High Score Challenge S7- R8 - Repton
Postby KarateEd » Mon Jun 12, 2017 8:13 am
Season Seven: Round 8
Repton chosen by Chrisn
:arrow: Round One starts at 9pm on Monday the 12th of June and ends at 9pm on Monday the 26th of June
:arrow: http://www.bbcmicro.co.uk/game.php?id=266
Link to Overall High Score Table...http://stardot.org.uk/forums/viewtopic.php?f=46&t=12659
And now for an old classic .....that I never played back in the day.......Ed ...........
Re: High Score Challenge S7- R8 - Repton
Postby FourthStone » Mon Jun 12, 2017 11:13 am
Ohh, I did play this BITD but I really wish I could setup a beeb to play it on... fond memories galore :mrgreen:
Postby MatthewThompson » Mon Jun 12, 2017 8:27 pm
Gave up with Video's Revenge, so thought would make an early start on this one, got all the way to worst ever Repton level (Giant Clam) and lost all my lives .
Postby KarateEd » Mon Jun 12, 2017 8:48 pm
Ok, just to get us started.....Edit: or not!
Postby KarateEd » Tue Jun 13, 2017 6:02 am
This isn't much of a score but the task is to really learn how to solve the puzzles in a timely manner and really, really know the mazes well.
As I've never played Repton before, I don't think I'm doing too bad. I'm through 2 levels now but am having issues with a couple of the puzzles in 3.
I'll get there eventually.
For those that have played this, I'm sure this seems like a very trivial score.
Postby CMcDougall » Tue Jun 13, 2017 7:00 pm
first played this on my cousins electron, yes in the little box on left not full screen per beeb 8)
think 99% of us won't need instructions, but here it is for the other 1% :-s
Postby KarateEd » Tue Jun 13, 2017 9:12 pm
Thanks Mr. McD......am I too late for the prize?... ;-)
Postby KarateEd » Tue Jun 13, 2017 9:56 pm
Still haven't solved 3 yet, that one last barrier to the key I think.....
Postby FourthStone » Tue Jun 13, 2017 10:37 pm
I'm doing about the same as you Ed :lol:
I'm sure I have completed every level of every Repton game created BITD but I am struggling with level 3 also, might have to go back and read the instructions again for any hints... I've really only had one play session of 30 minutes so far so need to create some quite time to focus, and I've been sick, and and and... :wink:
Postby KarateEd » Wed Jun 14, 2017 7:01 am
Excuses accepted my friend.....
Postby KarateEd » Wed Jun 14, 2017 8:35 am
Wow, 3 is not easy, lost a life just because I took too long and the monster at the beginning of level 2 got me once too...sheesh but I did solve the puzzle to the key so I could finish the level.
Postby FourthStone » Wed Jun 14, 2017 9:34 am
Got to level 4, know I can do better... first couple of levels re-imprinting on neural pathways :lol:
Agree with level 3, so many diamonds in the starting area then they spread out and hard to recall every single one so lots of backtracking and wrong turns...
Score: 10329
Postby FourthStone » Wed Jun 14, 2017 10:08 am
Last game for tonight, a little better :-k
Score: 13071
Postby KarateEd » Wed Jun 14, 2017 7:59 pm
Only slightly better. I can see this game is going to be quite the struggle, figuring out the best way to complete. I still haven't completed 3 without losing 1 life, usually to time more than lack of solving.
Postby chrisn » Wed Jun 14, 2017 9:56 pm
A classic Beeb game :) Does the first person to complete all 12 levels still get a prize...?
Level 3 is a race against the clock, the route needs careful planning (use the map). I also got caught by a monster on level 2, it seemed to jump through the boulder I was pushing. Now up to level 4... 10,603
Postby CMcDougall » Wed Jun 14, 2017 10:10 pm
this was easy BITD, level4 monsters a pain..
Postby KarateEd » Fri Jun 16, 2017 12:26 am
Well, I see how this is going to go.... stuck on level 4 now......
Postby KarateEd » Fri Jun 16, 2017 12:42 am
Postby MatthewThompson » Fri Jun 16, 2017 10:13 am
New high score, managed to finish all 12 levels , and the game just starts again, doesn't get quicker or anything, so just keep going until I lost all my lives.
