UK101 Hardware Modifications Archive
Seldon2k
Postby Seldon2k » Wed Aug 09, 2017 7:28 pm
After creating this forum http://stardot.org.uk/forums/viewtopic.php?f=45&t=13550 to act as a UK101 Programming Resource
I have just thought of the hardware modifications that made that necessary!
This forum is to be a repository of the various mods from PE Magazine, the CUA newsletters, and other sources to help people who may
either wish to 'upgrade' their UK101 boards 8) or just puzzle out what has been done to it before they acquired it. :?
I hope other will contribute any scans or hardware tips.
Re: UK101 Hardware Modifications Archive
Postby BigEd » Wed Aug 09, 2017 8:58 pm
I did a clock speed mod. Probably like the one described here:
Modifications
Because of the simple nature of the hardware, it was very easy to modify the machine. Some very common modifications included:
  • External power supply
    There was an on-board power supply (it just needed an external transformer), but it was under-rated and the voltage regulator chip was prone to failing. So it was quite common to remove it and use a rather better external power supply.
  • Overclocking the the CPU
    The 6502 had a 1μs cycle time and used a 1MHz external clock to generate it, however most CPUs could run quite happily at faster clock speeds. Since the UK101 had all its clock signals derived from a single 8MHz timer it was easy to find a 2MHz signal and attach it to the CPU clock pin, effectively doubling the machine speed.
  • Improving the video
    It was relatively simple to double the video RAM to 2K and then display 32 lines instead of the standard 16, which was a very useful extension.
  • Increasing the cassette baud rate
    The standard cassette interface ran at 300 baud which was reliable but pretty slow. It was simple to double this to 600 and even double again to 1200, as long as you used a decent quality tape recorder - running the CPU at 2MHz also helped a lot when trying to get 1200 baud to work reliably.
trev-ham
Postby trev-ham » Thu Aug 10, 2017 8:59 am
I have done several mods to my test UK101 as seen in the image, they are;
Multi-Monitor board (switchable)
ROM/RAM board with switchable 1Mhz/2Mhz clock
Video RAM adapter to accept 6116 SRAM (replacing the existing 2114's)
Programmable Sound Generator (as described in Practical Electronics Sep 1980)
These mods have been designed to have little or no impact on the original PCB. If anyone is interested I have a small number of bare PCB,s available for a small donation.
Trevor
Postby flaxcottage » Thu Aug 10, 2017 7:22 pm
Love those circuit boards. :D =D> =D>
I'd be interested in the ROM/EPROM board that sits on the 6502 socket. It makes my veroboard concoction look positively primitive. :lol:
I'd PM you but since you have only 4 posts you couldn't reply. If you contact an administrator maybe they will let you PM. [-o<
Currently running L4 Econet with BBC B, BBC B+ 128K, Master 128K, 4Mb A3000, 4Mb A3020, 4Mb A4000, 4Mb A5000 dual FDD; UK101; HP41CX setup; Psion 3a, 3mx and 5mx; Z88; TI-58c, TI-59 and printer, HP-16C programmer's calculator and a bakery of Pis.
JonTr7
Postby JonTr7 » Fri Aug 11, 2017 7:07 am
Hi Trevor
I'm interested in a programmable sound generator board.
John
IanB
Postby IanB » Fri Aug 11, 2017 4:58 pm
I previously posted this in another thread but as you are collecting mods in one place, here's my "no snow" modification which was published in the December 1981 issue of PC World:
This mod might not work when running the CPU at 2Mhz
trev-ham
Postby trev-ham » Fri Aug 11, 2017 6:50 pm
Hi Ian,
I did try this 'no snow' mod a while ago and it did not work at 2 MHz on my UK101 so abandoned it.
IanB
Postby IanB » Fri Aug 11, 2017 7:13 pm
trev-ham wrote:I did try this 'no snow' mod a while ago and it did not work at 2 MHz on my UK101 so abandoned it.
I couldn't get my UK101 to run at 2Mhz so never tried it but I'm not surprised it doesn't work as it relies on both the character clock of the video system and the CPU running at 1Mhz so they can both access the RAM on different phases of the clock. It probably wouldn't work on the Superboard either as the character clock on that is 500Khz.
