elk Superior Collection 1 or 2 ?? SSD or ADF.
Postby CMcDougall » Thu Mar 30, 2017 9:14 pm
just looking at more electron compilations, & found Vol3, but does Vol1 or 2 exist on disc?? or just tape? :?
& could someone transfer Vol3 from ADF to SSD, as the ones marked (EL) wont copy /tfr (as *RUN only :evil: )
Ta 8)
SuperiorCollection3-ADFS_E.zip
ADFS F
(100.68 KiB) Downloaded 22 times
Re: elk Superior Collection 1 or 2 ?? SSD or ADF.
Postby danielj » Thu Mar 30, 2017 9:26 pm
Nope, only 3 for the elk. Strangely.
Postby davidb » Fri Mar 31, 2017 12:33 am
Some of the games on volumes 1 and 2 weren't released for the Electron. I imagine that, when they compiled a Collection for the Electron, Superior wanted to include the "best" games for that machine and so the ones on volume 3 overlapped with those on the other volumes out of necessity. There wouldn't have been much point in releasing it for the BBC Micro.
Postby CMcDougall » Mon Apr 03, 2017 7:20 pm
^seems that way, as no Collection3 for beeb.
here is 2 & 1 :
so on 1:
Syncron
Repton, Karate Combat
Star Striker, Airlift, BMX on the moon, Wallaby, Smash & grab
so on 2:
Kix
Repton2, Deathstar
Space Pilot, Missile Strike, Battle Tank, Crazy Painter, Overdrive
so on Electron 3 only (never on beeb):
cv3 scrn
Does anyone have a good way of getting rid of the 'Access violation' on ADFS (EL) files so can copy :twisted:
have tried everthing, even using a disc editor on sector 2&3 (being cat) & *ACCESS :0.$.REPTON ELR
but stilll no joy :x
Really only after the Repton three files, as must have a mover with them to get to &E00
would also like to check against the other files, to confirm no changes.....
Postby CMcDougall » Mon Apr 03, 2017 9:16 pm
done it!
1) make another blank ADFS disc
2) save dummy files to it with same filenames
3) use disc editor to note the hex of each letter of filename
4) using backup disc of original, edit the EL files so names in hex are same as dummy2
5) CTRL -BRK, *ADFS /*MOUNT 0
6) save off files to another disc :lol:
SuperiorCollection3ssd.zip
ssd
(99.02 KiB) Downloaded 27 times
geraldholdsworth
Postby geraldholdsworth » Mon Apr 03, 2017 9:20 pm
If you're using a disc editor, you could just reset the top bit of 5th character of the filename to clear the 'E' flag.
Full details of the format here:
www.mdfs.net/Docs/Comp/Disk/Format/ADFS
Gerald Holdsworth
Repton Resource Page
www.reptonresourcepage.co.uk
Postby CMcDougall » Mon Apr 03, 2017 9:27 pm
^that does not work
I read about it, as asked this before many moons before, best answer was from BillC :
"first two characters of [!B]OOT in the virtual catalogue, at &C405. I'm certain i read it somewhere, but it's easy enough to test which high bits are set to give the file it's attributes -
1ST [R]EADABLE
2ND [W]RITEABLE
3RD [L]OCKED
4TH [D]IRECTORY
5TH [E]XECUTABLE"
as it's not just the 5th char (still says"Access violation"), as most chars are actually something else......
Return to “archive requests”
