Pipemania Challenge Issue being resolved soon
Postby KarateEd » Tue Dec 12, 2017 7:04 am
Hi Folks,
There is a slight problem with the SSD for PipeMania - We're going to stop the challenge until Daniel can fix that problem so for now would you all kindly cease submitting scores that are using the current SSD. Daniel noticed something that is offensive in today's current clime so we'll let him run his magic and we'll be back to it in no time.
In the mean time, please practice as much as you want for this challenge but please don't use the current SSD for posting. Both Wouter and I have removed the offensive part but it's easy enough for us to start again if you wish and that way we'll all be on an even playing field.
Thanks for your cooperation,
Re: Pipemania Challenge Issue being resolved soon
Postby CMcDougall » Tue Dec 12, 2017 11:18 pm
I've got four versions here, whats up with it? :?
if Daniel finds it... tell him I found him! :lol:
Grannys Garden2
Wouter Scholten
Postby Wouter Scholten » Wed Dec 13, 2017 4:50 am
KarateEd wrote:Both Wouter and I have removed the offensive part but it's easy enough for us to start again if you wish and that way we'll all be on an even playing field.
I have? I didn't notice anything in the highscore table. In case of different versions: I used the version in the beeb.mmb that duikkie provided quite a while ago.
Offensive in "today's clime"?
Postby KarateEd » Wed Dec 13, 2017 7:52 am
Yes, I guess the version you're using doesn't have the offence in it..... can you send me a copy via this thread Wouter?
Thanks,
Postby danielj » Wed Dec 13, 2017 8:09 am
I think if you have Ronnie Pie Hats in your high score table at any point, you're potentially afflicted.
billcarr2005
Postby billcarr2005 » Wed Dec 13, 2017 8:12 am
The 8 high scores are randomly selected from a set of 16... so it's possible that it doesn't appear all of the time!
Pipe Mania names.png (9.57 KiB) Viewed 117 times
Postby danielj » Wed Dec 13, 2017 8:16 am
OK, we're off - please use the disc image attached to the post for the challenge!
