Who's ready for... guess that game! ;D
Re: Who's ready for... guess that game! ;D
Post by chrisn » Wed Apr 03, 2019 11:25 am
Estra!
0xC0DE
Post by 0xC0DE » Wed Apr 03, 2019 11:33 am
It's almost like a pair of eyes...
0xC0DE
dv8
Post by dv8 » Wed Apr 03, 2019 11:46 am
Estra!
We have a winner! =D>
Post by lurkio » Wed Apr 03, 2019 1:34 pm
Wow, these have been rock-hard! Let's lower the bar a bit...
Post by Rich Talbot-Watkins » Wed Apr 03, 2019 4:08 pm
This is from one of those single screen platformers from the mid 80s! Was going to guess Karl's Kavern but I couldn't see it on the attract screen. Nor does it seem to be Blagger. Hmmmm :-k
scarybeasts
Post by scarybeasts » Wed Apr 03, 2019 8:30 pm
Sim? And wasn't that 4 the channel 4 logo from the time?
Post by lurkio » Wed Apr 03, 2019 8:40 pm
Correct, and correct!:
=D> =D> =D>
dv8
Post by dv8 » Thu Apr 04, 2019 10:20 am
Let's try another musical one.
In no way is this a blatant attempt to try and get more interest in a project of mine that seems to have fallen flat on its face. :^o
Grab the SSD from this post, mount the disc then enter (or copy+paste) the following command:
*PLAY O1 t-5 I R3: Cp8 Ep8 Gp8 Ep8 : H Cp8
Which game is this little tune from? Should be an easy starter for 10.
sbadger
Post by sbadger » Thu Apr 04, 2019 11:00 am
It just says, "Bad Chord" :?
dv8
Post by dv8 » Thu Apr 04, 2019 11:12 am
Are you using the latest version? (8th chords were added in version 1.02).
Diminished
Post by Diminished » Thu Apr 04, 2019 11:59 am
(Early raytrace? Phong shading? Still holds up. https://www.youtube.com/watch?v=R86_TLuI51w )
sbadger
Post by sbadger » Thu Apr 04, 2019 2:24 pm
That fixed it, That's from Acornsoft Monsters! :D
Post by Rich Talbot-Watkins » Thu Apr 04, 2019 2:25 pm
It worked for me! And it was so familiar yet so elusive. And then when I was least expecting it, the answer popped into my head:
<spoiler>
Acornsoft Monsters
</spoiler>
That PLAY command line is pretty versatile! Great to be able to write a little tune like that in such a small number of characters.
Bah, you beat me to it!
dv8
Post by dv8 » Thu Apr 04, 2019 3:10 pm
Yes, it's Monsters.
Considering you both posted within a minute of each other we'll call it a draw!
Now for something a little more obscure:
ENVELOPE 1,1,0,0,0,0,0,0,127,-4,-71,-3,127,0
*PLAY =! N1 =,2 O3 I ^#F,^D, ;75 ^D,A, ^D,B, ^D,A, ;100 B,G, A,#F, ^D,A
Post by lurkio » Thu Apr 04, 2019 6:24 pm
Yep! A bit like this one:
*PLAY N1 =,2 O3 I ^#F,^D, ;75 ^D,A, ^D,B, ^D,A, ;100 B,G, A,#F, ^D,A
Aaargh! Can't think of it.
:evil:
billcarr2005
Post by billcarr2005 » Thu Apr 04, 2019 7:23 pm
Yes we have no bananas!
from Banana man?
http://bbcmicro.co.uk/game.php?id=1
dv8
Post by dv8 » Thu Apr 04, 2019 7:48 pm
Yep! It was Banana Man =D>
dv8
Post by dv8 » Fri Apr 05, 2019 11:32 am
One more tune:
*PLAY @48 O3 SGA IBG S^CB QA S#FG IA#F SGB Q^D
dv8
Post by dv8 » Sat Apr 06, 2019 10:19 am
No-one? Okay, here's a clue:
Post by lurkio » Sat Apr 06, 2019 12:34 pm
One more tune: *PLAY @48 O3 SGA IBG S^CB QA S#FG IA#F SGB Q^D
No-one? Okay, here's a clue: guess_the_game.png
No idea! :oops:
But just for the hell of it, here's the tune playing in JSBeeb:
:idea:
Post by davidb » Sat Apr 06, 2019 2:35 pm
Bumble Bee
dv8
Post by dv8 » Sat Apr 06, 2019 3:23 pm
Correct, it's Bumble Bee. =D>
dv8
Post by dv8 » Fri Mar 06, 2020 3:16 pm
Thought I'd try resurrecting this thread after finding a few games left over from last time.
For starters, here's a really easy one. Which game is this tune from?
10 ENVELOPE 1,1,0,0,0,1,1,1,126,-10,-2,-4,126,60
20 REPEAT
30 READ N%
40 P%=N% AND &7C
50 D%=((N% AND 3)+1)*2
60 SOUND 1,1,P%,D%
70 UNTIL N% AND 128
80 DATA 93,72,81,72,61,175
In keeping with the OP's idea that this can be educational as well as a bit of fun, let's dissect the above code.
