Newbie with some tape loading queries
Balmoral James
Post by Balmoral James » Sat Aug 25, 2018 11:29 am
As a newbie to the BBC B I have been getting into the system since I bought it 2months ago, having owned other 8bit systems including the Electron for years I thought it was time to sample the BBC having heard many great things about it. Some of the issues I've had I have described on another thread but as for tape loading I have been playing a few of my compatible Electron games and have followed the *tape then chain"" command and that has generally been fine for me.
However I have run into problems loading a few dedicated BBC games such as Matchday and Knightlore. When I try and load them I get the message Locked. What does that mean? Does that mean the tape is damaged or have I entered the wrong loading commands. Both games are boxed but have no instruction manuals so I have been winging it so far! Any tips on this will be happily received (since I have joined the forum I have been bothering you all with my Beeb ineptitude and you have been fantastic so far) once again I throw myself at your mercy!!
MartinB
Re: Newbie with some tape loading queries
Post by MartinB » Sat Aug 25, 2018 11:40 am
'Locked' is the Beeb's response to a copy-protected tape (albeit a fairly minimal protection system) but you'll usually only see it with an original tape if you are using the wrong initial loading command. If yours is a disc machine, you should also enter PAGE=&E00 <Enter> after the *TAPE command and before the first loading command. If you then still see the locked message with CHAIN"", try *RUN <Enter>.
Post by hoglet » Sat Aug 25, 2018 11:41 am
For Knightlore, instead of CHAIN "" try *RUN
Balmoral James
Post by Balmoral James » Sat Aug 25, 2018 8:49 pm
Thankyou very much for that chaps. I'm off to try them out!
AndyF
Post by AndyF » Sun Aug 26, 2018 1:40 pm
I could not easily find the instructions / inlay for the 'B version unfortunately. I did find a nice review though of said version. :D
However the 'Gold Collection' "tape" variant does appear to require a *RUN to load it rather than the more usual CHAIN "" , so I concur with hoglet on that point.
PS, Welcome! :)
Andy
Post by hoglet » Sun Aug 26, 2018 1:47 pm
There is some documentation here:
http://8bs.com/othrdnld/manuals/game/Go ... on-doc.zip
MartinB
Post by MartinB » Sun Aug 26, 2018 2:03 pm
Andy wrote:....so I concur with hoglet on that point.
...and Martin :- O:)
AndyF
Post by AndyF » Sun Aug 26, 2018 5:17 pm
Somehow I missed his post #-o , sorry Martin! :D
Andy
Balmoral James
Post by Balmoral James » Wed Aug 29, 2018 6:22 pm
Cheers Guys, as ever you are fantastic.
AndyF
Post by AndyF » Wed Aug 29, 2018 7:56 pm
And somehow I half missed that too! Sorry Dave! :oops:
It does mention it as well in said inlay paperworks you found:
Gold Collection Inlay wrote:Check that your machine is in the correct loading mode by typing *TAPE then press RETURN and. If you have a filing system other than TAPE installed, type PAGE = & EOO then press RETURN (if you are uncertain as to whether this applies then do it anyway.)
To load the required program type CHAIN "" then RETURN; (*RUN or */ to load JETPAC, KNIGHT LORE or SABRE WULF) followed by PLAY on the cassette recorder. The required game will load automatically.
That's the main thing that you managed to sort it out (hopefully!) good to read. :) :)
Andy
