Search brokenness
Prime
Search brokenness
Postby Prime » Tue May 26, 2015 10:50 am
Hi all,
I think there may be a minor problem with the search function for the forum, selected the following options :
Advanced search,
Search for all terms or use query as entered,
search terms : +electron +circuit
Search within: Topic titles only
Display results as: posts
Hitting go brings up a list of posts, with the first 3 not containing "electron", at the top of the page I get :
"Search found 15 matches
Search term used: +electron +circuit ignored: electron"
Why is it ignoring electron, when I specifically requested that it is required?
Also searching for "electron" on it's own yields :
"The following words in your search query were ignored because they are too common words: electron.
You must specify at least one word to search for. Each word must consist of at least 3 characters and must not contain more than 14 characters excluding wildcards."
I can understand just having it ignored if searched for on it's own but in cases like this I think this is a little silly.
Phill.
Re: Search brokenness
Postby Pernod » Tue May 26, 2015 12:01 pm
There are options in phpBB to select the method used for searching. It seems this forum uses 'phpBB Native Fulltext' which utilises a 'Common word threshold' that defaults to 5%. This can be set to 0% to disable the common words issue, the index will need recreating after changing the threshold.
On my own forum I prefer to set the 'Search backend' to 'MySQL Fulltext' which doesn't have the threshold option and should be faster too.
Prime
Postby Prime » Sat Jun 06, 2015 9:03 pm
Can I bump this please?
Samwise, Arcadian or one of the other forum admins can we please fix this?
I wanted to search for "Master RAM Board" today and it decided to ignore "Master"
This is a real pain in the ASS!
Phill.
Postby Arcadian » Sat Jun 06, 2015 9:16 pm
I did mention this to Samwise a couple of week back. Apparently the setting has always been set to 0% (under fulltext native).
Anyway I've just tried changing the overall setting to fulltext mysql and it seems to be ok now?
For example I've just tried searching +Electron +Circuit and it returned the expected results. As did a search for "master ram board".
Prime
Postby Prime » Sat Jun 06, 2015 9:27 pm
Arcadian wrote:I did mention this to Samwise a couple of week back. Apparently the setting has always been set to 0% (under fulltext native).
Yep just checked it and it seems to be working now much better.
Thanks for sorting this out Dave,
Much appreciated.
Phill.
