List of Beeb/Elk Quill Adventures for Atom Porting
Postby hoglet » Sun Mar 02, 2014 9:03 am
I'm trying to put together a list of BBC/Electron Text Adventures written using The Quill, with a view to picking a few of the best and porting them to the Atom.
Here's my list, which I'll try to update as we find more.
I'm looking for requests and/or recommendations for which ones to do first. I'm hoping this will be mostly mechanical, as I think they all use the same database format.
Larsoft
Wychwood - Geoff Larsen
The Puppet Man - Geoff Larsen
Hex - Geoff Larsen
Rising Of Salandra: Return Of The Warrior - Geoff Larsen
Rising Of Salandra: The Prophecy - Geoff Larsen
The Nine Dancers - Geoff Larsen
http://www.acornelectron.co.uk/profs/el ... rsoft.html
http://www.beebgames.com/games.php?company=161
(all in The Larsoft Collection)
Elk Adventure Club
Magnetic Moon - Larry Horsfield
Reluctant Hero - Paul Waterman
Rohak The Swordsman - Aamar Mazir
Starship Quest - Larry Horsfield
The Axe Of Kolt - Larry Horsfield
http://www.beebgames.com/games.php?company=87
Lee Software
In Search of Atahaulpa - Anthony Lee
Annabel Gray - Anthony Lee
http://www.acornelectron.co.uk/profs/el ... s/lee.html
Squaresoft
Runestaff - Martyn Amos
http://www.acornelectron.co.uk/profs/el ... quare.html
http://www.ifarchive.org/if-archive/gam ... taff_E.zip
Riverdale
Suds - David Edwards
American Suds - David Edwards
Aussie Suds - David Edwards
Some other titles, might not be Quill:
Paranoral
What the Dickens?
http://www.beebgames.com/games.php?company=244
Andy F Quill Ports
Urban Upstart
Galaxias
Project-X: The Micro Man
Micro Man II: The O Zone
Subsunk
Magic Castle
http://www.retrosoftware.co.uk/SGAP
Other
Insomnia - The Ice Man
Rainbow's End - D D Green
Quest For The Last Baked Bean - Unknown
The Four Wands - D W Gore
The Inca Treasure - D W Gore
The Sea Queen - Jonathon Oates
Dodgy Geezers - Trevor Lever and Peter Jones
Stranded on Iollfrak - Matthew O'Donnell
See also
http://solutionarchive.com/list/platfor ... ystem%2C3/
Re: List of Beeb/Elk Quill Adventures for Atom Porting
Postby oss003 » Sun Mar 02, 2014 11:14 am
Hi Dave,
I read that there are about 450 adventures written with The Quill for the ZX Spectrum. If the databases of the Spectrum and BBC versions are the same ....
http://www.worldofspectrum.org/infoseek ... id=0006857
Postby oss003 » Sun Mar 02, 2014 11:36 am
Hi Dave,
If you know the database format then you can find 149 textfiles to build a Quill database here: http://www.winpaw.com/Snapshots.htm#UnPaw
Postby hoglet » Sun Mar 02, 2014 12:11 pm
Kees,
The problem is the BBC/Electron port of Quill came later, and it's database format is sufficiently different that porting is hard. AndyF has done 5 or 6, but it seems like a lot of work.
That's why I'm planning to focus on ones that already exist for the BBC and Electron.
Postby oss003 » Sun Mar 02, 2014 12:21 pm
Hi Dave,
hoglet wrote:The problem is the BBC/Electron port of Quill came later, and it's database format is sufficiently different that porting is hard. AndyF has done 5 or 6, but it seems like a lot of work.
Is this also difficult for the textfiles at WINPAW?
Quill Database : seazirun.z80
Extracted by UNPAWS32 v2.0
General data
Locations                           84
Objects                             31
Conveyable objects                   5
Messages                            61
System messages                     32
Character sets                       0
Default ink color                    7
Default paper color                  1
Default flash state                  0
Default bright state                 0
Default inverse state                0
Default over state                   0
Default border color                 1
Database version                     A
Database not compressed
Snapshot type          Z80 48K Basic48
Vocabulary
N       1
NORT    1
S       2
SOUT    2
E       3
EAST    3
W       4
WEST    4
NE      5
NW      6
SE      7
I found the sourcefiles for VDU4024. Just assembler the sourcefile at address #xxxx and then *LOAD VDUDATA at #xxxx. All keys are working now, start VDU40 by pressing CTRL-4 and the ESCAPE.
VDU-SRC.zip
(3.08 KiB) Downloaded 66 times
Postby hoglet » Sun Mar 02, 2014 1:27 pm
Perfect! Do you prefer the lower case or the upper case version?
Postby oss003 » Sun Mar 02, 2014 3:23 pm
Hi Dave,
hoglet wrote:Perfect! Do you prefer the lower case or the upper case version?
The lower case version looks nice!! =D>
aerworuld
Postby aerworuld » Sun Mar 02, 2014 3:43 pm
^ nicely done sir! =D> I will upload the corrected .uef soon I you fancy making a permanent Atom version of TCCOTMV?
Users browsing this forum: RobertoCanessa and 0 guests
