Wanted - A3000 IDE podule - CLOSED
wanted ads for hardware, software + literature (NOT for tape/disc image requests)
Forum rules
You're welcome to trade Acorn-related stuff with other forum members here - the rule of thumb to follow when trading, is that items or services offered should be of interest to our Acorn community. Do NOT use multiple accounts - please trade with your regular (and only) forum account. If you're giving items away, please make it clear if you would be unhappy with the recipient selling on some or all of the items. Similarly, please ensure that the giver is comfortable with you re-selling items you have accepted as a gift. We cannot be held responsible for what happens in these trading forums or for deals done via PM. This must be done at your own risk. If you aren't comfortable with this - make the trade via an alternative site which can apply safeguards of their own. Be sensible - if someone approaches you to trade via PM who is not posting in the public forums, this may be a sign that they are not entirely what they seem. Please report it to the moderators if you receive an unsolicited message from anyone suspicious, so that it can be investigated and hopefully stop anyone being taken advantage of.
trixster
Postby trixster » Mon Mar 20, 2017 9:15 pm
I'd like to buy an ide podule for my A3000. If anyone has one for sale then please let me know!
Kind regards,
Andy
trixster
Re: Wanted - A3000 IDE podule
Postby trixster » Fri May 12, 2017 8:35 am
Bump, still looking! Anyone!?
Postby Zarchos » Fri May 12, 2017 8:38 am
trixster wrote:Bump, still looking! Anyone!?
It depends.
Can you write 'The Archimedes was the best computer to own in the late 80ies and early 90ies ?'.
:twisted:
trixster
Postby trixster » Fri May 12, 2017 8:52 am
Postby danielj » Fri May 12, 2017 8:54 am
Okay, this is weird. :shock:
trixster
Postby trixster » Fri May 12, 2017 8:55 am
I'll do virtually anything for an IDE podule (within reason, with a few caveats) :oops: [-o<
Postby Zarchos » Fri May 12, 2017 9:01 am
trixster wrote:I'll do virtually anything for an IDE podule (within reason, with a few caveats) :oops: [-o<
OK.
Are you after one that can handle CF cards for sure and with the formatter, or you could handle this on your own ?
It can be time consuming ...
trixster
Postby trixster » Fri May 12, 2017 9:05 am
Ideally I'd like one that definitely works with either CF cards or with an IDE->SD adapter.
I have a working sd card in my A3020 so I would probably just make a disk image of that and then pop it into the A3000 - hopefully this would save the hassle of formatting and setting up the card.
Postby Zarchos » Fri May 12, 2017 9:10 am
trixster wrote:Ideally I'd like one that definitely works with either CF cards or with an IDE->SD adapter.
OK.
So give me some time checking what I've got available, and do some tests with the boards.
I'll ask about 100€ + shipping.
I think it's very reasonable, and that's because you're a *. member.
You could also check the BIN Archies on EBay and find yourself one with this minipodule.
Some people will say 100€ is expensive, knowing I grabbed some machines with IDE for this price, but hey, they should understand in the past I also spent some money on machines which are for the junkyard so except for a few parts, it was a net loss.
It's like trading on the stock markets : people tout their gains but rarely their losses.
:mrgreen:
trixster
Postby trixster » Fri May 12, 2017 9:26 am
Cool, that's fine by me, I've been looking for quite a while and the few that appear on eBay always seem to get snapped up quick when I'm not looking, and CJE charge the earth.
Let me know if you have something suitable and then I'll send you a PM.
Thanks!
Postby Zarchos » Fri May 12, 2017 9:30 am
trixster wrote:Cool, that's fine by me, I've been looking for quite a while and the few that appear on eBay always seem to get snapped up quick when I'm not looking, and CJE charge the earth.
Thanks!
Will do !
Give me a week max.
Postby Zarchos » Fri May 12, 2017 12:01 pm
Could you *. members confirm the castle IDE minipodule is the best suited for Trixster because it uses the Acorn ADFS 'system', thus Trixster could decide to simply remove the card he's got in his A3020, connect it to the Castle board, and it would work a treat.
(I know it's not what he intended to do).
Postby danielj » Fri May 12, 2017 12:09 pm
I think that means it'll have the same issues with CF cards as the A3020 does?
Postby Zarchos » Fri May 12, 2017 12:10 pm
danielj wrote:I think that means it'll have the same issues with CF cards as the A3020 does?
Yes.
But remember there's the whizzo rom he can softload from a diskette, 1st, and it solves most if not all issues ...
Postby danielj » Fri May 12, 2017 1:00 pm
Zarchos wrote:Yes.
