Wanted, uef BBC copy of Video's Revenge by Budgie
Re: Wanted, uef BBC copy of Video's Revenge by Budgie
Postby richardtoohey » Wed Dec 05, 2012 6:19 pm
Hi, Toby.
Pleased to hear from you! =D>
Cybershark
Postby Cybershark » Thu Dec 06, 2012 12:05 am
Always a joy to hear from the author of a classic :D
vanekp
Postby vanekp » Thu Apr 27, 2017 12:40 am
Here is a working copy of a uef for Video's Revenge, work on Beeb-Em Created from the wave file on this post.
videos_revenge.hq.rar
(14.58 KiB) Downloaded 21 times
Postby leenew » Thu Apr 27, 2017 9:32 am
Hi vanekp,
That UEF works thank you.
I have to run It In BeebEm at normal tape speed which is a *bit* of a shame.
That may be due to the protection scheme?
Thanks again.
Lee
vanekp
Postby vanekp » Thu Apr 27, 2017 12:14 pm
O I always leave the tape at the normal speed but to speed up loading I change the CPU speed to 1FPS loads fine in around 20 sec :D then set it back to normal after loading .
B.T.W. there is no copy protection in Video's Revenge the last two long blocks at the end of the tape are not even used and the screen file is loaded in with openin which is the file that wont let you load it at high speed.
vanekp
Postby vanekp » Thu Apr 27, 2017 2:59 pm
richardtoohey wrote:Right, not quite UEF, but hopefully you can use it (or someone can make a UEF version from this.)
This file DEFINITELY works - I have played it back to my BBC B from my laptop and the game loads fully & correctly. This is from the "Computer Hits 2" tape.
Raw format, 8 bit unsigned, 22050 Hz - on OpenBSD I play it back with ...
aucat -h raw -r 22050 -e u8 -i videos_revenge.raw
O and the wave file is not sampled at 22050Hz but 44100Hz as the tone sounded far too low when I was playing it.
Postby CMcDougall » Thu Apr 27, 2017 5:09 pm
http://www.stardot.org.uk/forums/viewto ... 023#p56929
Copied mine more like [-X
Lee pay attention :lol:
vanekp
Postby vanekp » Thu Apr 27, 2017 6:07 pm
I used the wav file in this chat from some time back a created it from there (log file to prove it) :-
MakeUEF V2.3.
Command line:
-i videos_revenge.csw -w 0 180 -z 99 8n1 -z 100 8n1
Date (D/M/Y) and time:
27/04/2017   02:28
Expected baud rate is 1223.
Gap written, length 1.00458 seconds.
Security waves written, length 1 waves, as follows:
S,
The security waves start with a pulse.
Carrier tone written, length 17892 waves.
Baud rate of the preceding data was 1225.232
The following block size is 284
Found :      VIDEO 00   Checksum ok
1 data blocks written.
Carrier tone written, length 2157 waves.
Baud rate of the preceding data was 1225.426
Found :      VIDEO 01   Checksum ok
2 data blocks written.
Carrier tone written, length 2156 waves.
Baud rate of the preceding data was 1225.174
Found :      VIDEO 02   Checksum ok, last block flag
3 data blocks written.
1 ordinary files written.
Carrier tone written, length 12731 waves.
Baud rate of the preceding data was 1224.686
Gap written, length 0.9798186 seconds.
Security waves written, length 24 waves, as follows:
S,S,S,L,L,S,S,L,S,S,L,S,S,L,L,S,S,L,S,S,L,S,S,L,
The security waves end with a wave.
Carrier tone written, length 12196 waves.
Baud rate of the preceding data was 1223.211
The following block size is 285
Found :     VIDEO1 00   Checksum ok
4 data blocks written.
Carrier tone written, length 2137 waves.
Baud rate of the preceding data was 1221.787
Found :     VIDEO1 01   Checksum ok, last block flag
5 data blocks written.
2 ordinary files written.
Carrier tone written, length 12710 waves.
Baud rate of the preceding data was 1223.781
Gap written, length 1.129524 seconds.
