Today I received.....
lcww1
Re: Today I received.....
Postby lcww1 » Sat Apr 14, 2018 11:56 am
AUN Manager’s Guide Iss. 2 Sept’ 1993
Scan to follow ........ :D
Postby 1024MAK » Sat Apr 14, 2018 12:26 pm
mattdy4 wrote:An "untested" BBC Model B Issue 2 with Sideways ROM (+RAM?) Board.
Nice 8) . If you want the contents of the EPROM chip with the uncovered window not to decay, it's best to cover the window with either a paper label or black insulation tape.
mattdy4 wrote:Also got an EEPROM programmer with it
Do you mean an EPROM programmer?
mattdy4
Postby mattdy4 » Sun Apr 15, 2018 6:54 pm
Yeah I noticed that. I'm guessing that whatever is/was on it wasn't that important to the previous owner
I had to Google to realise there is an actual difference. You learn something new every day!
Reason: Edited to remove excessive quote tags
Lardo Boffin
Postby Lardo Boffin » Mon Apr 16, 2018 9:18 pm
A very nice boxed issue 4 beeb with all the leaflets and original guarantee (and an Acorn cassette player)! Not fully tested yet but boots up fine and all keys work.
I now have a boxed beeb for each of my kids once they are old enough. They *will* get into retro computers!
Its not quite as yellow as it looks...
BBC Master
Postby 1024MAK » Tue Apr 17, 2018 1:02 pm
Today...
Another box of delights from Dave H :D
AP5 kit with nice case
Thanks Dave =D>
Postby daveejhitchins » Tue Apr 17, 2018 10:03 pm
1024MAK wrote:Another box of delights from Dave H :D
Glad it arrived intact.
I'll take this opportunity to raise a potential problem for AP5 kit units:
The 2 x 20 way connectors, for the User Ports, are new - old stock. I've noticed, when I've been building them, that the pins have become 'aged'. So I've been pre fluxing them and activating with my heat gun, before soldering. So I'm recommending something similar for kit builders. e.g. Check they're soldered correctly!
Thanks - Dave H :D
crj
Postby crj » Tue Apr 17, 2018 10:37 pm
mattdy4 wrote:
1024MAK wrote:If you want the contents of the EPROM chip with the uncovered window not to decay, it's best to cover the window with either a paper label or black insulation tape.
Actually, wouldn't an EPROM be OK in practice if it was inside a Beeb that was kept closed? I doubt much light would get in there!
Postby 1024MAK » Tue Apr 17, 2018 11:22 pm
Yes, if no, or very little light can get in, it does not matter. But it does depend on which case he has (different cases have different sized slots at the rear). And where it is kept. And this assumes the lid is fitted most of the time.
lcww1
Postby lcww1 » Wed Apr 18, 2018 6:04 pm
Fresh from OSHPark:
simoni’s Arch 2nd floppy pcbs
See this thread for details: http://stardot.org.uk/forums/viewtopic.php?f=16&t=14874
