modes and plot codes
richmond62
Postby richmond62 » Sun May 14, 2017 7:34 am
I am trying to plot a simple SINE curve in BBC BASIC (no, I'm not so moronic
that I cannot work out the code for that), and do NOT want the end result to
look like the blips on a Geiger counter, but a solid line.
I have been wading (knee deep) through the MODEs and
the endless PLOT display codes with no result.
This, for instance, yielding nothing but a moving dot:
55 MODE 4
60 PLOT 69,CA,SA
I would be most grateful for some advice.
dp11
Re: modes and plot codes
Postby dp11 » Sun May 14, 2017 7:50 am
Post your full code please.
I suspect your mode 4 command should be once at the top of your code and not in the loop.
richmond62
Postby richmond62 » Sun May 14, 2017 8:51 am
Postby jgharston » Sun May 14, 2017 9:04 am
richmond62 wrote:Screen Shot 2017-05-14 at 11.50.40 am.png
Yes, that's gonig to clear the screen every time you go around the loop.
PLOT action codes
Postby flaxcottage » Sun May 14, 2017 9:06 am
Yep, make line 10 MODE4 and delete line 60.
This will produce a curve using dots.
To get a curve using very short straight lines use the following code;
Changing the value in V will alter the amplitude.
I'll be at ...
richmond62
Postby richmond62 » Sun May 14, 2017 9:12 am
Thank you very much for your help.
I switched SA and CA round as the thing looked bl**dy silly the other way :wink:
Postby danielj » Sun May 14, 2017 9:13 am
You can also ditch the CLS and CLG and the LET keyword if you like :) it'll still work fine.
richmond62
Postby richmond62 » Sun May 14, 2017 9:17 am
I'll ditch the LET on my BBC Master, but I'm not entirely sure if ALL BBC BASIC allows one to drop the LET statement,
and Richard Bannister's HORIZON does NOT emulate a Compact.
I learnt BASIC 4 initially (Hollerith cards in the post to Imperial College), and then something called DBAS 9
on a Research Machine; hence the slightly backward-looking LET statements.
The CLS and the CLG are neither here nor there, just something ingrained from the murky past (1976).
Postby danielj » Sun May 14, 2017 9:32 am
Even v1 doesn't require LET :)
richmond62
Postby richmond62 » Sun May 14, 2017 9:40 am
So why did "Bonehead" Barker, our Maths teacher and the man who turned me onto computer programming, make a BIG thing about LET statements?
Postby danielj » Sun May 14, 2017 9:54 am
Probably because he didn't know what he was on about :D
Postby jgharston » Sun May 14, 2017 10:14 am
richmond62 wrote:I'll ditch the LET on my BBC Master, but I'm not entirely sure if ALL BBC BASIC allows one to drop the LET statement
ALL BBC BASICs omit LET, it's in the specification.
richmond62
Postby richmond62 » Sun May 14, 2017 10:37 am
Or, maybe because he was NOT teaching us BBC BASIC :)
This is a bit creepy: http://teachersinstitute.yale.edu/curri ... .09.x.html
Postby BeebMaster » Sun May 14, 2017 7:52 pm
Also in BBC BASIC in a FOR...NEXT loop you can omit the variable in the NEXT statement (unless you have nested loops and need to distinguish between two or more) - so you can change line 80 to just "NEXT".