It should be possible to get it working at both 1Mhz and 2Mhz by gating the signal going to pin 9 of IC28 with the 1Mhz clock but I haven't looked at the exact timing details of this.
tinplatepete
Postby tinplatepete » Sat Oct 14, 2017 10:16 pm
Hi Trevor.
I am also intrested in your PSG board.
Peter
Pete
tinplatepete
Postby tinplatepete » Sat Oct 14, 2017 10:18 pm
I did Ians no snow mod back in the day and it worked fine on 1Mhz & 2 Mhz, It was my first UK101 mod.
Pete
tinplatepete
Postby tinplatepete » Sat Oct 14, 2017 10:55 pm
My original uk101 needed an uprated PSU because of all the modifications, 32k Ram Board, J1 Buffer board, Premier Sound VIA Card, Premier Floppy controller card, switchable 16/32 Line Display, 1Mhz/2Mhz speed, Premier Sprite/Colour Board, Premier Basic 5, Premier Basic X, Premier Toolkit, All the original Roms were mounted on an Premier EPROM extension board.
The Dos for the FCC was ROMDOS.
With all these mods it was never a reliable machine but I had a lot of fun building the boards and was a constant job keeping it going but enjoyable.
The original machine has long since gone but some of the parts from it are on my replacement UK101, 32k Ram board and some of the EPROMS.
If anyone is interested I will post a picture of the original UK101 with all the mods.
Pete
tinplatepete
Postby tinplatepete » Tue Oct 17, 2017 4:21 pm
This is my long lost upgraded uk101.
Pete
Postby flaxcottage » Tue Oct 17, 2017 7:53 pm
That looks amazing! :shock:
What are all the bits? Please tell. [-o<
tinplatepete
Postby tinplatepete » Sun Oct 22, 2017 4:14 pm
The board in the middle is a switchable 1K/2K screen Ram made by Taqwa and this is one I am looking to recreate.
The board middle left is an extension EPROM board made by Premier Publications and this is also one that I will be recreating.
The board on the left hand side tight against the case is a programmable colour/sprite board also made by Premier Publications.
The board connected to the J1 socket is a J1 buffer board made by Premier Publications.
The long board on the right hand side up tight against the case is a J1 mother board by Premier Publications.
The two boards connected to the J1 extension board are as follows top Premier Publications Sound/VIA and below is a Premier Publications Floppy Disk Controller; I would love to recreate both of these boards.
The board that has the 6502 processor mounted on it is a 32K Ram board made by Audio Computers and I still have this board.
The board on its own to the right is an A to D converter made by me for interfacing the VIA board.
As you can see I was well into UK101s back in the day and enjoyed every moment of it and have recently got back into it, I now have two UK101s, one to keep original and one to upgrade, I still have some of the original Premier EPROMS and parts from my old uk101.
Pete
Postby flaxcottage » Sun Oct 22, 2017 6:28 pm
In your Premier EPROMS there wouldn't happen to be a BASIC X would there? That appears to be MIA. I have the documentation and a supposedly good disassembly but it doesn't work in my UK101.
tinplatepete
Postby tinplatepete » Fri Oct 27, 2017 10:19 pm
I don't have my original Basic X, I think the Basic X you have is the one from OSIweb, this one has some modifications done to the code for it to work with other software on a Superboard, in order to get this to work on a UK101 there is a few JSRs in the code that need to be changed, I managed to work out some of the changes and got it to work but it still wasn't quite like the original Basic X, the default Sound address has been changed and it doesn't display the words Premier Basic X when first started but apart from that it works ok
By the way the original default sound address for Basic X is EF90 & EF91 (61328 & 61329 and this is located in the last few bytes of data at the end of the code in the EPROM.
I am hoping soon to have a copy of an original Premier Basic X, watch this space.
Pete
Seldon2k
Postby Seldon2k » Mon Oct 30, 2017 3:32 am
Hardware Info Request
I have been looking at the Cassette Port of the UK101 and am a little puzzled over the selection of the Baud Rate.
