High Score Table - Boulderdash
Re: High Score Table - Boulderdash
Postby KarateEd » Tue Mar 15, 2016 6:18 am
The Mgmt.......:-)
Postby MatthewThompson » Tue Mar 15, 2016 10:32 am
>So Matt, the 4th screen, what is the goal? I managed to destroy all 4 of the beasts that were locked up and then I expected to see an open door >somewhere but, nope.....is there something else you have to do in this level?
You need to get the correct amount of jewels, which (I think) is 36, to get these jewels, you drop the boulders onto those butterfly things, they will turn into jewels, 9 in total, so you need to squash 4 butterflies and get 9 jewels from each to open the level exit up, but beware as you can lose jewels if you drop other jewels on the butterflies, or it's by the edge of the screen , it's pretty easy to do but if you just wait with a boulder balanced on your head and then drop it as the butterfly comes up the passageway to you , 9 jewels should appear each time and collect them all up before you move onto the next butterfly.
hope that makes sense !
matthew
Postby KarateEd » Wed Mar 16, 2016 1:35 pm
Hi Matt,
Makes perfect sense, seems like I lost jewels to the edges or something because I didn't always get 9 jewels
Thanks for the explanation.
Postby KarateEd » Thu Mar 17, 2016 5:24 am
OK, must be getting better, got through that level and have a much lesser score.... one of THOSE games....!
Postby MatthewThompson » Thu Mar 17, 2016 11:03 am
KarateEd wrote:OK, must be getting better, got through that level and have a much lesser score.... one of THOSE games....!
It is one of THOSE games !! really annoying , i've got to new levels and had a much worse score because i've had a better game and not lost any lives !
Postby sydney » Sat Mar 19, 2016 2:28 pm
The Mgmt.......:-)
Postby KarateEd » Tue Mar 22, 2016 5:13 am
This score was tough to achieve because it's in that one with the squares (8 I think) with the instant kill creatures.... such an imagination.
Anyway, starting to really like this game but it's not easy....
Postby KarateEd » Wed Mar 23, 2016 9:57 pm
Another slight boost up, some interestingly tough screens once you figure out some of the interesting tough screens...
Postby KarateEd » Thu Mar 24, 2016 12:26 am
Broke 3k
Postby KarateEd » Mon Mar 28, 2016 6:35 am
So, I'm getting to the 'green' screen with the flashing thingys and the flooding faces. I've collected all the diamonds, killed 2 of the thingys and then the flood takes the rest.
I cannot for the life of me figure out how to get out of this one....any clues anyone?
Oh, on a real Beeb this time.....got my Issue 4 board working again.....still a problem with the Issue 7 board, will fix as time permits.
Postby MatthewThompson » Mon Mar 28, 2016 12:28 pm
KarateEd wrote:So, I'm getting to the 'green' screen with the flashing thingys and the flooding faces. I've collected all the diamonds, killed 2 of the thingys and then the flood takes the rest.
The green algae stuff needs to be blocked in, trap it in with boulders so it can't move and the whole area will turn into diamonds.
Postby sydney » Fri Jun 03, 2016 1:27 pm
High Score Tables Updated To New Format......
The Mgmt.......:-)
Return to “software: games - high scores”
Users browsing this forum: Yahoo [Bot] and 1 guest
