Acorn Art Thread
guesser
Re: Acorn Art Thread
Post by guesser » Mon Nov 27, 2017 2:44 pm
kieranhj wrote: On a slight aside, I wondered if you might be interested in "emulating" / "approximating" the Teletext 2.0+ spec on a Beeb using Video NULA? I have no idea about the specs beyond the fact that you can use orange :D but you can certainly tweak the MODE 7 palette using the RobC's wonderful add-on.
What's the specs of the available palette etc? I assume it's just capable of remapping the 8 colours using a look up table? In which case most of my simple recoloured pics should work fine.
It's surprising how much difference just subtly tweaking the palette can make to a picture really.
kieranhj
Post by kieranhj » Mon Nov 27, 2017 2:58 pm
guesser wrote:What's the specs of the available palette etc? I assume it's just capable of remapping the 8 colours using a look up table? In which case most of my simple recoloured pics should work fine.
You can map all 7 colours in MODE 7 (not black) to anything from a 12-bit palette so 4096 possible colours.
Non-Teletext examples: viewtopic.php?f=3&t=13545
There's a small palette utility so you could save out an updated Teletext 2.X palette file for others to enjoy. :)
guesser
Post by guesser » Tue Nov 28, 2017 2:54 pm
Some wag on twitter suggested I should do a 9F with all the valve gear...
pixelblip
Post by pixelblip » Sun Dec 10, 2017 5:57 pm
Happy Christmas to all at Stardot from pixelblip
paulv
Post by paulv » Sun Dec 10, 2017 6:23 pm
pixelblip wrote:Happy Christmas to all at Stardot from pixelblip
^^^^^^^^ I think for many, this image evokes memories of seeing their first computer. It certainly does for me :D
Merry Christmas!
Post by FourthStone » Sun Dec 10, 2017 7:08 pm
Gorgeous! I want one [-o<
Post by tricky » Sun Dec 10, 2017 9:40 pm
Love it
pixelblip
Post by pixelblip » Fri Dec 15, 2017 11:10 pm
Happy Christmas Mode 7 version
pixelblip
Post by pixelblip » Fri Dec 15, 2017 11:13 pm
Geostationary Orbit
pixelblip
Post by pixelblip » Fri Dec 15, 2017 11:14 pm
Zironia
guesser
Post by guesser » Sat Dec 16, 2017 12:14 am
As requested here are all my train pictures with the level 2.5 teletext colour palettes included for VideoNuLA. :)
nulatrains.ssd
(13.5 KiB) Downloaded 26 times
(the Network Rail New Measurement Train has a slight defect on a Beeb because of the SAA5050 hold mosaics bug)
pixelblip
Post by pixelblip » Sat Dec 16, 2017 4:49 pm
2049
Inspired by the Soundtrack to the film which I painted this to........although it should be greyer - this picture is more Tron than Bladerunner!
pixelblip
Post by pixelblip » Sun Dec 24, 2017 10:15 pm
For Fourthstone
Happy Christmas All over The World
pixelblip
Post by pixelblip » Sun Dec 31, 2017 1:30 am
Metropolis
Post by FourthStone » Sun Dec 31, 2017 3:31 am
Wow the pastels are great!
Loving the split Christmas pic too, what a contrast of our Christmas extremes =D>
Happy New year all, looking forward to 2018 :D
pixelblip
Post by pixelblip » Sun Jan 14, 2018 3:41 pm
Orb
pixelblip
Post by pixelblip » Sun Jan 28, 2018 9:28 pm
Witches Brew
Site Admin
Post by Arcadian » Sun Jan 28, 2018 11:58 pm
Ooh that Witches Brew art is possibly my fave piccie so far ... but I absolutely adore all of them ... do keep 'em coming!! :)
pixelblip
Post by pixelblip » Sat Feb 03, 2018 7:05 pm
The Prettiest Star
pixelblip
Post by pixelblip » Sun Feb 04, 2018 5:22 pm
Stax III
Post by FourthStone » Sun Feb 04, 2018 7:00 pm
Loving the new pictures, the last one has some quite interesting shades happening.
=D>
pixelblip
Post by pixelblip » Fri Feb 09, 2018 9:15 pm
Solar Flare
pixelblip
Post by pixelblip » Sat Feb 10, 2018 6:51 am
Pyramids of Time
pixelblip
Post by pixelblip » Sun Feb 18, 2018 4:16 am
Em=2
pixelblip
Planet Pyro
pixelblip
Post by pixelblip » Sat Feb 24, 2018 5:11 am
Faster than light
Post by FourthStone » Sat Feb 24, 2018 7:32 pm
Impressive! You've been busy again :D
SimonSideburns
Post by SimonSideburns » Sun Feb 25, 2018 11:56 am
I've been loving these pictures.
Has anyone created compressed versions of these and shoved them on a disc or multiple discs to create a slideshow?
If not, I'm quite happy to try to do so, but just wanted to avoid duplication of work if they'd already been converted.
I don't know how many will fit on a disc as due to the dithering they won't compress all that much, but if there are 4 sides to play with they may all fit. The LDPIC and SVPIC routines are freely available but is there a better option? Is there any Windows software that can do the conversion rather than trying to LOAD the files onto BeebEm?
Failing that, what is required to use the DataCentre (is it simply a case of accessing the files directly on drive 5) or a MMC type device? I only have the DataCentre so I wouldn't know what capabilities the MMC type devices have. The one benefit of the DataCentre approach is that adding new pictures when pixelblip creates them could be easier.
I'm writing a game where you can change your character from a Wizard to a monkey to a cat.
Well, Imogen that!
ctr
Post by ctr » Sun Feb 25, 2018 3:27 pm
SimonSideburns wrote:I've been loving these pictures.
I've been loving the pictures too. I thought they might make a good wallpaper, but I should have realised it would clash with all the icons on my desktop. It's attached anyway.
As a side effect of this I "normalised" all the pictures into the same resolution and bit depth of PNG file, and also made MODE 2 versions of them all. A couple of the early pictures aren't quite pixel-perfect because they've been converted from shrunken JPEGs. A zip with all these files is attached too.
Edit: btw, this doesn't include the MODE 7 pictures.
pics.zip
(1.4 MiB) Downloaded 15 times