Security waves written, length 22 waves, as follows:
S,S,S,L,L,S,S,L,S,S,S,L,L,S,S,L,S,S,L,S,S,L,
Carrier tone written, length 12222 waves.
Baud rate of the preceding data was 1222.793
Found :      SPLIT 00   Checksum ok
6 data blocks written.
Baud rate of the preceding data was 1223.032
Found :      SPLIT 01   Checksum ok
7 data blocks written.
Baud rate of the preceding data was 1225.165
Found :      SPLIT 02   Checksum ok
8 data blocks written.
Baud rate of the preceding data was 1224.505
Found :      SPLIT 03   Checksum ok
9 data blocks written.
Baud rate of the preceding data was 1223.482
Found :      SPLIT 04   Checksum ok
10 data blocks written.
Baud rate of the preceding data was 1223.283
Found :      SPLIT 05   Checksum ok
11 data blocks written.
Baud rate of the preceding data was 1224.453
Found :      SPLIT 06   Checksum ok
12 data blocks written.
Baud rate of the preceding data was 1225.547
Found :      SPLIT 07   Checksum ok
13 data blocks written.
Baud rate of the preceding data was 1225.035
Found :      SPLIT 08   Checksum ok, last block flag
14 data blocks written.
3 ordinary files written.
Baud rate of the preceding data was 1224.077
Gap written, length 2.293741 seconds.
Security waves written, length 13 waves, as follows:
The security waves start with a wave.
Carrier tone written, length 12200 waves.
Baud rate of the preceding data was 1223.276
Found :      TITLE 00   Checksum ok
15 data blocks written.
Carrier tone written, length 475 waves.
S,
The security waves end with a pulse.
Baud rate of the preceding data was 1222.65
Gap written, length 0.007709751 seconds.
POSSIBLE DROPOUT - THE GAP IS LESS THAN 0.02 SECONDS.
Carrier tone written, length 1176 waves.
Baud rate of the preceding data was 1221.998
Found :      TITLE 01   Checksum ok
16 data blocks written.
Carrier tone written, length 476 waves.
S,
Baud rate of the preceding data was 1222.155
Gap written, length 0.007596372 seconds.
Baud rate of the preceding data was 1221.423
Found :      TITLE 02   Checksum ok
17 data blocks written.
S,
Baud rate of the preceding data was 1221.275
Gap written, length 0.007165533 seconds.
Baud rate of the preceding data was 1221.653
Found :      TITLE 03   Checksum ok
18 data blocks written.
S,
Baud rate of the preceding data was 1220.155
Gap written, length 0.007210884 seconds.
Baud rate of the preceding data was 1219.699
Found :      TITLE 04   Checksum ok
19 data blocks written.
S,
Baud rate of the preceding data was 1222.099
Gap written, length 0.007188209 seconds.
Baud rate of the preceding data was 1223.266
Found :      TITLE 05   Checksum ok
20 data blocks written.
S,
Baud rate of the preceding data was 1221.594
Baud rate of the preceding data was 1220.79
Found :      TITLE 06   Checksum ok
21 data blocks written.
S,
Baud rate of the preceding data was 1223.84
Baud rate of the preceding data was 1221.538
Found :      TITLE 07   Checksum ok
22 data blocks written.
S,
Baud rate of the preceding data was 1222.903
Gap written, length 0.006780045 seconds.
Baud rate of the preceding data was 1223.728
Found :      TITLE 08   Checksum ok
23 data blocks written.
S,
Baud rate of the preceding data was 1220.846
Baud rate of the preceding data was 1222.171
Found :      TITLE 09   Checksum ok
24 data blocks written.
S,
Baud rate of the preceding data was 1219.432
Baud rate of the preceding data was 1223.036
Found :      TITLE 0A   Checksum ok
25 data blocks written.
S,
Baud rate of the preceding data was 1220.902
Gap written, length 0.00675737 seconds.
Baud rate of the preceding data was 1221.192
Found :      TITLE 0B   Checksum ok
26 data blocks written.
S,
Baud rate of the preceding data was 1219.98
Baud rate of the preceding data was 1221.768
Found :      TITLE 0C   Checksum ok
27 data blocks written.
