2nd SATA hard drive??
Post by CMcDougall » Mon Aug 07, 2017 9:24 pm
On my desktop main work /music horse, I put it back to winXP when it came with Win Vista, wiped straight away :lol:
now, if I want to add other Hard Discs to it, the normal IDE ones 34+pins (PATA?) are easy, take out lead & power from old CD drive,
plug in the IDE one, wire up, power on, WinXP finds and can get all the stuff out it as drive D:
BUT, thought would do same but with a SATA drive, but it's a no show #-o
tried the Disk Management, still a no show, as usually with new HD they need Partitioned / formatted /wait ages / then "healthy"
so, does taking out the SATA lead & power from a DVD read/writer not work as same as the IDE..... :roll:
here is the drive, looked up the spec /instructions, but it does not show anything about 2nd drive or Jumper settings, maybe answer :?
pic of said SATA drive, brand new out TV vision boxes, WD -500GB -WD5000AVCS:
Re: 2nd SATA hard drive??
Post by 1024MAK » Mon Aug 07, 2017 9:36 pm
Is it showing up in the BIOS when the machine boots?
Is your BIOS set to show the boot sequence or is it set to hide the boot messages?
I've had multiple HDD including PATA, SATA and SCSI in systems before. Can't say I nicked the DVD/CD ROM drive connectors for it though (as I used spare leads and connectors that either the system already had, or used my own).
I have found with some motherboards, the specific SATA socket used is important. Use the wrong one and the drive gets ignored :twisted: But I think that was a design flaw with that motherboard design.
Post by CMcDougall » Mon Aug 07, 2017 10:01 pm
the Acer Desktop is always set to Auto detect everthing in the BIOS (saves me clicking the F10 key fast to stop for setup &save) :wink:
& boot is HD DVD CD Floppy
so, should find it, as per the easy IDE, but not sure about the faster 2 wire SATA's.....
might buy /try a USB docking thingy ma bob...(caddy!) if any good at £3, doubt it unless USB3, but again still slower one would expect :-k
topcat96
Post by topcat96 » Mon Aug 07, 2017 11:09 pm
The chances are that only the internal primary SATA port is actually set to auto configure as a HD in the BIOS. The CD drive you borrowed the cables and SATA port must already be configured as a CD/DVD drive in the BIOS and it needs to be changed.
I would suggest checking the BIOS settings and ensure the drive shows up in there first. If not then no amount of tinkering with windows disk management will solve your problem because the BIOS settings are basically "god" and tells any software that interrogates it whats connected.
BTW ... SATA drives don't need any jumper settings. It's all automatic as there's no Master or Slave requirement like there is in PATA. One SATA drive per SATA socket on the mainboard, no daisy-chaining allowed or possible.
JonC
Post by JonC » Tue Aug 08, 2017 12:36 pm
Also, while your CD/DVD Drive may have worked, cheap SATA cables can be fickle, so try changing it.
Also try plugging in to a SATA mobo connector that your current HDD sits on to see if it detects. :D
Jon
Post by CMcDougall » Wed Aug 16, 2017 8:39 pm
had another go a few days ago, it's not the cable, as it finds the DVD writer no probs, so maybe SATA2 cable is only for <5GB :-k
motherboard is dated 2008, & I updated the BIOS to latest version many moons ago... (now not supported 2017)
so it shows in the BIOS as I said everything is set to Auto.
It finds it in the Device Manager :
DM sata2
but when in Dis'K' (tut tut [-X Americans :lol: ) management, it's a no show, so can't partion /format :x
might pass on this, just wanted a bigger 2nd drive like the easy IDEs, for more music /backups, instead of ssssslow DVDs
JonC
Post by JonC » Thu Aug 17, 2017 2:11 pm
It sounds like it could be a faulty device.
If you have it in as the only drive and try a fresh Windows install on it, does it recognise the drive?
Edit: The drive could be factory partitioned to GPT, which means XP won't see it in Disk Management
Jon
TopBanana
Post by TopBanana » Thu Aug 17, 2017 3:25 pm
Just clarify for me - how are you plugging in the SATA drive ?
It's a SATA connection from the motherboard ?
Post by CMcDougall » Sun Oct 21, 2018 5:33 pm
just had another go with my 7x 500gb Western Digital WD5000AVCS sata 3.5" drives taken from old BT Vision TV box recorders.
answer is, linux does not look at them either from a CD/DVD boot disc.
further investigation is they are password protected, being "PACE FRANCE Master Security PWD2"
so, another boot CD prog called 'HDAT2 v6.4' can erase the password, but takes about 3.5hrs each drive #-o
if anyone knows of a faster way, let me know, as they are going in the very back of my loft now! :shock:
EDIT: this is same with the 160gb ones too #-o
EDIT2: the newer Vision box & Bush TV boxes have 2.5" 500gb laptop drives, no passwords!! :D
Post by CMcDougall » Sat Nov 03, 2018 1:34 pm
^ does anyone know a quicker way :?:
just smashed up a Sky vision box, 3.5" Sata 500gb hard disc within, plugged into my Desktop PC, found straight away & was one full partition of FAT32. :)
Post by 1024MAK » Sat Nov 03, 2018 3:38 pm
It sounds like those “password protected” drives are actually encrypted...
If you don’t want the data on them, a reformat may be quicker.
Return to “off-topic”
