Shark maps
Shark maps
Postby davidb » Tue Dec 21, 2010 1:54 am
Since the levels on the Electron version Firetrack are only really designed to stop the player from getting a clear shot at the pirates, I looked around for another game where editing the levels would have more of an effect on the gameplay. I've always liked Shark, so I went digging for the level data.
As with the Firetrack map information I uncovered, I'm really unlikely to do anything with this for the time being, so I've attached my notes here. Inspired by Cybershark's Hobgoblin level editor, I wanted to write a map editor to run on a real or emulated Electron, but I forgot how much I dislike 6502 machine code. ;-)
Maybe someone else will have more luck...
SharkMap.zip
Shark level data information
(941 Bytes) Downloaded 146 times
Cybershark
Re: Shark maps
Postby Cybershark » Tue Dec 21, 2010 11:08 am
Hahaha, thread title made me chuckle. I'm thinking "Yes, I do. What of it?" :lol:
But yeah, Shark was a really excellent game. Much more interesting than Green Beret! Although due to the manic - and totally random - enemy generation then the baddies were often so overwhelming you had to retreat a lot of the time!
However, in mapping terms then that random generation means level design would be very easy indeed 8)
davidb wrote:Inspired by Cybershark's Hobgoblin level editor, I wanted to write a map editor to run on a real or emulated Electron, but I forgot how much I dislike 6502 machine code. ;-)
Well, I wrote most of mine in BASIC. Not touched that for a day or two actually as there's still some enemy behaviour which I can't figure out - may be hardcoded. See above about mapping being easier when you don't have to worry about placing baddies :lol:
I'm very tempted to take a look into modding this!
Re: Shark maps
Postby davidb » Wed Dec 22, 2010 12:01 am
I thought I'd publish what I've managed to do so far. Here's the output of a simple Python tool to get the data out of the game's CODE file:
http://www.boddie.org.uk/david/Projects ... kMap/maps/
The Python script itself can be found here:
https://bitbucket.org/dboddie/sharkmap
There are also other bits and pieces, but nothing that really works very well. :)
Cybershark
Re: Shark maps
Postby Cybershark » Tue Jan 04, 2011 9:16 pm
Heh, I'd forgotten how small the levels actually are in Shark. It's all about the effort of progressing!
Nice level display routine there - I suspect this one may be easier to edit on an external platform as the game area does take up a much larger portion of the screen than does Hobgoblin. Also the sprite data is not as easy to use (for me at least).
Re: Shark maps
Postby davidb » Thu Jan 06, 2011 5:15 pm
I think it would be possible to do a simple level editor in BASIC and 6502 code, though with MoonMap I found it easier to have an external tool do the ASCII to map data conversion and regenerate a UEF file. With Shark, that's probably also possible because there aren't many kinds of map tile. Firetrack is a bit different - there are constraints on the way map data is encoded which would might make it quite easy to produce non-encodable levels.
Re: Shark maps
Postby davidb » Mon Jan 10, 2011 1:00 am
Well, I returned from holiday with the flu so, while off work, I thought I'd spend some time looking at the BASIC and 6502 code I'd already written.
If you want to play with this, you'll need to copy the CODE, LOADER and PATCH files from the Shark UEF file into the disc image. Then it should just be a matter of Shift-Break and off you go.
Keys:
Z X : / left, right, up, down
. , scroll level left, right
0-9 A-F set tile at the current position and set the current tile
Return set tile at the current position using the current tile
F1 F2 F3 select level 1, 2, 3
S save levels
L load levels
W wipe the current level
Have fun!
Editing the second level.
(8.35 KiB) Downloaded 839 times
shark-editor.ssd.zip
DFS image containing only the editor files.
(13.08 KiB) Downloaded 116 times
Cybershark
Re: Shark maps
Postby Cybershark » Wed Jan 12, 2011 12:26 am
Just had a little play with it and am rather impressed - although some of the structures you've created in your levels are very surreal!
Was having trouble finding the game files you mentioned ...until I remembered you'd said 'Electron'. Editor all works nicely but I guess I'm going to have to get myself an Elkulator now! That or merge the modified map data into the Beeb version :P
But yeah, very slick tool you have there. I love the speed of it and the way you can just switch between levels in the blink of an eye. Looks like you used the game code itself for the screen display? Nice touch, and it certainly saves time and memory!
Re: Shark maps
Postby davidb » Wed Jan 12, 2011 1:09 am
Cybershark wrote:Just had a little play with it and am rather impressed - although some of the structures you've created in your levels are very surreal!
I was in a rush to create them!
Cybershark wrote:Was having trouble finding the game files you mentioned ...until I remembered you'd said 'Electron'. Editor all works nicely but I guess I'm going to have to get myself an Elkulator now! That or merge the modified map data into the Beeb version :P
It looks like the BBC tape version stores the level data at the same offset into the SHARKMC file, so it should be possible to patch it in the same way as for the Electron version. The sprite data looks like it might be a bit different, though, so the editor won't display it properly. Of course, doing all this on an Electron (emulator) with PAGE at &E00 works just fine, but more messing about is required when using a BBC (emulator) with a higher PAGE.
The first level of the BBC version has some subtle differences to the Electron version, which I found mildly interesting.
Cybershark wrote:But yeah, very slick tool you have there. I love the speed of it and the way you can just switch between levels in the blink of an eye. Looks like you used the game code itself for the screen display? Nice touch, and it certainly saves time and memory!
Thanks! Actually, I wrote my own display routine, which was a nice way to remind myself why I never really got very far with 6502 back in the day. I think I probably won't feel the need to write 6502 code again for a while... :lol:
Re: Shark maps
Postby davidb » Thu Jan 13, 2011 12:56 am
I figured out the sprite format on the BBC version and modified the editor but the PAGE > &E00 on the BBC makes it impossible to use the editor. However, it is possible to use an Electron (emulator) to edit maps for use on the BBC. The attached disc image contains the modified editor, but no game files; you'll have to get those from the original disc.
Maybe someone with Beeb DFS mojo can do something to fix it up.
shark-editor-bbc.ssd.zip
Shark map editor for BBC maps - needs to be run on a PAGE &E00 DFS system.
(14.19 KiB) Downloaded 120 times
Cybershark
Re: Shark maps
Postby Cybershark » Wed Jan 26, 2011 12:28 am
I just used BeebEm in Master 128 mode :P
And thanks for making a BBC version too!
Cybershark wrote:The sprite data looks like it might be a bit different, though, so the editor won't display it properly.
Yeah, the Electron version has it all laid out quite plainly, now I see it. But that Beeb data just didn't seem to be in a friendly format to me.
Re: Shark maps
Postby davidb » Wed Jan 26, 2011 1:01 am
Cybershark wrote:I just used BeebEm in Master 128 mode :P
D'oh! I didn't think of that. Mind you, I don't have the Master ROMs for BeebEm, so maybe that's why. I hope you have fun with it!
Cybershark wrote:Yeah, the Electron version has it all laid out quite plainly, now I see it. But that Beeb data just didn't seem to be in a friendly format to me.
It appears to be stored in vertical strips, probably to make the scrolling routine simpler. I notice that the scrolling on the BBC version makes the game a lot harder in places.
