Page 1 of 1
STH Elite disc image
Posted: Wed Sep 11, 2019 6:20 pm
by Diminished
During testing on the Disc Toaster I encountered this Elite image from the Stairway archive:
http://www.stairwaytohell.com/bbc/archi ... /Elite.zip
Downloading and extracting it yields an SSD file of 115456 bytes.
The maximum size for a standard-formatted 40 track disc is 256 bytes per sector * 10 sectors per track * 40 tracks, which gives exactly 102400 bytes.
So, what's with this image? I'm guessing it used some non-standard sector format to squeeze the extra data in there -- can anyone confirm?
Re: STH Elite disc image
Posted: Wed Sep 11, 2019 7:13 pm
by billcarr2005
It's an 80 track disc, with only sectors with data being in the image, ie. no additional formatted tracks filled with &E5
Any non standard format wouldn't emulate correctly...
Posted: Wed Sep 11, 2019 7:15 pm
by Diminished
That explains it, thanks.
Was Elite not available at all on 40 track disc?
Posted: Wed Sep 11, 2019 7:26 pm
by billcarr2005
On the original disc, drive 0 was 40 track and if an 80 track drive was detected the data was loaded from drive 2
Posted: Wed Sep 11, 2019 7:42 pm
by Diminished
So side A was 40 track and B was 80 track?
Does anyone know if there's an image of the 40 track version anywhere? Both my drives are 40.
Posted: Wed Sep 11, 2019 9:22 pm
by billcarr2005
The original disc has an unformatted track and also several tracks where the physical and logical track numbers don't match, so a straightforward SSD isn't possible... but there shouldn't be any reason why the STH version won't write to a 40 track disc, just delete $.ELTDEMO and $.ELTCODE (the ELITE rolling demo)
Posted: Wed Sep 11, 2019 10:22 pm
by Diminished
Ah, that's interesting. In theory I could write a nonstandard disc like that, but I'd need to write a parser for hq-UEF files and since I'm doing everything on an embedded system in ARMv4 ASM with a 16K RAM workspace, I don't fancy it right now.
I'm slowly finding more discs that don't have a 40-track compatible version on STH. Repton 1 is another one.
Posted: Thu Sep 12, 2019 8:11 am
by billcarr2005
But at least Repton ( the version here? https://www.stairwaytohell.com/bbc/arch ... Repton.zip ) is undersized and can be padded out if necessary. The fact that the SSD says it's an 80 track disc can largely be ignored.
Posted: Thu Sep 12, 2019 12:25 pm
by Diminished
Whoops, you're right.
Well, that's curious; my code rejected that image. It seems you have just managed to find a bug from miles away. :lol:
