High Score Challenge S8 - R9 - Bug Eyes
Michael Brown
Re: High Score Challenge S8 - R9 - Bug Eyes
Postby Michael Brown » Fri Dec 29, 2017 7:39 am
Just taken a look at my copy of Bug Eyes.
I take full blame for this.
In BUG5 Bill had changed the value of &1F14 from &F8 to &A8 and &1F35 from &F9 to &A9 to avoid a clash with the Datacentre.
However, because I wanted to keep the stars in the loader moving the same as the tape version does whilst loading the main game, I had to add some code to BUG5 to stop them before starting the game. The way I did this broke the game. I have now moved this routine to a spare bit of memory at &3110 in BUG4.
I have checked the game and although I cannot complete it, it does still go to "GAME OVER" when dead and restarts.
Also it retains the highest score and only makes a noise at GAME OVER when a new high score is achieved.
Hopefully, this sorts the issue.
Is it possible someone could download the image here and play the game through and let me know the outcome?
If OK then I will copy this over to my Disc012.
Many thanks.
MICK.
bugeyesfix.zip
(8.49 KiB) Downloaded 3 times
BTW Another good reason to play games is to check they actually work correctly when copied to disc.
Last edited by Michael Brown on Fri Dec 29, 2017 2:50 pm, edited 2 times in total.
Postby KarateEd » Fri Dec 29, 2017 8:33 am
leenew wrote:Hmmm... that's a shame.
This is one of the few games that we had to alter to make it compatible with the datacentre.
See here: viewtopic.php?f=6&t=6178&p=59797&hilit=Bug+eyes+datacentre#p58567
Maybe Billcarr could have another look at this?
Lee.
I also noticed that that version didn't update the high score correctly. It took whatever game you just played and made that the high score. Something more to think about..
Postby chrisn » Fri Dec 29, 2017 11:41 am
Thanks for the hint, JoolsH! Got a bit further this time... 36,450
Michael Brown
Postby Michael Brown » Fri Dec 29, 2017 2:49 pm
See my previous post.
Just edited it and inserted a new version of the game.
If someone can please try this one.
Hopefully, this time, I have got it right!
Mick.
Postby CMcDougall » Fri Dec 29, 2017 3:02 pm
played from the original tape, but never got past level 8 :(
why are they easier after lev4! :roll:
58,890 lev8
Postby JoolsH » Fri Dec 29, 2017 3:13 pm
Michael Brown wrote:See my previous post.
Nope, still crashes on completion I'm afraid :(
Postby CMcDougall » Fri Dec 29, 2017 3:23 pm
^if it works with original tape, AND the STH disc convert version, maybe the DataCentre fix just knackers everything else,
so pointless just for folk with a DataCentre, as more %people will have Tape /Disc / 33p MMC interface :D
noticed this version is called 'Agent Starman'
& when I first played BITD from compilation "The Complete BBC -Audiogenic"
it is 'Agent Zelda'
tape rip linky below, wonder if that's OK too, ie goes round again after level10 :-k
viewtopic.php?f=32&t=5023#p66848
EDIT: it does work, even with my bad tape to disc hack from 1986 :D
as have them saved in 'The Savestate thread!' 8)
scr Zelda
EDIT2: inst from both:
Michael Brown
Postby Michael Brown » Fri Dec 29, 2017 4:59 pm
OK!
Just to see if it is the Datacentre fix that causes the problem.
Here is the same copy of Bug Eyes with the original code for the keys.
If someone could please check this copy and let me know the outcome.
regards,
Mick.
bugeyesfix.zip
Postby JoolsH » Fri Dec 29, 2017 5:39 pm
That one crashes on completion too.
Postby KarateEd » Fri Dec 29, 2017 6:28 pm
A slight bump up, almost have this level figured out..... 44,470
Postby KarateEd » Fri Dec 29, 2017 6:35 pm
Michael Brown
Postby Michael Brown » Fri Dec 29, 2017 7:00 pm
That's Odd!
OK the only other thing it could be is that there is a ?&3C7=&00 in the loader of the STH version.
I have added it to my version.
Hopefully this sorts it. If so then it was a tape protection thing after all!
If not, then I may have to wait for Bill C to investigate.
