Games that don't work in jsbeeb
pau1ie
Postby pau1ie » Sat Jan 07, 2017 10:38 pm
Thanks to ahope1 for creating a bug report in github. The customrl also allows a game not to be played online, so I switched off the following games. Does anyone know of any others that don't work?
joachim
Re: Games that don't work in jsbeeb
Postby joachim » Sat Feb 25, 2017 10:54 pm
Just to be clear, there are non-RAM versions of Dunjunz too: STH has a non-RAM disc image and that doesn't work on jsbeeb either.
billcarr2005
Postby billcarr2005 » Mon May 08, 2017 9:27 pm
Since the Master version of Dunjunz was Side B of the original disk, I decided to try Side A on jsbeeb with "BBC B" set as the model and it works fine.
I don't think that the version using sideways RAM was official, and as such I'm not entirely sure it's worth trying to get it working.
Postby lurkio » Mon May 08, 2017 9:29 pm
The STH zip file that contained a .SSD of Dunjunz for the Master also contained a separate .SSD for the Model B, but the two .SSDs were originally two sides of a flippy disc that needed to be removed from the drive, turned over, and reinserted before you could play the Model B version of the game. (The second .SSD also held all the level data, for both Model B and Master.)
I've created a single .SSD that should contain a bootable, working copy of the Model B version of Dunjunz:
If you know how to play the game -- I don't! -- then please try my version and let me know if it works properly. In particular, can you get past Level 1 and onto Level 2?
Postby lurkio » Mon May 08, 2017 9:30 pm
billcarr2005 wrote:Since the Master version of Dunjunz was Side B of the original disk, I decided to try Side A on jsbeeb with "BBC B" set as the model and it works fine.
You just beat me to the Submit button!
I thought the Master version was on Side A of the STH copy?
billcarr2005
Postby billcarr2005 » Mon May 08, 2017 9:48 pm
I stand corrected!
Had misnamed my FSD and subsequent SSD files :oops:
Pernod
Postby Pernod » Tue May 09, 2017 11:50 am
lurkio wrote:If you know how to play the game -- I don't! -- then please try my version and let me know if it works properly. In particular, can you get past Level 1 and onto Level 2?
It works to level 2, I didn't try it any further.
Postby lurkio » Tue May 09, 2017 11:54 am
Thanks, Nigel! That's probably good enough -- I just wanted to check that the game code could find and load the files for levels beyond Level 1.
:idea:
joachim
Postby joachim » Thu Jun 08, 2017 12:26 am
A tiny failure: the "Play" link in Ghouls of Azzod, http://bbcmicro.co.uk/game.php?id=599, doesn't result in a functional game, just a black screen in jsbeeb.
Incomprehensibly, the game loads fine if you press SHIFT-BREAK from this screen, or if you BREAK and *EXEC !BOOT. It's just the autoboot straight from startup that fails.
Postby lurkio » Thu Jun 08, 2017 11:10 am
joachim wrote:A tiny failure: the "Play" link in Ghouls of Azzod, http://bbcmicro.co.uk/game.php?id=599, doesn't result in a functional game, just a black screen in jsbeeb. Incomprehensibly, the game loads fine if you press SHIFT-BREAK from this screen, or if you BREAK and *EXEC !BOOT. It's just the autoboot straight from startup that fails.
I think this is down to some sort of vague "timing" issue with JSBeeb, which has already been reported here:
Unfortunately, Matt Godbolt doesn't seem to have been able to do much development work on JSBeeb lately, so I think we'll have to work around any issues, case by case. For Ghouls Of Azzod, this fix seems to work:
All I did was add a pointless PRINT statement to the !BOOT, which seems to slow it down just enough to allow JSBeeb to boot the game from a "cold start".
:idea:
Matt Godbolt wrote:Hi all, I'd like to announce my Javascript BBC Micro emulator, jsbeeb ...
Return to “bbcmicro.co.uk”
