Electron Elite query
trixster
Post by trixster »
Someone on the fb group was suggesting Elite might have been released for electron on disk as well as cassette. Was there a disk release?
Re: Electron Elite query
Post by davidb »
I've never heard of a disk release. There's no mention of one on Ian Bell's Elite pages and only the original cassette version is listed on Every Game Going.
There could have been a re-release on disk, though I don't remember seeing anything like that. Perhaps the person was thinking about unofficial hacks to make it run from disk, like those on the EGG entry page, linked to above.
trixster
Post by trixster »
Yes, and there's no mention on FrontierAstro which i thought had a pretty comprehensive list of what versions were released.
Post by danielj »
Indeed. Never released on disk. There was only ever a tape release. Two versions under acornsoft, one (I think?) under superior. First version had knackered galactic hyperdrive (not that that made too much difference as there was no need to leave galaxy 1).
AndyF
Post by AndyF »
Fractionally off topic here but what happens if you try the MasterCompact (ADFS Based by default) version of Elite on the Elk ? I'm only picking this one up as ( a ) The M128C version is ADFS and ( b ) If I remember correctly (not seen one for years) the plus expansion for the ELK only really initially gave ADFS ?
I don't have either an emulator or disk image of said version to hand as I write this otherwise I'd of tried. Then again its probably going to demand shadow memory and fall over I guess. :-k , I'm not sure what would happen about the awol Mode7
As above only reason for even suggesting this is both are ADFS 'by default' as such.
Mind you I had a late DFS in my Compact which was a nice addition ! :D
Andy
Post by danielj »
It won't work as it relies on the beeb's hardware which the elk doesn't have.
Post by CMcDougall »
Plus the mCompact ADFS version is page at &E00 with colours, so that's out the window as elk with ADFS is crap at &1D00 :evil: and can only handle B&W per tape version.
Post by DutchAcorn »
Best simply use the Elk disc version (attached).
ElkElite.zip
(26.43 KiB) Downloaded 29 times
rmbrowngr
Post by rmbrowngr »
I have on disk Elite for the Electron from www.acornelectron.co.uk DVD. Unfortunately it’s the tape version transferred to disk and saving and loading commanders is to tape.
Richard B
That’s probably the same version I just posted then...
trixster
Post by trixster »
DutchAcorn wrote:
Tue May 14, 2019 5:37 pm
Is this the cassette version on a disk.... or an official elk disk version...?
Post by danielj »
Cassette version on disk. There was no disk version. There was no disk version. There was no disk version.
trixster
Post by trixster »
There is no disk version.
So what is it?
It’s a White Hole....
danielj wrote:
Tue May 14, 2019 6:59 pm
by the way, there was no official disc version :lol:
whoever done the unofficial tape to disc of exile are mental!
topcat96
Post by topcat96 »
Why no Electron Elite on floppy disk !!!! :(
CMcDougall wrote:
Tue May 14, 2019 7:26 pm
Exile? Was there an official Electron disk version for Exile?
Post by danielj »
Andrew_Waite
Post by Andrew_Waite »
It is odd that there was never a Plus1 cartridge version of Elite. Much of the code could have run in the faster half of the Electron's memory map.
Post by danielj »
Cartridge games didn't run from ROM, they just used the cartridge as a fast tape (ROM filing system) to load it into RAM. I suspect it'd have needed a fair amount of rejiggling to run from ROM. If you want to know what this would have been like, have a poke at the mega-games cartridge :)