Mick.
bugeyesfix.zip
(8.5 KiB) Downloaded 3 times
Postby JoolsH » Fri Dec 29, 2017 8:10 pm
Nope, that's borked too.
Looking at the debugger in B-em, it ends up at address &B58, which contains &32 HLT which according to this crashes the 6502.
Postby KarateEd » Sat Dec 30, 2017 2:27 am
Moved up a bit more, slowly but surely working towards completing the levels..... 54,640
Michael Brown
Postby Michael Brown » Sat Dec 30, 2017 9:20 am
Hi Jools
I will take a look again in the new year and start a new thread to avoid clogging up this thread!
Happy new year.
Mick.
i
Postby MatthewThompson » Sat Dec 30, 2017 3:57 pm
New high score at last, really don'tk know why the bottom left hand part of level 2 is causing me so much grief, it shoudn't be that hard !
Postby KarateEd » Sat Dec 30, 2017 4:13 pm
MatthewThompson wrote:New high score at last, really don'tk know why the bottom left hand part of level 2 is causing me so much grief, it shoudn't be that hard !
I hear you on that one Matt but it is only 10 levels so I guess he started it off hard to make sure there is a challenge and brother is there ever.....
Postby JoolsH » Sat Dec 30, 2017 6:23 pm
That bit's a bit of a pig, but if you do the first bit of the level fast enough, it becomes easy.
Got to that level, the third time around.
169,220
Postby KarateEd » Sat Dec 30, 2017 7:23 pm
Got to level 9, getting close to finishing at least once through..... 62,940
Postby KarateEd » Sat Dec 30, 2017 9:15 pm
Postby MatthewThompson » Sat Dec 30, 2017 9:20 pm
New high score, starting to get the hang of Level 2 now, but "'Yikes' doesn't seem as easy to cross those platforms as they do on Vindaloo. maybe it's just me !
Postby FourthStone » Sat Dec 30, 2017 10:30 pm
Was having a good run until I kept getting stuck on the elevator on "WOT NO ALIENS" could not move right for some reason :evil:
I also find Yikes! to be more tricky than the other levels after it, and the spiders on Dominic Is a Wally still catch me unawares as the collision detection seems a bit off.
Score: 72540
Postby KarateEd » Sun Dec 31, 2017 3:55 am
Another small bump up.... still can't seem to solve level 9 but think I'm close..... 68,240
Postby chrisn » Sun Dec 31, 2017 7:49 am
Now up to level 8, need to figure out the right timing to fall down to the bottom ... 55,220
Postby KarateEd » Sun Dec 31, 2017 7:57 am
Well, victory of some sort - got TO the 10th level, now have to work on getting that one completed to catch Jools..... LOL... 73,260
Postby KarateEd » Sun Dec 31, 2017 8:50 am
Finally solved 1 - 10 levels, got to level 2 on the 2nd time around. Got flustered or otherwise I'd still be going but still nowhere near what Jools got.... I must be terribly inefficient in this game I guess, probably haven't chosen the best solutions but the ones I've got seem to work anyway. 87,600
Postby MatthewThompson » Sun Dec 31, 2017 9:02 am
169,220
Thanks for the pointer, I can do this level pretty much every time now, just don't stop hardly, and just go for it at the start. I thought Yikes would be pretty straight forward as it is a carbon copy of a Vindaloo level but it's a lot harder, the platforms seem to behave differently.
Postby KarateEd » Sun Dec 31, 2017 9:16 am
Level 8, 2nd time around. Went into the 2nd round with only one life and got to 8th level, which I never die on and got careless..... 134,410
Postby MatthewThompson » Sun Dec 31, 2017 12:03 pm
Very slight increase, I have now sussed Level 2 out and can do that easily every time now, level 3 never been a problem, but Yikes is still getting me every time !
Postby KarateEd » Sun Dec 31, 2017 3:43 pm
MatthewThompson wrote:Very slight increase, I have now sussed Level 2 out and can do that easily every time now, level 3 never been a problem, but Yikes is still getting me every time !
I found Yikes to be really hard and sometimes it still gets me, hell, it gets me lots but it's just a timing issue and there are patterns that work every time, it's just a matter to see them. I started using counting along with those patterns and get through far more often now.
Return to “software: games - high scores”