S,
Baud rate of the preceding data was 1218.458
Gap written, length 0.006689342 seconds.
Baud rate of the preceding data was 1221.02
Found :      TITLE 0D   Checksum ok
28 data blocks written.
S,
Baud rate of the preceding data was 1219.585
Gap written, length 0.006802721 seconds.
Baud rate of the preceding data was 1220.56
Found :      TITLE 0E   Checksum ok
29 data blocks written.
S,
Baud rate of the preceding data was 1218.369
Baud rate of the preceding data was 1214.956
Found :      TITLE 0F   Checksum ok
30 data blocks written.
S,
Baud rate of the preceding data was 1221.132
Gap written, length 0.006734694 seconds.
Baud rate of the preceding data was 1215.468
Found :      TITLE 10   Checksum ok
31 data blocks written.
S,
Baud rate of the preceding data was 1217.977
Baud rate of the preceding data was 1216.152
Found :      TITLE 11   Checksum ok
32 data blocks written.
S,
Baud rate of the preceding data was 1219.947
Gap written, length 0.00739229 seconds.
S,
Carrier tone written, length 1175 waves.
Baud rate of the preceding data was 1217.062
Found :      TITLE 12   Checksum ok
33 data blocks written.
S,
Baud rate of the preceding data was 1219.958
Found :      TITLE 13   Checksum ok
34 data blocks written.
Carrier tone written, length 477 waves.
Baud rate of the preceding data was 1221.605
Gap written, length 0.007346939 seconds.
Baud rate of the preceding data was 1221.823
Found :      TITLE 14   Checksum ok
35 data blocks written.
Gap written, length 0.007324263 seconds.
Baud rate of the preceding data was 1222.457
Found :      TITLE 15   Checksum ok
36 data blocks written.
Carrier tone written, length 478 waves.
Baud rate of the preceding data was 1220.672
Baud rate of the preceding data was 1224.479
Found :      TITLE 16   Checksum ok
37 data blocks written.
S,
Baud rate of the preceding data was 1220.353
Baud rate of the preceding data was 1222.286
Found :      TITLE 17   Checksum ok
38 data blocks written.
S,
Baud rate of the preceding data was 1221.968
Baud rate of the preceding data was 1221.365
Found :      TITLE 18   Checksum ok
39 data blocks written.
S,
Baud rate of the preceding data was 1221.319
Gap written, length 0.007256236 seconds.
Baud rate of the preceding data was 1218.438
Found :      TITLE 19   Checksum ok
40 data blocks written.
S,
Baud rate of the preceding data was 1221.572
Baud rate of the preceding data was 1219.47
Found :      TITLE 1A   Checksum ok
41 data blocks written.
S,
Baud rate of the preceding data was 1221.935
Baud rate of the preceding data was 1216.78
Found :      TITLE 1B   Checksum ok
42 data blocks written.
S,
Baud rate of the preceding data was 1221.363
Baud rate of the preceding data was 1216.666
Found :      TITLE 1C   Checksum ok
43 data blocks written.
S,
Baud rate of the preceding data was 1216.591
Baud rate of the preceding data was 1216.038
Found :      TITLE 1D   Checksum ok
44 data blocks written.
S,
Baud rate of the preceding data was 1218.063
Baud rate of the preceding data was 1219.068
Found :      TITLE 1E   Checksum ok
45 data blocks written.
S,
Baud rate of the preceding data was 1218.939
Baud rate of the preceding data was 1221.307
Found :      TITLE 1F   Checksum ok
46 data blocks written.
S,
Baud rate of the preceding data was 1219.684
Found :      TITLE 20   Checksum ok
47 data blocks written.
S,
Baud rate of the preceding data was 1219.059
Gap written, length 0.007142857 seconds.
Baud rate of the preceding data was 1222.113
Found :      TITLE 21   Checksum ok
48 data blocks written.
S,
Baud rate of the preceding data was 1218.874
Baud rate of the preceding data was 1220.675
Found :      TITLE 22   Checksum ok
49 data blocks written.
