Procedural greneration
Postby sydney » Tue Aug 29, 2017 4:22 pm
I'm playing around with the possibility of writing a 'Roguelike' and the procedural generation of the levels.
I'm starting with a seed value of two bytes and use the first byte to set a variable then add the two bytes, replace the first byte with the second and store the sum in the second byte's space as follows:
.increment_seed
   lda temp_seed
   sta temp
   lda temp_seed+1
   sta temp_seed
   clc
   adc temp
   sta temp_seed+1
rts
This will give me a repeatable sequence of values to set the attributes of the rooms, paths, monsters etc
Each level has 9 spaces for rooms and I'd like there to be a 75% chance of a room being present so one of the attributes is 'exists'. What is a good way of deciding how to implement this? At first I was simply going to use values over 64 means the room exists and below means it does not but was worried that two low (0 and 1) could create a lot of non-existant rooms.
If I were to AND the seed with 00000011 would this give me 0 25% of the time? I think it would but I've had the kids running round screaming all day and my brain seems to have stopped functioning properly.
Re: Procedural greneration
Postby tricky » Tue Aug 29, 2017 4:44 pm
And %00000011 would be zero 25%, non-zero 75%.
You would have to be slightly careful about your seeds, e.g. 0,0 would be a little dull.
I posted a similar routine on RS for "random" numbers, it actually just generates a sequence of 256 numbers before repeating.
For rough random chances, I usually AND with something, where each bit set halves the chance of getting 0; I try to avoid the bits that I am using for something related. e.g. n = rand; if (n & %00000011) PRINT TAB(n, rand) as it will only print in every fourth column.
Rich Talbot-Watkins
Postby Rich Talbot-Watkins » Tue Aug 29, 2017 5:05 pm
And there are some more random number generators on this page if you need a larger seed size, or you're just finding your results to be not random enough!
http://codebase64.org/doku.php?id=base:6502_6510_maths
Postby sydney » Tue Aug 29, 2017 9:07 pm
Thanks guys.
I'm going to try to tire the kids out tomorrow morning so I can get some peace and quiet in the afternoon and get some coding done.
Return to “programming”
