TODAY i am looking for
duikkie
Post by duikkie » Mon Dec 25, 2017 9:46 am
maybe this is something for a sticky item :)
i have found the verobard but know i am looking for the name of
the 40 pins connector male on motherboards for the harddrive flatcable
sometimes the are blue, mostly black or white
so 40 pins ide male connector on pcb board gives 0 finds
Re: TODAY i am looking for
Post by jgharston » Mon Dec 25, 2017 9:59 am
duikkie
Post by duikkie » Mon Dec 25, 2017 10:08 am
on ebay they called :
20Pcs 2.54mm 2x20 Pin 40 Pin Straight Male Shrouded Box Header PCB IDC Connector
thanks
vanekp
Post by vanekp » Mon Dec 25, 2017 10:12 am
I think you are looking for IDC male PIN40 angled 90° like this one https://www.ebay.com/i/181040702954?rt=nc
Peter.
cmorley
Post by cmorley » Wed Dec 27, 2017 10:48 am
Yes box headers...
you can use websites like digikey or rapid electronics in the UK which allow you to browse by category & picture. Once you find the right thing you can see what they name it. The chinese ebay sellers often call things by weird names though so only 1/2 useful tip! With ebay sellers I find one then try searching again with terms the sellers use to see if I can get a better price/quantity...
duikkie
Post by duikkie » Wed Jan 31, 2018 2:21 pm
oke today i am looking for things to make a veroboard 4 holes to stand 3cm from desk. i know you did have plastic things for a motherboard in pc. looking for this or a small tube. maybe this is standaard somewhere around ?
---------- pcb board
______________ desk
and how are the called :)
Post by hoglet » Wed Jan 31, 2018 2:31 pm
"PCB Spacers" or "PCB standoffs"
Lardo Boffin
Post by Lardo Boffin » Wed Jan 31, 2018 2:33 pm
duikkie wrote:oke today i am looking for things to make a veroboard 4 holes to stand 3cm from desk. i know you did have plastic things for a motherboard in pc. looking for this or a small tube. maybe this is standaard somewhere around ?
______________ desk
Mounting feet?
https://m.ebay.co.uk/itm/8pcs-fixed-pla ... Ciid%253A1
BBC Master
JonC
Post by JonC » Wed Jan 31, 2018 3:10 pm
Stand offs. :D
Jon
Post by daveejhitchins » Wed Jan 31, 2018 4:22 pm
______________ desk
If you can't find "just what you want" send me a drawing and I'll print some for you :D
duikkie
Post by duikkie » Thu Feb 01, 2018 8:28 am
why , why,why ???
i am thinking of using a diode or something like pcb spacer :evil:
drawing : the 0.5 mm end to solder in a hole of the veroboard
the body of a component like diode
the other eind 2 or 2,5 mm for the other board (the problem :) )
length = 12mm
the registor cutting of one end some glue
or the cap two times solderd en glue on top for the other board
it is diy the dutch way :shock: :D
Post by 1024MAK » Thu Feb 01, 2018 12:41 pm
For stripboard or Veroboard, I drill 3mm size holes where I want the mounting points to be. Then use a combination of metric M3 machine screws, M3 washers, M3 nuts and M3 spacers (either unthreaded round types, or hexagonal cross-section threaded types). I find that the nylon PCB stand-offs often don't work very well in stripboard/ Veroboard.
The M3 machine screws, nuts, spacers etc are available in steel, some in brass, and in both natural and black nylon. If it will be exposed to sunlight (or some types of fluorescent light), don't use natural colour nylon parts, as they will go brittle and then break after a couple of years of exposure.
Here is an eBay listing showing abox of various black nylon M3 parts. But shop around, as the price varies. Search for "Nylon M3 Hex Spacers/Screws/Nuts Stand-off Assortment Kit Box Set for PCB".
M3 spacers
M3 machine screws, nuts and spacers etc
crj
Post by crj » Thu Feb 01, 2018 4:58 pm
1024MAK wrote:For stripboard or Veroboard, I drill 3mm size holes where I want the mounting points to be.
Outdoors, wearing a mask, because FR-4 dust is harmful to breathe... right?
Post by 1024MAK » Thu Feb 01, 2018 6:27 pm
It's made of FR-2 / SRBP.
crj
Post by crj » Fri Feb 02, 2018 1:24 am
I thought drilling any form of fibreglass produced pretty nasty dust?
vanekp
Post by vanekp » Fri Feb 02, 2018 5:37 am
https://en.wikipedia.org/wiki/FR-2 FR-2 is an abbreviation for Flame Resistant 2. It is a NEMA designation for synthetic resin bonded paper.
Post by 1024MAK » Fri Feb 02, 2018 5:49 am
FR-2 / SRBP Is not made of fibreglass. It is synthetic resin bonded paper. A composite material made of paper impregnated with a plasticized phenol formaldehyde resin. It is brown or light tan in colour. Still not a good idea to breathe in the dust. But then, it's never a good idea to inhale any dust. One of the biggest known causes of lung problems due to dust, is actually stone dust. Workers in industries where there is a lot of stone dust can, if precautions are not taken, end up with terrible problems.
Aside from the matrix boards and custom PCBs made of FR-4 from eBay, that mostly are made in China, normal commercial stripboard (which is the generic name, Veroboard being a manufacturers trade name) is made from FR-2 / SRBP. I buy mine from U.K. electronic parts suppliers.
PCBs can also be made from FR-2 / SRBP if no heavy components are used and the size of the board is not too large (or it is mounted on a suitable frame). PCBs made using FR-2 / SRBP are cheaper.
It is also possible to buy plain (with no copper tracks) sheets (in various thicknesses) of FR-2 / SRBP.
duikkie
Post by duikkie » Fri Feb 02, 2018 6:08 am
it is a small hole 2 mm veroboard, can't drill anything in it a tracks are used and 3 mm will cut a line.
maby a coil with wire is on the top 2 mm left and small on the other side ? to solder.
1024MAK wrote:For stripboard or Veroboard, I drill 3mm size holes where I want the mounting points to be. Then use a combination of metric M3 machine screws, M3 washers, M3 nuts and M3 spacers (either unthreaded round types, or hexagonal cross-section threaded types). I find that the nylon PCB stand-offs often don't work very well in stripboard/ Veroboard.
Post by daveejhitchins » Fri Feb 02, 2018 7:07 am
Which, if I remember correctly (?) is just paper and glue! - (phenolic)
duikkie
Post by duikkie » Tue Feb 06, 2018 6:58 pm
coils with value 2700 uH and look like a big resistor 1/2 or 1 watt ( silver,red,purple,red,gold) see other item :D
the other one is 560 uH ( to buy in china :) )
