Provisional STL DDFS 2.0 User Manual
These forums are for community collaboration on archiving, magazine scanning etc. to avoid work duplication and agree conventions / define standards
SimonSideburns
Postby SimonSideburns » Sat Aug 26, 2017 4:07 pm
I have painstakingly scanned in the above named document.
I have also manually typed it back in (which was always going to be quicker than trying to use OCR) along with most of the errors.
I'll leave it up to the viewer to correct anything found (if they wish).
I'm happy to attach both the PDF and TXT files.
Solidisk DDFS 2.0 Provisional Guide.txt
(32.73 KiB) Downloaded 21 times
STL DDFS 2.0 ROM - User Guide - (Provisional).pdf
PDF of scanned document
(5.21 MiB) Downloaded 17 times
Well, Imogen that!
Re: Provisional STL DDFS 2.0 User Manual
Postby flaxcottage » Sat Aug 26, 2017 5:37 pm
Thanks. I think I have one of these with a spare model B motherboard. The manual will come in very useful when I try to get the DDFS working. =D>
Currently running L4 Econet with BBC B, BBC B+ 128K, Master 128K, 4Mb A3000, 4Mb A3020, 4Mb A4000, 4Mb A5000 dual FDD; UK101; HP41CX setup; Psion 3a, 3mx and 5mx; Z88; TI-58c, TI-59 and printer, HP-16C programmer's calculator and a bakery of Pis.
Postby jgharston » Mon Aug 28, 2017 1:13 pm
SimonSideburns wrote:I have also manually typed it back in (...) along with most of the errors.
Argh. So.... want... to.... correct those errors. ;)
SimonSideburns
Postby SimonSideburns » Tue Aug 29, 2017 10:28 am
It would be so interesting to see what changed between this provisional manual and the actual one that was sent out. I touch type and had to make my fingers follow what was written as normally I would have corrected as I went along. I did spot several issues, even with the BASIC listings that had been provided.
Anyone have one?
Well, Imogen that!
Postby CMcDougall » Tue Aug 29, 2017 4:32 pm
maybe you could post pics of what you have, to trigger someone elses mind....
I have one (or2?) up loft at mo, but sure are just pink, like the ones on eBay at mo:
Return to “community projects”
