RS Basic Sprite plotter example code
Postby sydney » Wed Jan 25, 2017 11:49 am
This example code is what I used in my beebout game and I'm going to adapt it a bit to use in my Combat game. I thought it was worth posting here as it's a good way for novice programmers to get started.
The code given at RS is in a format suitable for use with the Swift ide and P65 Ophis assembler which I never got on with and I use Beebasm and Notepad++ so I set about adjusting the code so that it assembles with beebasm.
I'm going to make some further adjustments so that it works with a 256 pixel (64 byte) wide screen, which should be quite easy, and I'll post that code here too.
Edit: added sprite256.zip which plots sprites on a 64 byte wide screen
Edit 2:This code is not written by me but by SteveO and was posted in the sample code section of RetroSoftware.
sprite256.zip
(8.87 KiB) Downloaded 37 times
sprite.zip
(8.19 KiB) Downloaded 29 times
Re: RS Basic Sprite plotter example code
Postby FourthStone » Tue Feb 07, 2017 9:29 pm
Thanks for posting this, really nice piece of code :D
I am absorbing as much sprite code as I can to build up to doing a project or two, noticing the 256 pixel screen really does simplify the code a lot so thinking that would be a good format to aim for.
Postby sydney » Tue Feb 07, 2017 9:54 pm
I've just reread my post and I've not made it clear that this code isn't mine, it's by SteveO and he posted it at Retrosoftware in the example code section. All I've done is adapt it for a 256 pixel wide screen. It's going to form the basis for my Combat project which I'll hopefully have time to work on tomorrow.
Postby FourthStone » Wed Feb 15, 2017 11:10 pm
I just had a question regarding the sprite data format, I'm trying to use my own sprites and they not plotting at all or produce a mess so I must be doing something wrong.
With the Sprite Graphic Structure, the comments say to use Width, Height, Data:
;Sprite Graphic Structure
   ;offset       meaning
   ;00           width
   ;01           height
   ;02->to end   graphic data
So I've pasted in some mode 1 sprite data preceded by width (assume byte width) and height (assume pixel height) as follows:
.GameSprites
   ;INCBIN "DroidSprites.bin"
   equb 5,8,&11, &33, &CC, &88, &00, &11, &DD, &BB, &88, &00, &00, &57, &AE, &00, &00, &00, &FF, &FF, &00, &00, &11, &73, &EE, &88, &00, &22, &30, &CC, &44, &00, &DF, &00, &00, &BF, &00, &66, &00, &00, &66, &00
Strangely when I look at the DroidSprites.bin file the first two bytes are 24 and 0. Can you tell me if I am missing something about the width and height bits or the format of the sprite data? :?
18 00 DA 00 9C 01 5E 02 20 03 E2 03 E4 04 E6 05 E8 06 EA 07 94 08 3E 09 06 20 00 00 00 00 00 15 15 15 15 01 03 03 03 03 03 03 03 03 02 00 00 00 00 00 00 00 00 01 01 01 00 00 00 14 14 14 3E 14 00 00 00 94 94 C0 03......
Postby FourthStone » Thu Feb 16, 2017 1:27 am
Just a follow up to say I've worked it out, after finding the swift sprite format documentation and after a bit of head banging ](*,) the penny finally dropped after much scrutinizing of the data in DroidSprites.bin
So in case anyone was wondering, the excellent sprite plotter code above expects the sprite data to be in the following format:
So depending on how many sprites are referenced this will determine the offset address for the first and subsequent sprites.
Apologies if this is made obvious somewhere else as I couldn't find it or was too thick to read it properly #-o
Return to “programming”
