smps schematic with pictures
duikkie
Post by duikkie » Fri Dec 16, 2016 10:10 am
i am hopeless with finding thing on internet ;)
but are there sides with electronic things with scoop pictures
as simple as a trafo if i put 220 ac too 12 volt is the picture on prim and sec side ( i can't find it)
of course i what pictures of a smps transformer with pictures
but how is it called to look for with google ? electronic scoop pictures ?
i am happy with anything ( low -pass filter to blok pictures of a ne555, ossilators with components)
if i find a side which explains thinks is it mostly to simple ( with cars half full on the prim side (trafo), and less car full at the sec side) (p=u*i===p=u*i)
but i want scoop pictures !!!
poink
Re: smps schematic with pictures
Post by poink » Fri Dec 16, 2016 11:56 am
Have you tried a design guide? For instance, this one by OnSemi, has both the basic circuits, and the waveforms you'd expect for a working SMPS, albeit without all the filtering and safety components.
Per component detail tends to drop off for the full application circuits; but if you want to really dig down on one of those; perhaps make a low voltage (eg., DC to DC) one on the bench[1] or in a circuit simulator like SPICE?
[1] Voltages in a mains powered SMPS are over (or at least very close to) to a scope's limits; you need an expensive high voltage differential probe...
duikkie
Post by duikkie » Fri Dec 16, 2016 2:28 pm
that spice is that free ware ?
i know about high voltage therefor i need internet :) to see what the picture is.
i will study the pdf file but i think i understand the theory.
poink wrote:Have you tried a design guide? For instance, this one by OnSemi, has both the basic circuits, and the waveforms you'd expect for a working SMPS, albeit without all the filtering and safety components.
Post by 1024MAK » Fri Dec 16, 2016 3:32 pm
Talking of PSUs and SPICE (it is a series regulator rather than a switch mode type though).
More SPICE here!
poink
Post by poink » Fri Dec 16, 2016 9:38 pm
duikkie wrote:that spice is that free ware ?
There's several free and/or open source versions of SPICE. Very powerful, not necessarily the easiest thing just to pick up and use (as is fairly typical of EDA tools, of course).
dp11
Post by dp11 » Fri Dec 16, 2016 9:41 pm
For PSUs the you want LTSpice : http://www.linear.com/designtools/software/
duikkie
Post by duikkie » Sat Dec 17, 2016 10:52 am
Off course you have more versions
which one to draw and simulate the hole
bbc psu ?
dp11 wrote:For PSUs the you want LTSpice : http://www.linear.com/designtools/software/
duikkie
Post by duikkie » Sat Dec 17, 2016 3:10 pm
maybe i am to stupid for this sort of programs ?
i can't find the symbool to get power on ??
simple a registor r1 r ?? how to put value in ? symbool of gnd is there
but symbool v1 from examples i don't know where ???
so 5 volt over a R to ground ??? to measure
5 volt r1 then r2 to gnd . measure voltage between r1 and r2 if i can not put power symbool then nothing can run :(
duikkie
Post by duikkie » Sat Dec 17, 2016 3:33 pm
hopeless
duikkie
Post by duikkie » Sat Dec 17, 2016 3:36 pm
there must be 5 volt no 0.00 mv
poink
Post by poink » Sat Dec 17, 2016 5:12 pm
duikkie wrote:there must be 5 volt no 0.00 mv
What you've got there is pretty much just a couple of resistors on the negative terminal of a battery. Hence, the reading looks correct; there's no potential difference anywhere (except across the voltage source itself).
duikkie
Post by duikkie » Sun Dec 18, 2016 9:05 am
oke there is a symbool for gnd but the voltage symbool is for neg and pos :shock:
we learn everyday more and more :oops:
duikkie
Post by duikkie » Sun Dec 18, 2016 3:18 pm
how do i get ac as power ?
i know for working order there must be 130khz pulse on collector q3(=q1)point by r18(=r2)
l3 is not connected. and one R by the diverder
what am i doing wrong ???
see allso the psu by hand item
osc5.zip is zip file for ltspice 4
osc5.zip
(1.11 KiB) Downloaded 12 times
duikkie
Post by duikkie » Sun Dec 18, 2016 3:20 pm
pictures
poink
Post by poink » Sun Dec 18, 2016 5:09 pm
duikkie wrote:how do i get ac as power ?
There's usually a voltage supply component with the AC (wiggly line) sign on it.
You don't want a voltage supply at both ends though.
In some cases, you might find a load resistor across on the output helpful (to simulate there being a beeb attached).
