B-Em fault with Galaxy Raiders???
Michael Brown
Postby Michael Brown » Thu Feb 16, 2012 7:27 pm
Not sure if it is a fault but Galaxy Raiders by Visions hangs when loaded from the uef tape image on B-Em.
I may have mentioned this before in a different thread.
I have taken a look at my disk image from my Games Disk 8 which used elements from the uef tape image in the STH and this version works on BeebEm but not B-Em just like the tape image.
I find it very strange as B-Em is more close to a real beeb than BeebEm yet B-Em hangs the tape image. I have not had access to a real BBC to check if the tape image works fine or not, so therefore cannot tell if the problem is with the image or B-Em.
One thing I can now tell you is that I have got Galaxy Raiders to work on B-Em by altering the code at &1A30 (or &2A30 fro disk) which does a LDA #&80 to a LDA #&15.
I am not sure what basically a *FX 128,1 does but by changing it to *FX 15,1 the game now works fine and I have tested it this afternoon and have had no problems.
Therefore here is a special B-Em version of my Games Disk 8 with the change.
BBC Arcade Games Disc 008bem.zip
(133.42 KiB) Downloaded 113 times
I know a few people don't like the games being hacked, but this is currently the only way this game will work on the B-Em emulator.
If anyone can check the tape image on a real BBC and let me know then that would be great otherwise I wonder if Tom Walker has any ideas why B-Em does not like that code or maybe it is the BEQ routine after it.
regards,
Mick.
Re: B-Em fault with Galaxy Raiders???
Postby MartinB » Thu Feb 16, 2012 8:51 pm
Works fine when loaded via UPCFS (~6s) :D
firthmj
Postby firthmj » Thu Feb 16, 2012 8:57 pm
According to the BeebWiki, OSBYTE &80,1 should read the first A/D channel - the equivalent of ADVAL 1.
Presumably if you've changed A to &15, that's actually the equivalent of OSBYTE 21, not OSBYTE 15?
If so, you've basically changed it to a call to flush the serial input buffer
I guess a quick test would be to compare the ADVAL behaviour of B-Em, BeebEm and a real Beeb.
Regards
Michael
Had fun at the
Meeting 13th May 2017
SarahWalker
Postby SarahWalker » Thu Feb 16, 2012 9:01 pm
It's waiting for ADC channel 1 (joystick 1 X) low byte to go non-zero. No idea why. The existing emulation has the default midpoint being $8000 so this obviously doesn't happen.
Temporary solution - if you have a joystick plugged in, move it left-right a bit.
Michael Brown
Postby Michael Brown » Wed Mar 14, 2012 4:28 pm
It looks like this was the only game that did this. It does seem strange as to why it does this at the start.
