Level9's Lancelot & Scapeghost
lolinhoz
Postby lolinhoz » Wed Feb 27, 2002 7:33 pm
Well, I really CAN'T make them run on Beebem, and I do not understand why!<br>
<p></p><i></i>
Re: Level9's Lancelot & Scapeghost
Postby Arcadian » Wed Feb 27, 2002 11:47 pm
You need a 64k B+ to run Scapeghost in text-only mode, and a Master 128k to run the graphical version. The same probably applies to Lancelot, so I reckon this is where the problem lies as BeebEm emulates a standard Model B by default.<br>
<br>
Whilst running BeebEm in Master-mode should *in theory* resolve this, there seems to be an emulator bug at present. <!--EZCODE EMOTICON START :( --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/frown.gif ALT=":("><!--EZCODE EMOTICON END--> <br>
<br>
I've tested them on a 'real' Master and they both load up fine. <p></p><i></i>
lolinhoz
Postby lolinhoz » Thu Feb 28, 2002 11:47 am
Yes, I think it should be an emu problem, because I've already tried to run them in the Master mode.<br>
<p></p><i></i>
Postby Arcadian » Fri Mar 01, 2002 12:44 am
I haven't checked, but I think MESS features B+ emulation ... perhaps you could try this?!? <p></p><i></i>
davidk
Postby davidk » Fri Mar 01, 2002 7:52 pm
I can get both of them to run okay under BeebEm 1.4 in BBC B mode - What doesn't work?<br>
<br>
If I run as BBC Master then the graphics appear to be all messed up, which looks like an emulator problem.<br>
<br>
David<br>
<p></p><i></i>
