Five-A-Side Soccer for the Electron
robcfg
Post by robcfg » Mon Dec 31, 2018 12:26 pm
I found a small stack of Electron games at my parent's place, and decided to dump them just for fun and learning how to do it.
Thing is, I managed to get an UEF file from my wav file, but I'm not able to load it on any emulator.
This is the MakeUEF log:
Found :      SOCCA 00	Checksum ok
Found :      SOCCA 01	Checksum ok
Found :      SOCCA 02	Checksum ok
Found :      SOCCA 03	Checksum ok, last block flag
Found :      DATA1 00	Checksum ok, last block flag
Found :          ? 00	Checksum ok
Found :          ? 01	Checksum ok
Found :          ? 02	Checksum ok
Found :          ? 03	Checksum ok
Found :          ? 04	Checksum ok
Found :          ? 05	Checksum ok
Found :          ? 06	Checksum ok
Found :          ? 07	Checksum ok
Found :          ? 08	Checksum ok
Found :          ? 09	Checksum ok
Found :          ? 0A	Checksum ok
Found :          ? 0B	Checksum ok
Found :          ? 0C	Checksum ok
Found :          ? 0D	Checksum ok
Found :          ? 0E	Checksum ok
Found :          ? 0F	Checksum ok
Found :          ? 10	Checksum ok
Found :          ? 11	Checksum ok
Found :          ? 12	Checksum ok
Found :          ? 13	Checksum ok
Found :          ? 14	Checksum ok
Found :          ? 15	Checksum ok
Found :          ? 16	Checksum ok
Found :          ? 17	Checksum ok
Found :          ? 18	Checksum ok
Found :          ? 19	Checksum ok
Found :          ? 1A	Checksum ok
Maybe it's missing the last block flag or the last block altogether.
Also, the tape is marked as an Electron tape, but I've managed to see the loading screen on BeebEm4 emulating the Model B/Master. How compatible are the different Acorn 8-bit models?
Rob
Re: Five-A-Side Soccer for the Electron
Post by CMcDougall » Mon Dec 31, 2018 12:43 pm
only works on an Elk emulator.
all mine are here, inc 5aSideSoccer-ELK :
viewtopic.php?f=32&t=5023&start=30#p190758
the bible to make them from unreadable old tapes is here:
viewtopic.php?f=6&t=5987&p=56042&hilit= ... ike#p56019
robcfg
Post by robcfg » Thu Jan 03, 2019 12:02 pm
I've tried it on MAME 0.202 but fails at the end of the load.
That said, I'm having trouble finding an Electron emulator that works on MacOS...
robcfg
Post by robcfg » Thu Jan 03, 2019 1:05 pm
I finally got Clock Signal and managed to load your UEF file, @CMcDougall
If try to load mine I get a "Bad ROM at line 140" error. Anyone knows what kind of error is that?
Post by CMcDougall » Thu Jan 03, 2019 6:24 pm
^ it must just be a bad .WAV file & the UEF maker has transfered / picked up something not 100% so manipulated it as something else
if mine works, then it ain't a ROM that needs unplugged from your elk, as nothing in a bog standard elk (no plus1 / plus3) as only OS1.00 & Basic2
