Space Adventure on the Elk
Snuggsy187
Post by Snuggsy187 » Fri Oct 11, 2019 8:41 pm
Hi All,
One of my favourites BitD, but there wasn't a version of Space Adventure for the Electron :(
This is very much a work in progress, but thought I'd post a working version to see what people think !
Again Beeb VIA interrupts spoiled the show for the Elk - have removed these, but yet to do a replacement game delay timer, so speed is variable (yes, it's a bit slow when fighting androids, but then again a bit too fast when using a Turbo board) !
Disc and Tape versions vaguely tested on Elkulator - *RUN INST , or *RUN LOAD to skip the lengthy instructions !
SA-E-v0.1.uef
(14.25 KiB) Downloaded 9 times
SA-E-v0.1.ssd
(14 KiB) Downloaded 12 times
PUSH PARCHMENT > POKE LOCK > PULL PARCHMENT
0xC0DE
Re: Space Adventure on the Elk
Post by 0xC0DE » Fri Oct 11, 2019 9:02 pm
Looking good! It's great to see the Electron getting some love =D>
Haven't played this game before. The player keeps moving in the same direction even after releasing a key. Is that supposed to be like that?
0xC0DE
Snuggsy187
Post by Snuggsy187 » Fri Oct 11, 2019 9:11 pm
Thanks 0xC0DE :D
It's very odd, isn't it, you can only stop by pressing the spacebar, but that's how it is on the original Beeb version !
Key control choice strange as well - why use " ; . " instead of " : / " ? :?
0xC0DE
Post by 0xC0DE » Fri Oct 11, 2019 9:19 pm
But now is your chance to change/improve all that! :mrgreen:
Was the original Beeb game written in asm? Have you reverse engineered it or,....?
0xC0DE
Snuggsy187
Post by Snuggsy187 » Fri Oct 11, 2019 9:31 pm
Agreed, maybe I'll put in some sort of key control choice....
Original game released in 1983 by Virgin / Pro Software (?)
I just disassembled the original game and imported it into ASM (Making some memory relocation changes and such like). Still annotating, and getting my head around a weird sprite print routine, but will post the Elk ASM version when I'm happy with it :D
0xC0DE
Post by 0xC0DE » Fri Oct 11, 2019 9:43 pm
Great! We need more coders for the Electron! I write 6502 code on it every day 8)
Asking the real questions here: did you ever get your Electron out of storage?????
0xC0DE
Snuggsy187
Post by Snuggsy187 » Sat Oct 12, 2019 8:22 am
Alas no :oops: But I did set eyes on it last weekend ! I shall endeavour to resolve the situation ! :D
Snuggsy187
Post by Snuggsy187 » Mon Oct 21, 2019 8:11 pm
So here's version 0.2 !
Still slow on a standard Elk, but I've put in a replacement delay timer. Runs better with turbo of course.
ASM attached - bit of a mess, but there's a couple of hidden cheats you can enable !
Assemble with:
beebasm -i SA-E-ASM-v0.2.asm -do SA-E.ssd
Been mainly making code space in the hope of sorting out the convoluted sprite print routine (sorry whoever wrote it, but I think it is !). For example, when you walk left, it will flip the right facing sprites and then print them - EVERY time !
Saved a lot of space ditching numerous furniture print routines for a standard use one.
Changed the keys to : / instead of ; . - still SPACE to fire (there is some kind of keyboard conflict when using RETURN to fire and moving diagonally) :roll:
Also still need to generate some randomness when placing the door keys, energy cells etc. - they're in the same place every time the game is loaded at the moment........ :D
SA-E-ASM-v0.2.asm.txt
(70.23 KiB) Downloaded 12 times
SA-E-v0.2.uef
(14.16 KiB) Downloaded 7 times
SA-E-v0.2.ssd
(14 KiB) Downloaded 8 times
0xC0DE
Post by 0xC0DE » Mon Oct 21, 2019 8:43 pm
Great work! =D>
0xC0DE
Snuggsy187
Post by Snuggsy187 » Tue Nov 05, 2019 11:19 am
Version 0.3 !
There's been a bit of chaos with this - finally got a "random" generator working for the item and android placement, seeding off the system clock. Kept getting a crazy bug when drawing the room exits. Turned out to be a strange issue in the &0D00 page (which seemingly had nothing to do with it !)
Redesigning the sprite print may need a huge rewrite. I suddenly remembered M Jakobsen's excellent guide in the Electron User for speeding up the Electron. So, I disabled the keyboard and used direct hardware access instead. I've also (for the moment) turned off the ADC channels, so joysticks will not work. I need to check and test the direct hardware lookups for joysticks on a real Electron........
Speaking of which, guess what, my Electron and associated gubbins are now out of storage :D - I may tell the (ongoing) story of getting it working in the Hardware section...... :evil:
Note - haven't tested this version to completion, but looks ok......and seems quicker, without Turbo !
SA-E-v0.3.uef
(14.25 KiB) Downloaded 7 times
SA-E-v0.3.ssd
(14 KiB) Downloaded 6 times
SA-E-ASM-v0.3.asm.txt
(72.34 KiB) Downloaded 7 times
