BeebAsm BASIC2 assembler O% equivalent?
Postby cmorley » Sun Oct 29, 2017 11:12 am
Reading through the wiki for beebasm I can't see how you set the equivalent of the BASIC 2 assembler's O%.
P% <= ORG
O% <= ??
I am building a ROM which has code which is copied to RAM before executing. In BASIC2 assembler I'd use P% = RAM address & O% = ROM address so all the jump addresses are correct & the assembled code ends up sequentially in the ROM.
How do you do this in BeebAsm?
Thanks,
Chris
Re: BeebAsm BASIC2 assembler O% equivalent?
Postby sweh » Sun Oct 29, 2017 12:38 pm
I would have that code in a separate file, compiled at the target address and then INCBIN it into the main code at the right place.
The "tips" section of the wiki page gives a hint on how this could all be done in one file (http://www.retrosoftware.co.uk/wiki/ind ... and_tricks). I've not tested but I expect the results of the first SAVE could be INCBIN'd later, and the labels defined in the first section will be available to the main code.
kieranhj
Postby kieranhj » Sun Oct 29, 2017 12:46 pm
I looked back at the relocdemo that comes with BeebAsm and it has the unsatisfactory solution of defining an OFFSET variable and then manually patching up any absolute address references. :-k
I bet this was on Rich’s to do list (and might even be a feature in one of the branches on GitHub - reminds me, again, we need to get these moved to an “official” StarDot repo.)
Postby cmorley » Sun Oct 29, 2017 12:54 pm
Ok thanks, I will try with INCBIN.
Postby sweh » Sun Oct 29, 2017 4:46 pm
So a "1 only" file kinda works, but it's messy. It requires some kludging
eg (no code moving done; just a proof of concept of INCBIN working)
$ cat foo.asm
ORG &120
.start120
JSR p1
RTS
.p1
LDA #65
JMP &FFEE
.end120
SAVE "part1",start120,end120
ORG &3000
.start3000
LDA #65
JSR &FFEE
RTS
INCBIN "part1"
.end3000
$ beebasm -i foo.asm
foo.asm:19: error: Error opening file.
INCBIN "part1"
$ touch part1
foo.asm:20: error: Fatal error: the second assembler pass has generated different code to the first.
.end3000
$ hdump real
00000000  A9 41 20 EE FF 60 20 24 01 60 A9 41 4C EE FF      .A ..` $.`.AL..
So it finally worked (and we can see the JSR matches) but the path wasn't clean!
Splitting it into two separate files worked
$ ls
part1.asm  part2.asm
$ beebasm -i part1.asm
$ beebasm -i part2.asm
$ hdump real
But you lose any variables you may have defined for the relocatable section
Postby cmorley » Mon Oct 30, 2017 7:09 pm
Yes, not pretty.
Postby Rich Talbot-Watkins » Mon Oct 30, 2017 8:00 pm
I added a COPYBLOCK command ages back (which is apparently in the 1.08 release, though not documented). The idea was that you could assemble a bit of code in its correct location, then use
COPYBLOCK start, end, destination_addr
to relocate it to the new address.
There may be problems to do with subsequently assembling code over the original addresses (though maybe CLEAR can help with that). I used it successfully at some point to create a BeebAsm assemblable Chuckie Egg, complete with relocation code.
Maybe that can do what you need?
Postby cmorley » Fri Nov 03, 2017 12:18 pm
Sorry didn't see your reply until now.
Yes COPYBLOCK would work I think.
e.g.
\RAM
ORG &<ram address>
.startram
[CODE]
RTS
.endram
\ROM
ORG &<rom address>
.startrom
[CODE]
\copy down to ram
LDX (endram-startram+1)
.copyloop
DEX
LDA romcopy,X
STA startram,X
BNE copuloop
JSR startram
[more CODE]
.romcopy
COPYBLOCK startram, endram, romcopy
.endrom
SAVE "rom", startrom, endrom
along these lines? I'll give it a whirl.
Postby Rich Talbot-Watkins » Fri Nov 03, 2017 2:58 pm
cmorley wrote:along these lines? I'll give it a whirl.
Yeah I think that was pretty much the idea. It doesn't advance ORG though, so your .endrom will be in the wrong place - you'll need a SKIPTO if you want to skip over the copied block (maybe it'd be useful to have a version which copies a block to the current ORG and advances it by the right amount too).
It's a bit clumsy though. I agree that having a way of being able to specify an address offset, like O%, would be a better solution. As ever with BeebAsm, I knocked it together with much haste and little thought at the moment that I needed it!