The following requires a working UK101 with an unmodified cassette interface and test equipment (frequency counter or Scope).
My analysis so far goes as follows:-
An 8MHz clock divided by 8 by IC29 (7493) to give the 1MHz clock for the CPU
This gets divided by 8 in the divider chain IC59 (74163) to give C3 of 125KHz.
Now we get to the bit that requires testing, C3 goes to IC57 (74163) and in conjunction with IC58 (7400)
Then a divide by 13 (Modulo 13, resets on a count of 12), giving approx 9600Hz. This needs measuring at pin 11.
This then goes to IC63 (7474) for a divide by 2 giving 4800Hz. This can be checked at the ACIA (6850) pins 3 and 4.
The ACIA control register at its base address of F000H is, unfortunately, read-only! It must be setting the lowest two bits (CR1 & CR0) to 0 & 1.
This would result in an internal divide of 16 giving 300Hz, therefore, a Baud Rate of 300 Baud.
The reason behind this investigation is that I am attempting to add a Cassette Port to the FPGA UK101 that Grant Searle designed.
I have just read that the Baud Rate is set at 9600 in the FPGA design!
Hopefully, it can be changed by poking the control register of the emulated 6850?
I think it would be nice to relive the real experience of loading a few programs from Cassette.
I may just use an arduino/pic between the FPGA and the cassette to buffer and retransmit serialy to the FPGA board.
Hope someone can be of help,
Terry (Seldon2k)
Postby BigEd » Mon Oct 30, 2017 6:01 am
I haven't measured, but that sounds right to me. The UK101 design is a near-copy of the OSI 600 Superboard design, and the cassette interface is meant to conform to the Kansas City standard - that's 300 baud, and a specific modulation.
Although 300 baud is also a standard for serial communication, it's a bit slow, and many systems default to 9600. This is probably why Grant went for 9600 in the FPGA UK101. (In fact, he says "Since I was going to use serial only (not cassette) I increased the baud rate to a more useable 9600 baud with HARDWARE handshaking to prevent loss of data.")
Grant also indicates two lines in the VHDL to change if you want 300 baud:
-- if serialClkCount < 10416 then -- 300 baud
        if serialClkCount < 325 then -- 9600 baud
[snip]
-- if serialClkCount < 5208 then -- 300 baud
        if serialClkCount < 162 then -- 9600 baud
Edit: It's a nice idea to be able to poke the ACIA to change the rate. The original chip has a divider for /16 and /64 operation, but not for /32. Grant's model doesn't have the divider. So that would be a change, and a novel one, but presumably not too tricky for someone skilled in the art.
Seldon2k
Postby Seldon2k » Mon Oct 30, 2017 6:10 am
Thanks Ed,
I don't know how I missed that, but I am still interested in the clk going to the ACIA in the original UK101
and also if the real TX/RX Clk is present on any of the pins of the FPGA board (far less likely).
Terry (Seldon2k)
Seldon2k
Postby Seldon2k » Fri Nov 03, 2017 1:41 am
I will post the following advert to both the Hardware and Software UK101 Archives as it seems to cover both
The next advert is the one that caused me to send off a cheque for a UK101 kit in the Summer of 1979.
Hopefully, this will be of interest.
Terry (Seldon2k)
Postby flaxcottage » Fri Nov 03, 2017 9:13 am
Seldon2k wrote:The next advert is the one that caused me to send off a cheque for a UK101 kit in the Summer of 1979.
Terry (Seldon2k)
Same here! :lol: That was a lot of money back in 1979. :?
jonb
Postby jonb » Fri Nov 03, 2017 9:31 am
I saw that advert or one very similar to it but as an impoverished teenager I could only gaze at it (rather wistfully). I remember thinking at the time that it represented to best price / performance ratio on the market that I'd seen to date.
Meanwhile, my best mate was shopping around for a computer and had considered the Newbury NewBrain (we went to Newbury to see it) and the then forthcoming Sinclair QL (which he wisely rejected as it was vapourware at the time). Around the same time the BBC Micro was announced so he waited and got one of them. Envious, me...? :mrgreen:
Return to “other vintage computer hardware, software and games”