A few pointers - every section of earth is worth 1 point,so that can push up your score, and those monsters are a nightmare, but they do not need to be killed to finish the level (unlike Repton 2 + 3) so if you don't need to drop the egg don't. All the screens are possible to finish (Giant Clam is a nightmare - there is a way to do it but it means losing a life) always use the map to check for the best route, missed diamonds etc, there isn't one unfortunately for the last 3 levels.
Postby MatthewThompson » Fri Jun 16, 2017 6:37 pm
New high score, that will be it now I think. A tip for a couple of levels, do not get the key straight away as when the safes turn to diamonds the boulders will fall off and can block some diamonds below.
Postby FourthStone » Fri Jun 16, 2017 11:05 pm
Small improvement, not even close to MT :lol:
Have the first 4 levels on rinse repeat with the odd mistake costing a life here and there, the monsters on E can be a real pain so getting to F with enough lives is a challenge... I recall BITD once a level was completed and the password gained the earlier levels were seldom played again so a play through from start to finish is a big challenge (for me).
Score: 15688
Postby MatthewThompson » Sat Jun 17, 2017 8:09 am
FourthStone wrote:Small improvement, not even close to MT :lol:
Score: 15688
The monsters on Level E (Gecko) can be dealt with quite easily, collect absolutely everything on that level before you drop any eggs, then drop the right hand side egg first, get the diamond, then come out of that area go down and along to the left so the monster can't follow you out, go over to the left hand egg, drop this one get the diamond above, then go up and round to the one above and collect the diamonds to finish the level. Hope that helps,
Postby richardtoohey » Sun Jun 18, 2017 1:24 am
MatthewThompson wrote:New high score, managed to finish all 12 levels
=D> but a bit off-putting when I haven't even started! How long did you have to play for to get through all 12 levels (I mean the one game where you did it, not total time for all attempts, if that makes sense.)
Definitely one of the best BBC games. Can't remember how far I got through it BITD, doubt I finished it.
Postby KarateEd » Sun Jun 18, 2017 3:33 am
C'mon Richard, get started, let's see how far you get. I don't think I'm getting much further than I am now so catch up.....
Postby richardtoohey » Sun Jun 18, 2017 7:09 am
Got to the last bits of level 3 but botched up a few of the puzzles ... ](*,)
If Tim Tyler did this when he was 15 (IIRC) I do wonder what he's up to now!?
Long way to go to catch up with you, Ed, but will see if my fading brain cells can at least get me through level 3. I haven't got the cats to help me :wink:
Postby MatthewThompson » Sun Jun 18, 2017 7:13 am
Not sure how long it takes to finish, not that long ,no more than 45 minutes, i've been played Repton again on iRepton and then again on Android Repton , so i've been playing these levels loads in the last couple of years, they don't really take that long to do once you know the route through them.
Postby richardtoohey » Sun Jun 18, 2017 7:29 am
Thanks, I imagined it would be hours and thought it was an odd choice for high scores, but then just having had a quick whirl it doesn't take long (as you say) to get through each level. Once you've figured out the puzzles. :D
Wonder if anyone does speed-running through Repton?
Might be something for another round of high scores ... quickest timed runs first level Repton, Rocket Raid, whatever. But then proving it, etc. might be too hard. :-k
Postby MatthewThompson » Sun Jun 18, 2017 8:35 am
richardtoohey wrote:Thanks, I imagined it would be hours and thought it was an odd choice for high scores, but then just having had a quick whirl it doesn't take long (as you say) to get through each level. Once you've figured out the puzzles. :D
I thougth Repton was an odd choice to start with as I thought it was just complete 12 levels and the game ends, I didn't realise it would restart and you can do it again so there is no maximum score - unlike on the later incarnations of Repton1 .
Some of the levels can only take a couple of minutes , you don't have to collect the earth, that takes time, depends if you want higher scores or not.
Kecske Bak
Postby Kecske Bak » Sun Jun 18, 2017 11:04 am
Although I adore Repton I was surprised this was chosen for a high score challenge, and even more surprised at how well this competiton is going.
I've just bought Repton on Android. Getting chased about by three monsters "Giant Clam" on a touch screen without losing a life was very frustrating but the satisfaction when you achieve it is incredible.
Postby KarateEd » Sun Jun 18, 2017 6:03 pm
Well, I was also wondering how it would go but it seems to be doing fairly well. It's not any odder than some other games. It's a level type game with a certain amount of points to it, multiple ways to score those points to have a score climb higher, or not, and there are choices all along the way so it actually makes a very good choice for the challenge. I didn't think it would at first but by trying it, who knew?
