DOS Plus assisstance
marcusjambler
Postby marcusjambler » Sun Nov 12, 2017 4:32 pm
I've spent a bit of time using the DOS plus (2.1) environment and its working great.
Creating directories and copying files across from A: drive to run them from the C: drive on CF (datacentre) HD... All good.
I'm struggling to delete ANY files once created on either A: or C:
ERASE/ERAQ are not working they just flag ' file not erased'... DEL does the same.
Is there a specific command I'm not using?
From memory, in DOS 5.0 there was facility for changing ATTRibutes.
Is that the case with DOS Plus?
Re: DOS Plus assisstance
Postby RobC » Sun Nov 12, 2017 4:56 pm
ERASE filename
works for me.
marcusjambler
Postby marcusjambler » Sun Nov 12, 2017 5:03 pm
Thanks Rob... In that case I'm going to re-image the CF card.
That will probably sort it out.
marcusjambler
Postby marcusjambler » Sun Nov 12, 2017 6:35 pm
Hmmmm...
I've re-imaged the CF card in my Rertclinic Master.
DOS boots to 2.1 and ERASE is flagging ' file not erased : (filename) '
So I then booted my VideoNula Master with DOS 2.1 3.5" boot disks and that also comes up with the 'file not erased' report when trying to erase a file.
marcusjambler
Postby marcusjambler » Sun Nov 12, 2017 7:41 pm
Starting to get somewhere with this....
It turns out that the ERASE command works with internal PI copro tube connection and not with External tube connection.
Postby jgharston » Sun Nov 12, 2017 8:16 pm
marcusjambler wrote:Starting to get somewhere with this....
That is...... weird!
marcusjambler
Postby marcusjambler » Sat Nov 18, 2017 11:08 am
The issue has now evaporated :D
Not entirely sure why...
Return to “software: other”
Users browsing this forum: No registered users and 7 guests