But that sort of defeats the purpose of having a HDD! :D The bonus is it removes most reliance on floppies.
(for the record, I'm just getting the bits together to test a theory with the castle board!)
Postby Zarchos » Fri May 12, 2017 1:09 pm
danielj wrote:
Zarchos wrote:Yes.
I agree there'll be a delay to use your hd (about 5 seconds to load an ultra tiny file and ctrl break to reboot) ...
trixster
Postby trixster » Fri May 12, 2017 1:33 pm
The 2 chip sd card adapter works in the A3020 so maybe it'll work with the castle podule too?
Postby danielj » Fri May 12, 2017 1:36 pm
Should do - it's just if you want to run another one, those are hard to get. I can test that later if you'd like?
Postby Zarchos » Fri May 12, 2017 1:37 pm
trixster wrote:The 2 chip sd card adapter works in the A3020 so maybe it'll work with the castle podule too?
I believe so, but it's where I'd like to have confirmation from *., it uses the same chip found in the A3020 or A4000.
Or at list a subset of this multi I/O chip.(of course the IDE part).
Or it's only software (ie the filer) but I don't know RISC OS well enough.
When I ask stupid questions, it's always to go to sleep at night being a bit less an idiot .... :wink:
trixster
Postby trixster » Fri May 12, 2017 1:47 pm
Is the castle ide podule 44 pin or 40pin?
Postby Zarchos » Fri May 12, 2017 1:51 pm
trixster wrote:Is the castle ide podule 44 pin or 40pin?
It's for 2,5 '' hard drives, so that should be 40 ...
Postby danielj » Fri May 12, 2017 2:04 pm
It's 44pin - 40pin is 3.5" ide.
trixster
Postby trixster » Fri May 12, 2017 8:34 pm
Well I can't seem to find the 2 chip sd adapter anywhere online now.
So is it a lottery whether a cf adapter will work with a castle ide podule?
Postby danielj » Fri May 12, 2017 8:50 pm
No, the 2-chip ones are basically non-existent. I'm going to test mine with an SD-CF in a CF-IDE adapter, but the ebay seller sent me the wrong thing. If it works then there's a reasonable solution for the time being, both for the CastleIDE board and the A3020, using SD cards (which is frankly better than using CF cards which are becoming rather rarer in themselves). Watch this space.
The CF adapter will work, the lottery is the CF card. Most don't work AFAIK.
trixster
Postby trixster » Sat May 13, 2017 6:32 am
Cool, I actually have a cf-sd adapter so it'll be good to know if it works better than going through a cf-card lottery.
Postby Zarchos » Sat May 13, 2017 6:33 am
Don't forget the DOMs ... no adaptors needed, and they are cheap !
I've got one fitted in the external port of a Risc Developments IDE minipodule, and it works a treat ! (I soldered the 2 flying wires to the 'power' pins on the A3000 motherboard).
Why bother with CF/SD adaptors when you've got this cheap and efficient solution ?
http://www.ebay.co.uk/sch/i.html?_from= ... 5573.m1684
I'll run some tests this week to see how they behave with the various IDE minipodules I own, and standard chipset as found in the A3020 / A4000, I'll report in a new thread what works or not.
Of course I can provide a working DOM with the IDE minipodule I'll sell.
I've been wanting (proper English ? Not sure) to replace all my hard disk drives / CF or SD cards with adaptors by DOMs for a long time, so I'm going to do it at last.
trixster
Postby trixster » Tue May 16, 2017 7:37 pm
Thanks!
Will do !
Give me a week max.
Anything to report, old chap?
Postby Zarchos » Tue May 16, 2017 7:48 pm
Thanks!
Will do !
Give me a week max.
No.
Last week end I enjoyed baie de Somme and Berck's beach (and oysters + other seafood. Marvellous. With white wine).
Expect some news for this week end.
I need to find where my box of DOMs is ... not an easy task : which house ? Which floor ? Which room ? Which parcel / storage box / cupboard ?
Postby RobC » Tue May 16, 2017 9:23 pm
Zarchos wrote:Could you *. members confirm the castle IDE minipodule is the best suited for Trixster because it uses the Acorn ADFS 'system', thus Trixster could decide to simply remove the card he's got in his A3020, connect it to the Castle board, and it would work a treat.
I've got a Castle mini-podule in my A3000 but had trouble getting it to work with various CF cards. In the end, I got it working with a dual CF adapter and two Sandisk 256MB cards. For some reason, it won't work reliably with only one card installed but is rock solid with two!
trixster
Postby trixster » Tue May 16, 2017 9:25 pm
Return to “wanted”
