New version of Astro Blaster (was: I'm currently working on a version of AstroBlaster)
sirmorris
Re: I'm currently working on a version of AstroBlaster
Postby sirmorris » Wed May 18, 2016 9:20 pm
A bit late to the party ... but what can I say. :shock:
Stunning work there. AB is one of my all-time favourites. You have done it proud. Thank you.
Also My TMS was relieved at having something other than 'Call me Kenneth' Kendall to work with :lol:
Postby tricky » Wed May 18, 2016 10:37 pm
Thanks, i really should add the docking bit for swram beebs, but i quite like the choice of more time or cooler laser that the fireball storm offers, that and I'ma bit lazy :lol:
Postby tricky » Mon Jun 13, 2016 7:16 pm
I have found what I think is the cause of AstroBlaster not working on machines without sideways RAM (or 1 bank and no speech chip).
This should also add sampled speech back to anyone with Watford Electronics Shadow RAM who had it with the original version.
It looks like I have a typo, which is wrongly identifying WE Shadow RAM.
The fix is to change line 275 of LOADSWR from IF W% = 255... to IF W% <> 255...
New .ssd attached with fix, please let me know if this has any issues for anyone.
Michael Brown,
sorry for changing the files again!
Mark (Retro Clinic),
Sorry for doubting you or your excellent DataCentre.
AstroBlaster should work on any BBC Model B, B+, Master or Compact (only tested in emulation).
For the best experience, use RGB to SCART on a CRT (extra smooth) with a speech enable beeb with sideways RAM.
If there is a Speech chip and at least one bank of SidewaysRAM, you will have full speech (even without Kenneth Kendall).
If there is no speech chip, Up to two banks of SidewaysRAM or WE Shadow RAM will be used for sampled speech.
AstroBlasterWEFix.zip
Fix for wrongly identifying WE Shadow RAM
(40.98 KiB) Downloaded 36 times
Michael Brown
Postby Michael Brown » Tue Jun 14, 2016 9:40 am
Hi Tricky,
Just loaded the version of AstroBlaster into my Beeb (with Datacentre).
The game now works fine - It does not display any text at the bottom (as it is not loading any RAMs) and plays the game simply without the in game speech.
Works the same under both emulators as well!
Well done.
Is this now the final version and what are you going to create for us next?
regards,
Mick.
Postby tricky » Tue Jun 14, 2016 12:38 pm
It is the final version unless i get inspired to add the docking level, but that would be quite a bit of work for not much Bang. If i did, i would add the mystery bonuses which are also missing.
I did start a thread asking what next, but have got distracted with rally-x, SelfTestOS and Phoenix.
Michael Brown
Postby Michael Brown » Tue Jun 14, 2016 3:31 pm
Hi Tricky,
Any chance you could finish your excellent version of Phoenix?
regards,
Mick.
Postby tricky » Tue Jun 14, 2016 6:50 pm
By way of an apology for causing you to have to update your AstroBlaster disc, I will post an updated WiP.
Postby tricky » Thu Jul 14, 2016 6:08 pm
Sorry again everyone, well pau1ie spotted a bug with Master and Master Compact joystick support.
Here is a new version, only $.game should have changed and it should only affect Master and Master Compact joystick support.
If anyone with a Master and or Compact could check and report back, that would be great.
Master Compact WARP is down on the joystick!
AstroBlaster-MasterJoyFix.zip
fix for Master and Compact joystick support
(41.57 KiB) Downloaded 27 times
pau1ie
Postby pau1ie » Fri Jul 15, 2016 12:05 pm
Hi Tricky
tricky wrote:If anyone with a Master and or Compact could check and report back, that would be great.
It works, except that now the joystick button is warp rather than fire. My joystick is the BBC one and only has a single button - bottom picture on this page:
http://wouter.bbcmicro.net/pictures/hardware/bbc_joysticks/index.html
Still works well with the keyboard though.
Edit - Forgot to say, this is a Master 128 with datacentre.
PaulH
Postby tricky » Fri Jul 15, 2016 2:51 pm
I'll have to have another look, does down on the stick fire?
pau1ie
Postby pau1ie » Fri Jul 15, 2016 3:04 pm
tricky wrote:does down on the stick fire?
No.so far as I can see up and down don't do anything.
Postby tricky » Fri Jul 15, 2016 6:28 pm
Sorry, confused myself, down is as I said before, compact only.
Maybe I am missing something important about the master joystick, I'll have to check,
For some reason, I was only supporting a single button, but I thought that that was because I copied the code from Carnival, which, only uses one button.
