Fixing Hunchy!
Fixing Hunchy!
Postby leenew » Tue Dec 23, 2014 11:57 am
Hi there,
The game Hunchy on Michael Brown's disc collection Disc 069 is faulty.
If you miss the bell at the end of the screen then hunchy can walk through walls.
(Play it, you will see what I mean...).
This needs fixing.
I have found the original source for the game.
It was "Your Computer" March 1985.
Here is the listing:
And here is Mick's program:
HUNCHY.zip
(5.52 KiB) Downloaded 66 times
Also, at some point, Mick mentioned the game was running too fast, and he "altered the machine code" to slow it down.
Well, reading the article, the listing was for the Electron, and needed 2 variables altering on line 20 to slow it down for the beeb.
Armed with all these facts, can anyone make a good version? :D
Thanks,
Lee.
Michael Brown
Re: Fixing Hunchy!
Postby Michael Brown » Wed Dec 24, 2014 10:07 am
Hi Lee,
ref Hunchy!
The slowing down routine has already been sorted by me, although the correct disc may not have been re-archieved.
To slow the game down, change the figure at line 740 in hunchy2 in the .delay routine. LDY#180 to a higher figure such as 250.
To slow down the speed of the fall when killed, change the figure at line 970 in hunchy2 in the .delay2 routine. LDY#150 to a higher figure such as 250.
As for the walls fault, some careful reading and checking will need doing. The best way for this is for one person to read the text from the mag whilst another reads/checks against the code from the game otherwise I can see it taking a long long time unless something very simple and obvious pops up!
regards,
and happy xmas
Mick.
duikkie
Re: Fixing Hunchy!
Postby duikkie » Thu Dec 25, 2014 3:00 pm
so what is the problem #-o , ? a faulty printed version in the magazine or wrong typing from the magazine ??
maybe , at chrimas diner , i have to go to the attic , because of the nauty list thing again :cry:
else i will look at other time :mrgreen:
Re: Fixing Hunchy!
Postby roland » Thu Dec 25, 2014 4:36 pm
duikkie wrote: I'll maybe , at chrimas diner , i have to go to the attic
Do you also have your mother in law visiting you :lol:
256K + 6502 Inside
duikkie
Re: Fixing Hunchy!
Postby duikkie » Fri Dec 26, 2014 8:28 am
is there no better copy of the listing. i have found a few typo errors. but sometimes the listing can not be read.
if there are errors in the m/c code you get strange things :x
leenew wrote:Hi there,
This needs fixing.
HUNCHY.zip
Thanks,
Lee.
Michael Brown
Re: Fixing Hunchy!
Postby Michael Brown » Fri Dec 26, 2014 7:33 pm
Hi All,
happy xmas!
Good news!!!
Spent all day reading through the code and found several errors in the version on my disc.
I have made all the changes and the game now works.
firstly, changed the code at lines 20 and 1420 to make SP(1) and SP(2) 180 to start and then 160 later to speed the game up as per instructions.
secondly, changed the code at lines 740 and 970 in .delay and .delay2 to LDY#200 after running the original in ElectrEm to get as close to the correct speed as possible.
Also changed some wrong code at line 110 (?&D4A to ?&D54) to make the bonus score print on the screen instead of the random code.
lastly, to stop walking off the right of the screen the code at line 660 should be LDA&74 and not LDA&72.
regards,
Mick.
Disc069.zip
(137.21 KiB) Downloaded 67 times
Re: Fixing Hunchy!
Postby leenew » Sat Dec 27, 2014 11:57 am
Ho! Ho! Ho! good detective work Mick =D>
That's another problem off the list 8)
Ooh that reminds me... I will update the "problems list in the other thread"... after a turkey sandwich :wink:
Lee.
p.s. Sorry to Duikkie who must be disappointed not to be the one fixing this :cry:
duikkie
Re: Fixing Hunchy!
Postby duikkie » Sat Dec 27, 2014 12:41 pm
i can allways make a one file game out of this :)
i allso found errors but the listing was to poor to read
my eyes are not as they where when i was 18 years
leenew wrote:Ho! Ho! Ho! good detective work Mick =D>
Lee.
Michael Brown
Re: Fixing Hunchy!
Postby Michael Brown » Sun Dec 28, 2014 8:24 pm
Hi duikkie,
did you find any other errors other than the ones I found?
if there are more, then Hunchy will require further work.
I only checked for the bits I needed to make the game work as it should.
regards,
Mick.
duikkie
Re: Fixing Hunchy!
Postby duikkie » Tue Dec 30, 2014 12:18 pm
o jee , i have to look at the new download again.
line 10 , the escape fx was gone
L. 20 ??
L.30
L 110
L 560 ?
L. 570 ??
L. 830 ?
L. 880
L. 900
L.920
L. 970
L. 1120
L. 1400
1430
1450
1480
1590
what i did see i don't rember #-o
but i saw allso lots of missing ; by the printtab.
if the line numbers do not give you the answer , i will look and give what i could not see from the listing. ( which was bad for my eyes :wink: )
Michael Brown wrote:Hi duikkie,
regards,
Mick.
Michael Brown
Re: Fixing Hunchy!
Postby Michael Brown » Mon Jan 05, 2015 1:48 pm
Taken a look through the printout, but cannot make out some of the code (8s, Bs and Ds) look too close.
Is it possible that we could have a bigger and better scan of the pages so I can check properly that the code in the game matches the code on the pages.
regards,
Mick.
Re: Fixing Hunchy!
Postby leenew » Mon Jan 05, 2015 3:28 pm
That was the best scan I could find. If anyone has the original magazine (Your Computer March 1985) maybe we can do better?
Lee.
Re: Fixing Hunchy!
Postby richardtoohey » Sun Jan 11, 2015 3:17 am
=D>
Another one bites the dust ... I've been keeping half-an-eye out for this appearing on eBay - didn't twig that it was a magazine listing.
Jalov
Re: Fixing Hunchy!
Postby Jalov » Sun Jan 11, 2015 12:04 pm
leenew wrote:That was the best scan I could find. If anyone has the original magazine (Your Computer March 1985) maybe we can do better?
Lee.
It's in the download at Archive.org
Re: Fixing Hunchy!
Postby leenew » Sun Jan 11, 2015 12:24 pm
Excellent!
Are these better?
Lee.
Michael Brown
Re: Fixing Hunchy!
Postby Michael Brown » Sun Jan 11, 2015 1:42 pm
thanks Lee,
thant looks a lot better.
I will take a proper look through this at some point in the near future.
It is on my list of things to do and won't be forgotten!
Mick.
