Barbarian 2 Disk Download Is Broken
Dave_E
Postby Dave_E » Sat Apr 11, 2015 7:38 am
When you complete a level on the version here at StH the game hangs with 'Bad program'.
billcarr2005
Re: Barbarian 2 Disk Download Is Broken
Postby billcarr2005 » Sat Apr 11, 2015 8:50 am
It appears it's a tape to disc transfer, from the file BARBARI. That also contains "BARBARIAN 2/E 1.00" - does that point to the Electron version?
Attached is an image with the files copied from the original BBC disk, then with DATA2 saved off from the loader.
Are you playing the game on a real machine, or via emulation? Which DFS are you using? It could be related to the same glitch that prevents further levels on Clogger, amongst others, from loading correctly.
BARBARIAN II.zip
Barbarian II
(37.03 KiB) Downloaded 49 times
Dave_E
Postby Dave_E » Sat Apr 11, 2015 9:27 am
I downloaded it from StH.
I was attempting to play it in BeebEm.
Dave_E
Acorn DFS
billcarr2005
Postby billcarr2005 » Sat Apr 11, 2015 11:18 am
Any change with the attached image, or still the crash?
Dave_E
Postby Dave_E » Sat Apr 11, 2015 12:26 pm
Heh heh, I have to play through level 1 again now, do I? :-) It was hair-pulling enough the first time around avoiding all those gaping pits...!
I'll have a go with it later this evening with the same configuration. :-)
billcarr2005
Postby billcarr2005 » Sat Apr 11, 2015 1:51 pm
The following, from Zentrix's Cheat It Again Joe 4 might be of some help :)
CHAIN"BRB2CHT" to load, then insert the game disk to continue.
BARBARIAN II CHEAT.zip
Barbarian II Cheat
(963 Bytes) Downloaded 42 times
Return to “archive issues”