S,
Baud rate of the preceding data was 1219.596
Gap written, length 0.00723356 seconds.
Baud rate of the preceding data was 1217.466
Found :      TITLE 23   Checksum ok
50 data blocks written.
S,
Baud rate of the preceding data was 1221.561
Baud rate of the preceding data was 1219.183
Found :      TITLE 24   Checksum ok
51 data blocks written.
S,
Baud rate of the preceding data was 1219.191
Baud rate of the preceding data was 1215.696
The following block size is 283
Found :      TITLE 25   Checksum ok, last block flag
52 data blocks written.
4 ordinary files written.
Carrier tone written, length 12702 waves.
Baud rate of the preceding data was 1218.919
Gap written, length 2.288141 seconds.
Carrier tone written, length 12238 waves.
Baud rate of the preceding data was 1218.895
Found :      PART1 00   Checksum ok
53 data blocks written.
Baud rate of the preceding data was 1219.924
Found :      PART1 01   Checksum ok
54 data blocks written.
Baud rate of the preceding data was 1220.044
Found :      PART1 02   Checksum ok
55 data blocks written.
Baud rate of the preceding data was 1220.104
Found :      PART1 03   Checksum ok
56 data blocks written.
Baud rate of the preceding data was 1219.304
Found :      PART1 04   Checksum ok
57 data blocks written.
Baud rate of the preceding data was 1222.236
Found :      PART1 05   Checksum ok
58 data blocks written.
Baud rate of the preceding data was 1222.452
Found :      PART1 06   Checksum ok
59 data blocks written.
Baud rate of the preceding data was 1222.893
Found :      PART1 07   Checksum ok
60 data blocks written.
Baud rate of the preceding data was 1224.011
Found :      PART1 08   Checksum ok
61 data blocks written.
Baud rate of the preceding data was 1225.513
Found :      PART1 09   Checksum ok
62 data blocks written.
Baud rate of the preceding data was 1222.954
Found :      PART1 0A   Checksum ok
63 data blocks written.
Baud rate of the preceding data was 1225.46
Found :      PART1 0B   Checksum ok
64 data blocks written.
Baud rate of the preceding data was 1223.023
Found :      PART1 0C   Checksum ok
65 data blocks written.
Baud rate of the preceding data was 1222.651
Found :      PART1 0D   Checksum ok
66 data blocks written.
Baud rate of the preceding data was 1222.512
Found :      PART1 0E   Checksum ok
67 data blocks written.
Baud rate of the preceding data was 1224.184
Found :      PART1 0F   Checksum ok
68 data blocks written.
Baud rate of the preceding data was 1224.939
Found :      PART1 10   Checksum ok
69 data blocks written.
Baud rate of the preceding data was 1227.079
Found :      PART1 11   Checksum ok
70 data blocks written.
Baud rate of the preceding data was 1228.274
Found :      PART1 12   Checksum ok
71 data blocks written.
Baud rate of the preceding data was 1226.461
Found :      PART1 13   Checksum ok
72 data blocks written.
Baud rate of the preceding data was 1226.783
Found :      PART1 14   Checksum ok
73 data blocks written.
Baud rate of the preceding data was 1227.899
Found :      PART1 15   Checksum ok
74 data blocks written.
Baud rate of the preceding data was 1227.724
Found :      PART1 16   Checksum ok
75 data blocks written.
Baud rate of the preceding data was 1227.349
Found :      PART1 17   Checksum ok
76 data blocks written.
Baud rate of the preceding data was 1226.243
Found :      PART1 18   Checksum ok
77 data blocks written.
Baud rate of the preceding data was 1226.017
Found :      PART1 19   Checksum ok
78 data blocks written.
Baud rate of the preceding data was 1227.358
Found :      PART1 1A   Checksum ok
79 data blocks written.
Baud rate of the preceding data was 1227.132
Found :      PART1 1B   Checksum ok
80 data blocks written.
Baud rate of the preceding data was 1226.347
Found :      PART1 1C   Checksum ok
81 data blocks written.
Baud rate of the preceding data was 1225.208
The following block size is 92
Found :      PART1 1D   Checksum ok, last block flag
82 data blocks written.