Does the fire button on the other joystick do anything?
Postby 1024MAK » Fri Jul 15, 2016 7:41 pm
Err, the only differences between a Master 128 and a BBC B is some of the addresses are different (if you are directly accessing the hardware).
The Master Compact of course does not have an analogue port (no A>D converter chip), so just has digital inputs via the user VIA 6522 port B (FE60-FE7F).
FEC0-DF Analogue-to-digital converter (B/B+)
FEC0 Start conversion                   Status
FEC1                                    Data high byte
FEC2                                    Data low byte
FEC3 -                                  -
FE18-1F Analogue-to-Digital converter (Master)
FE18 Start conversion                   Status
FE19                                    Data high byte
FE1A                                    Data low byte
FE1B -                                  -
Master Compact Joystick
Pin VIA  Function
 1  PB3  Up
 2  PB2  Down
 3  PB1  Left
 4  PB4  Right
 5  CB1
 6  PB0  Fire 1
 7  +5V  Used with some auto-fire joysticks
 8  0V   Ground / common
 9  CB2  Fire 2 (if used)
pau1ie
Postby pau1ie » Fri Jul 15, 2016 11:05 pm
tricky wrote:Does the fire button on the other joystick do anything?
No, it has no effect.
I am pretty sure fire used to fire on the previous version where the ship shot off to the right. Also, of course, I have to press fire to start the game.
Postby tricky » Sat Jul 16, 2016 7:31 am
[quote="pau1ie]I am pretty sure fire used to fire on the previous version where the ship shot off to the right. Also, of course, I have to press fire to start the game.[/quote]that is what i don't get, the fire button code hasn't changed, only the movement code, which just used a different address for the adc.
Mark, thanks, I don't think i knew about the second fire button on the compact. I will change the loader so that starting with fire2 on the compact disabled down for warp - if i ever get the rest correct!
I think the best thing i can do is probably write a little joystick checking program and ask people to try it for me. Maybe Dave could lend me a working master and compact, out maybe it will make a practicallittle project for abug south.
Paulie, one last thing, does fire work ok on carnival?
Postby 1024MAK » Sat Jul 16, 2016 9:46 am
To help prevent confusion (Whoops! Too late :oops: )
There are various differences with so called "Atari" standard joysticks. I listed the functions that are listed as per the Atari ST pin-out where one possible second fire button may be used on some joysticks. It does not mean that all joysticks have a second fire button mapped to that pin (pin 9).
Further, I don't know if any Master Compact software actually uses a second fire button. Reading CB2 is done rather differently to reading one of the PB inputs.
Sorry if I confused matters :oops:
Postby tricky » Sat Jul 16, 2016 11:36 am
OK, I've written a test program for B, B+, Master and Compact (probably A to with ADC, but OS 0.1 would need a couple of tweaks).
Attached is a .zip containing a DFS, ADFS and TAPE image of the test program OSJOY.
There is a bit more about it here http://www.retrosoftware.co.uk/forum/viewtopic.php?f=73&t=1013&p=7746#p7746.
I would appreciate it if anyone could try it on a Master and Compact as I don't have them.
Sarah, any chance of supporting two fire buttons in B-em? if not, I'll take a look later.
If anyone has anything a bit exotic (basically, not just a model B) I would appreciate knowing if the machine identification works correctly and whether left/right and the two fire buttons report correctly on all platforms.
osjoy.zip
identify OS and ready joystick
(45.34 KiB) Downloaded 30 times
Postby 1024MAK » Sat Jul 16, 2016 11:50 am
I have a BBC B, a Master 128, and a Master Compact (all working). I do have a B+, but it is currently not operational :(
If I have time this weekend, I will try your test program. If I do, I will of course post up the results.
pau1ie
Postby pau1ie » Sat Jul 16, 2016 10:36 pm
On my master I see on one of the joystics (Which are not labelled by the way) it says fire left. This one says right, left, centre etc. The fire button on the other joystick says fire right.
OS says 3.x Master. I have a retroclinic dualos fitted at the latest version (3.5?)
I think it is good.
Postby tricky » Sun Jul 17, 2016 7:06 am
Thanks, that is working correctly then.
I don't know why i called them left and right.
The "left" fire button should go with the stick which says left, centre (left), centre (right) and right. This should be fire in AstroBlaster, while the fire button which says "right" should be warp.
I'll go and check the AstroBlaster code again.
