Writing to Second Processor Memory from Sideways ROM
Postby BeebMaster » Sat Dec 17, 2016 5:52 pm
How do I store a byte in a location in the second processor RAM from a sideways ROM?
In my ROM image code, basically I have an "STA location" instruction. With the Tube off, it writes it in the I/O processor RAM, which is correct as I want it storing in the currently-in-use processor. But with the Tube on, it still writes it in the I/O processor instead of the second processor.
Re: Writing to Second Processor Memory from Sideways ROM
Postby jgharston » Sat Dec 17, 2016 6:22 pm
See the New Advanced User Guide p327 onwards or Acorn Application Note 4.
Claim the Tube
.TubeClaim
LDA #&C0+MyID ; recommend you use &3F for MyID
JSR &406:BCC TubeClaim
Initiate a data transfer
!block=CoProAddress
LDX #block AND 255 ; point XY to the block holding the 32-bit address in the second processor
LDY #block DIV 256
LDA #transfer ; 0=CoPro to Host, 1=Host to CoPro
JSR &406
Do the transfer
JSR TubeDelay ; Initial delay
JSR TubeDelay
For Host to CoPro transfers:
.TubeLoopSend
JSR TubeDelay
LDA source data ; data to send to CoPro
STA &FEE5 ; Send to CoPro
HaveIFinishedYet?
BNE TubeLoopSend
For CoProToHost transfers
.TubeLoopRecieve
JSR TubeDelay
LDA &FEE5 ; Get from CoPro
STA dest data ; Do something with the data
HaveIFinishedYet?
BNE TubeLoopRecieve
Release Tube:
LDA #&80+MyID ; same ID as when claiming
JSR &406
Subroutine for transfer delays:
.TubeDelay
JSR TubeDelay2
.TubeDelay2
RTS
Postby BeebMaster » Sat Dec 17, 2016 10:30 pm
Thanks very muchly for that, I've got it doing what it needs to be doing now - quite a faff to say I only wanted to transfer 6 bytes!!!
Postby jgharston » Sat Dec 17, 2016 11:20 pm
Normally the language processor is always in charge, so data is returned to the language processor in response to the language processor asking for it via the standard API.
Return to “programming”
Users browsing this forum: No registered users and 0 guests
