It's Magic by Central Computing
Postby leenew » Thu Apr 11, 2013 7:43 pm
Just trying to test this game, but cannot get the game to work in Beebem.
It is UEF only in the STH archive.
In beeb mode I am typing *TAPE then PAGE=&E00, then *RUN
It does not work.
Any clues please? :D
Re: It's Magic by Central Computing
Postby CMcDougall » Thu Apr 11, 2013 7:51 pm
just had a go, and *RUN is needed for first file 'It's Magic' (get ldr scrn), but 2nd file 'Magic Pt1' stops at block 57 :?
just tried at normal tape speed, it loaded 2nd bit, but then the screen went to Mode0 and junk all over it :-s
bEm22 just gives junk still on mode7 after load finished.....
Pt2 (more magic) works, but needs a password 6 letter long, fail twice, it presses break :(
Postby CMcDougall » Thu Apr 11, 2013 8:45 pm
Here's pt1 on disc now, shift-brk to load, seems to work! :wink:
onto pt2 .....
ItsMagic-Pt1.zip
TAPE >DISC
(16.05 KiB) Downloaded 83 times
Postby leenew » Thu Apr 11, 2013 9:09 pm
Coolio!
What did ya do Col??
Postby CMcDougall » Thu Apr 11, 2013 9:18 pm
because the UEF had bad block when loaded fast, i thought maybe its an old version that made it, so FreeUEF to turn back to a .WAV file. Then done MakeUEFam to turn to a new .uef, but did not like, so converted to .RAW, it then liked it. Used bbctapedisc to turn into a .SSD, then renamed the files with (ADT Rom) *DEX 00 to edit *CAT to proper file names. tried */ main bit, and it came up \:D/ then done a *BUILD !boot */magic1, *opt 4 3, sorted. 8)
Postby leenew » Thu Apr 11, 2013 9:30 pm
just what I would have done :lol:
Postby CMcDougall » Thu Apr 11, 2013 9:40 pm
=D> ........ :lol:
next one works also, had to edit the filename in the 'Loaders', and the password is 'wotcha'
shft-brk to load :wink:
ItsMagic-Pt2.zip
tape >disc
(16.1 KiB) Downloaded 81 times
Postby leenew » Thu Apr 11, 2013 10:20 pm
That's good work Col =D>
However :D
Street patroller by Central doesn't work either :lol:
notice the corrupted text and garbled messages :shock:
No rush 8)
Postby CMcDougall » Fri Apr 12, 2013 4:42 pm
which one Lee?, as got StreetPatroller & StreetPatrollerRemix too.
They are on disc as well, so I take it no worky :?
http://www.stairwaytohell.com/filesearc ... rch=Search
Postby leenew » Fri Apr 12, 2013 5:03 pm
It was the UEF's that were giving me trouble, but seeing as they are on SSD then in doesn't really matter! :lol:
Return to “archive issues”