(Feel free to skip the rest of the post if you don't care about code and just want to guess the game!)
The interesting thing about the tunes in this game is that each note is encoded using only a single byte.
If you've ever programmed music on the Beeb or Elk you will know that the pitch of each note (semitone) is 4 units apart from the next. As a consequence of this the bottom two bits of the pitch parameter are effectively unused. This game uses these unused bits to store the duration. The format of the bits in each byte value is:
E P P P P P D D
where P (bits 2-6) is the pitch from 0 to 124 in steps of 4, D (bits 0-1) is the duration from 0 to 3, and E (bit 7) is an end-of-tune marker. Bit 7 can be used in this way because all the pitch values are below 128.
In the above listing, line 40 extracts the P (pitch) bits using N% AND &7C. When used as a bitwise operator, AND can be used to mask off certain bits in a value and to keep others. If you look at the binary representation of the hex value &7C, i.e. 01111100, you will see that each 1 corresponds to the position of a P bit above and each 0 corresponds to a discarded bit.
Line 50 extracts the D (duration) bits from the value using N% AND 3. In binary 3 is 00000011 so it keeps just the lower two D bits and discards all the others. This leaves us with a value between 0 to 3, not that useful for a duration. The code then adds 1 to get a value between 1 and 4 and finally multiplies by 2 to give one of four possible durations: 2, 4, 6, 8.
Line 70 detects the end of the tune by testing N% AND 128. In binary 128 is 10000000, so just bit 7 is retained. The UNTIL statement treats any non-zero value as TRUE. So, when bit 7 of the note is 0 the expression evaluates to FALSE and the loop keeps running, but when bit 7 of the note is 1 (as it is for the last note) the value of N% AND 128 becomes 128 which is treated as TRUE and the loop ends.
If you want to see the actual sound parameters as they are extracted from the data, add the line:
55 PRINT P%,D%
iamaran
Post by iamaran » Fri Mar 06, 2020 4:22 pm
Frak!
dv8
Post by dv8 » Fri Mar 06, 2020 4:51 pm
Correct, it was Frak! =D>
As a prize here are the other tunes from the game.
Make these changes to the listing in the previous post...
End of game:
80 DATA 68,69,82,80,84,89,80,70,65,60,68,60,81,64,69,55,231
For the in-game tunes add these lines:
15 RESTORE
75 GOTO 15
then, Tune 1:
80 DATA 33,33,41,49,54,34,41,54,33,32,41,54,34,41,53,61,65,69,74,54,61,74,40,40,44,48,52,74,53,52,61,72,72,69,73,77,82,61,60,69,82,48,52,48,56,60,82,61,60,69,80,84,88,65,52,61,54,52,22,20,26,24,30,28,32,28,32,37,44,165
Tune 2:
80 DATA 15,61,13,27,73,25,13,61,13,25,73,25,61,13,43,81,41,9,89,9,13,61,41,33,13,25,33,21,109,15,109,13,27,85,25,13,81,13,25,81,25,73,13,43,81,41,9,89,9,13,61,41,35,27,21,217
Tune 3:
80 DATA 35,13,17,23,49,45,41,17,13,29,33,13,21,29,35,13,17,23,49,45,41,33,29,21,13,21,25,29,35,13,21,33,41,45,49,55,49,53,59,53,57,35,29,25,21,51,45,41,17,13,29,33,60,61,68,189
dv8
Post by dv8 » Sat Mar 07, 2020 2:43 pm
Okay, the last one was obviously way too easy so here's something a little more challenging.
Name the game:
 10 ENVELOPE1,1,0,0,0,0,0,0,126,-4,0,-1,126,100
 20 ENVELOPE2,1,0,0,0,0,0,0,60,10,0,-60,60,120
 30 SOUND &201,1,61,16 : SOUND &202,2,45,16 : SOUND &203,2,33,16
 40 SOUND &201,1,61,16 : SOUND &202,2,45,16 : SOUND &203,2,33,16
 50 SOUND &201,1,65,24 : SOUND &202,2,53,24 : SOUND &203,2,33,24
 60 SOUND &201,1,61,4  : SOUND &202,0,0,24  : SOUND &203,0,0,24
 70 SOUND &001,1,53,4
 80 SOUND &001,1,61,64
 90 SOUND &102,2,41,8  : SOUND &103,2,29,8
100 SOUND &102,0,0,8   : SOUND &103,0,0,8
110 SOUND &102,2,45,32 : SOUND &103,2,33,32
Play in jsBeeb (hopefully) [-o<
billcarr2005
Post by billcarr2005 » Sat Mar 07, 2020 3:54 pm
My first guess was Templeton (incorrectly) but my second was Rubble Trouble :)
dv8
Post by dv8 » Sun Mar 08, 2020 10:42 am
Yes, it was Rubble Trouble =D>
I thought it would take longer for someone to get it!
Let's raise the bar a bit then, which game is this from:
sbadger
Post by sbadger » Mon Mar 09, 2020 10:28 am
Bubble Bobble?