5 ordinary files written.
Carrier tone written, length 12724 waves.
Baud rate of the preceding data was 1225.874
Gap written, length 1.576009 seconds.
Baud rate of the preceding data was 1223.801
Found :       INST 00   Checksum ok
83 data blocks written.
Carrier tone written, length 2129 waves.
Baud rate of the preceding data was 1224.389
Found :       INST 01   Checksum ok
84 data blocks written.
Baud rate of the preceding data was 1225.629
Found :       INST 02   Checksum ok
85 data blocks written.
Carrier tone written, length 2128 waves.
Baud rate of the preceding data was 1223.699
Found :       INST 03   Checksum ok, last block flag
86 data blocks written.
6 ordinary files written.
S,
Baud rate of the preceding data was 1224.296
Gap written, length 1.745805 seconds.
Carrier tone written, length 12232 waves.
Baud rate of the preceding data was 1225.55
Found :      PART2 00   Checksum ok
87 data blocks written.
Baud rate of the preceding data was 1225.556
Found :      PART2 01   Checksum ok
88 data blocks written.
Baud rate of the preceding data was 1225.096
Found :      PART2 02   Checksum ok
89 data blocks written.
Baud rate of the preceding data was 1224.826
Found :      PART2 03   Checksum ok
90 data blocks written.
Baud rate of the preceding data was 1222.807
Found :      PART2 04   Checksum ok
91 data blocks written.
Baud rate of the preceding data was 1219.174
Found :      PART2 05   Checksum ok
92 data blocks written.
Baud rate of the preceding data was 1221.433
Found :      PART2 06   Checksum ok
93 data blocks written.
Baud rate of the preceding data was 1221.26
Found :      PART2 07   Checksum ok
94 data blocks written.
Baud rate of the preceding data was 1220.57
Found :      PART2 08   Checksum ok, last block flag
95 data blocks written.
7 ordinary files written.
Carrier tone written, length 12730 waves.
Baud rate of the preceding data was 1219.923
Gap written, length 1.417846 seconds.
Security waves written, length 23 waves, as follows:
Carrier tone written, length 12208 waves.
Baud rate of the preceding data was 1220.601
Found :       PROT 00   Checksum ok
96 data blocks written.
Carrier tone written, length 2127 waves.
Baud rate of the preceding data was 1220.437
Found :       PROT 01   Checksum ok
97 data blocks written.
Baud rate of the preceding data was 1219.537
Found :       PROT 02   Checksum ok, last block flag
98 data blocks written.
8 ordinary files written.
S,
Baud rate of the preceding data was 1222.234
Gap written, length 1.975873 seconds.
Carrier tone written, length 3959 waves.
Baud rate of the preceding data was 1221.042
The following block size is 511
Data block written with a non-standard data format.
99 data blocks written.
Carrier tone written, length 3945 waves.
Baud rate of the preceding data was 1220.281
The following block size is 510
100 data blocks written.
Carrier tone written, length 16 waves.
S,
Baud rate of the preceding data was 1220.388
Gap written, length 0.07505669 seconds.
Security waves written, length 7 waves, as follows:
S,S,S,S,S,S,S,
Baud rate of the preceding data was 1204.412
Gap written, length 0.1503628 seconds.
Security waves written, length 9 waves, as follows:
S,S,S,S,L,L,S,L,L,
Baud rate of the preceding data was 1262.775
Gap written, length 0.1075057 seconds.
Note possibly hiss were written as readable waves.
Postby CMcDougall » Thu Apr 27, 2017 6:10 pm
4.4yrs too late, already done #-o
vanekp
Postby vanekp » Thu Apr 27, 2017 6:15 pm
did not see the uef posted here....
Postby CMcDougall » Thu Apr 27, 2017 6:18 pm
try looking in the link i posted 3 up, its in there :shock:
being :
http://www.stardot.org.uk/forums/downlo ... hp?id=5519 for DL
plus 4+yrs ago when this was done, it had links in the other thread with it :roll:
EDIT : instructions here: download/file.php?id=29929&mode=view
