Mastering Interpreters and Compilers - book
Postby sydney » Sat Feb 03, 2018 10:47 am
Lardo Boffin bought Mastering Interpreters and Compilers by Bruce Smith but doesn't have time to scan it so posted it to me and I'm going to try to get it scanned. Unfortunately, even though I've owned a number of scanners over the years, I don't think I've ever used one!
I've been re-reading this thread but any advice would be great!
Re: Mastering Interpreters and Compilers - book
Postby sydney » Sat Feb 03, 2018 10:59 am
I'm using 'Not another PDF Scanner 2' software.
Here are the options screens:
Here is a test scan:
png:
tiff:
test1.tiff
test1.tiff (104.78 KiB) Viewed 360 times
Is the scan any good? What are the best settings? Should I use different software?
pau1ie
Postby pau1ie » Sat Feb 03, 2018 8:01 pm
Thanks to Lardo and you for doing this work.
Some characters are missing from the right side of the left page, maybe darkening it a little would help? But I would have thought that it would be possible to get the text out of the document as it is.
Edit - Should note that I don't really know anything about this!
Lardo Boffin
Postby Lardo Boffin » Sat Feb 03, 2018 9:02 pm
pau1ie wrote:Thanks to Lardo and you for doing this work.
All I did was walk to the post office! 8) All credit to Sydney.
BBC Master
Postby tricky » Sat Feb 03, 2018 9:04 pm
Thanks to both of you.
I've scanned and OCRed a couple about 10 years ago and that software would definitely have struggled with that, but hopefully things have improved in the meantime.
If it doesn't take too much longer, maybe try 600dpi and one notch less on the brightness.
b_b_c_m_i_c_r_o_2
Postby b_b_c_m_i_c_r_o_2 » Sat May 05, 2018 6:00 pm
Did you complete your scan of the whole book successfully?
If a pdf exists then I can get rid of my copy of the book.
Postby Elminster » Sat May 05, 2018 8:06 pm
I have that book, will take a while to scan and process as quite large.
If you are going to ocr it I would max out the dpi and then reduce file size, I.e. quality, post ocr.
Postby lurkio » Sat May 05, 2018 8:35 pm
What we did for another book might help: if you're scanning monochrome (black and white) text, and if you DON'T want high-resolution archive-quality scans, then use your scanner's "Text" setting (image bit-depth = 1). And 300 dpi. If there's too much "noise" in the scanned image, adjust the scanner's "Threshold" setting.
But if you're scanning in colour... you're on your own!
Postby Elminster » Sat May 05, 2018 9:00 pm
I think that was the book/thread Sydney was referring to in the very first post :)
Postby lurkio » Sat May 05, 2018 9:09 pm
Elminster wrote:I think that was the book/thread Sydney was referring to in the very first post :)
#-o #-o #-o