I would still appreciate anyone checking the compact, if possible with a one and two button stick.
PS, would it be possible to check the master in beeb mode and reportb back what it thinks the beeb is and if the stick still works, I'm guessing it won't work, but it may.
Postby tricky » Sun Jul 17, 2016 2:57 pm
Found a silly bug in the Master code, so here should be the Master fixed version, only $.game changed.
Compact still uses up or down (can't remember for WARP)
Master 2 button joystick fix
(41.57 KiB) Downloaded 50 times
pau1ie
Postby pau1ie » Tue Jul 19, 2016 12:37 pm
The game works perfectly, brilliant.
The dualos only allows me to switch between 3.2 and 3.5, and I haven't fitted the switch, so I am stuck on 3.5, but I don't have a model B mode to try.
PaulH
Re: New version of Astro Blaster (was: I'm currently working on a version of AstroBlaster)
Postby tricky » Sat Dec 16, 2017 9:21 pm
I've been tinkering with AstroBlaster as the first of my games to get a small update.
Not in game play, but in accessibility and in AstroBlaster's case making it a little more disk friendly.
I have reduced the number of files on the disc and compressed some of them to save space and load more quickly.
I have also made the joystick code "auto enabling", so pressing the fire button enables the joystick, allowing keyboard and joystick to be used together or swapped seamlessly.
I have also made the files ROM compatible so that they can be burnt as ROMs.
The game file ASTROBL is the main game and if it is in SLOT 0 (back cartridge slot on a Master/expansion port on a compact - I think) will boot at start-up. *ASTROBL at the prompt.
ASTROs1 is the "To battle stations" and "game over" samples. Test with *ASTROS1
ASTROs2 is the "Out of fuel" and "Warp activated" samples. Test with *ASTROS2
ASTROsp is the speech chip data for all of the in-game speech. No test.
The .ROM files in the .zip are identical to the files in the .ssd, but I thought they would be slightly easier to test.
I have tested them on my versions of b-em and beebem, but not on any real hardware, so please report any issues.
If you add the ROMs, and use the beeb before *ASTROBL, it might need a BREAK as each ROM writes to &7x, which is then detected by ASTROBL - I know this is not right, but is probably harmless (I hope).
I was thinking that ASTROBL + ASTROsp would be good for a beeb with speech chip or ASTROBL + ASTROs1 for a master/compact cartridge (Arcadian).
Mode7toBASIC is a BBC BASIC program I wrote to convert the MODE 7 loading screen into BBC BASIC, it might not be very useful, but as I had written it, I thought I would include it.
The code I use for detecting WE SHADOW RAM (the ROM actually), the code for finding sideways RAM banks and the code for uploading to SWRAM is all in BBC BASIC ASM as part of LOADER in case anyone is interested.
EDIT The sample for "To battle stations" seems a little odd on HW, so that probably needs looking at!
Mode7toBASIC.zip
(536 Bytes) Downloaded 12 times
AstroBlasting.zip
(73.3 KiB) Downloaded 20 times
Postby tricky » Mon Jan 01, 2018 1:25 pm
Fixed the broken samples, the ROM versions shouldn't have been affected as it was the length passed to the code that copies the ROMs into SWR.
I've also made it so that the samples on the loading screen can be skipped if you start in the first 10 seconds and reduced the attract repeats to once per minute.
I haven't extracted the ASTROs1, ASTROs2 and ASTROBL files, but they can be extracted and put on EPROM as before.
Game play should be unaffected and should still work on B, B+, Master and Compact with keyboard and/or joystick.
WARP is up or down on compact - I can't remember witch!
Let me know here if there are any issues I have missed.
ssd_titler is a small windows exe with source for setting the title on a .ssd file and resetting the accesses to 0.
It isn't clever, it just overwrites the first 8 bytes and the 5 bytes at &100, 12 bytes for title + writes counter, so anything other than a simple .ssd will probably get corrupted!
Usage: ssd_titler disc_image.ssd Title
ssd_titler.zip
(3.77 KiB) Downloaded 12 times
AstroBlaster.zip
(46.12 KiB) Downloaded 23 times
Postby tricky » Mon Jan 29, 2018 9:45 pm
Just got this message, I don't know which of the versions above were used, but the last one is the "oficial" version.
Hi again,
I was finally able to burn Astroblaster and Frogger to a 27256 EPROM. Seems to work great. Next I'll try Phoenix and one other (Space Invaders maybe).
I don't think I have done space invaders, but I thought I had done Carnival, but I can't find it!
