Matchbox sized 6502 / Z80 / 6809 Co Pro
Fwapp
Re: Matchbox sized 6502 / Z80 / 6809 Co Pro
Postby Fwapp » Thu Sep 22, 2016 9:32 am
Hi Gents - I took delivery of my LX9 co-pro board this morning and have installed to test it out.
I have an issue in that if I shift-break to call up my MMC card (using MMFS 1.27) it comes back with..
>*TV255
>*MENU
Tube on!
Entering *menu gives the same response.
When the bbc starts, I only get the first sound you normally here (boop of the boop-beep, yes I know, really technical!) but it shows
Acorn TUBE 65C102 Co-Processor
Acorn MMFS (my change)
Basic
Is there a command I need to enter to get things underway? I managed to sort my MMC card, but am wondering (as a learner Beeb driver) if I'm missing something that would be obvious to you old hands?
Acorn Atom (iss.4[WIP]) AtoMMC V2.0, BBC B (iss.7) Sir Morris SD Card and MMFS 1.27, Acorn Electron (iss.4), A3000
Lardo Boffin
Postby Lardo Boffin » Thu Sep 22, 2016 10:43 am
Fwapp wrote:Hi Gents - I took delivery of my LX9 co-pro board this morning and have installed to test it out.
>*TV255
>*MENU
Tube on!
Basic
I had a TurboMMC sd card reader installed and that had similar problems with the coproc switched on. I suspect the menu program knows it does non-tube safe stuff and therefore does not run.
If you do *FX151,230,14 (I think - the latest version may have a different null co proc) and then press break (this switches off the coproc) this should allow your MMC card reader to work from the menu.
If you have any tube based games (Elite) then you will need to leave the coproc on and navigate directly to it without using the menu.
Most games won't run with the coproc switched on.
Lardo
Fwapp
Postby Fwapp » Thu Sep 22, 2016 11:00 am
Thanks for the reply :)
Just gave that quick go and it seem to engage Z80 co-pro mode, so I might need a different *FX call.
Lardo Boffin
Postby Lardo Boffin » Thu Sep 22, 2016 11:11 am
Fwapp wrote:Thanks for the reply :)
You're welcome. And welcome to the world of Beeb!
I suspect you may have to go from 0 to 14 to see which one doesn't show a co-proc after pressing break...
Enjoy!
Postby hoglet » Thu Sep 22, 2016 11:16 am
You I think must have the LX9CoProCombined_20151215_1004_dmb firmware.
DIP switch / *FX settings as described here:
https://github.com/hoglet67/CoPro6502/w ... h-settings
To disable the Co Pro, try *FX 151,230,6
Postby DutchAcorn » Thu Sep 22, 2016 11:44 am
As software compatibility with the 6502 copro is limited, it is probably more practical to change the dip switch settings on the copro board to 0110: i.e. change the middle two switches (setting no 6). This will ensure that the copro is off by default and you can leave it plugged into the Tube port.
If you need your 6502 copro simply type *FX 151,230,0 and press ctrl-break. :D
Fwapp
Postby Fwapp » Thu Sep 22, 2016 11:56 am
Gents, thank you for your help - I now know a lot more!
Following a read of the co-pro settings and the DUTILS guide, Elite co-processor edition is up and running!
Lardo Boffin
Postby Lardo Boffin » Thu Sep 22, 2016 12:11 pm
Fwapp wrote:Gents, thank you for your help - I now know a lot more!
Excellent news! See you in the 'Quest to become Elite!' thread!
Postby hoglet » Wed Sep 28, 2016 11:49 am
dominicbeesley wrote:Where's the best place to ask / look for questions regarding the sources. For example I'm looking for the source code for the bootrom.dat (PIC?) code, trying to work out how the initial boot works
By initial boot, do you mean the Xilinx multi-boot loader? (there in no PIC, it's all done in hardware)
The source code for this is here:
https://github.com/hoglet67/CoPro6502/b ... P_reboot.v
https://github.com/hoglet67/CoPro6502/b ... CAP_core.v
https://github.com/hoglet67/CoPro6502/b ... P_config.v
There is a general description of how Xilinx supports multi boot here:
http://www.xilinx.com/support/documenta ... f#page=133
It's pretty hairy though!
The ability to dynamically reconfigure needs to be embedded in every one of the Co Processor designs, so the *FX 151,230,N will work.
dominicbeesley
Postby dominicbeesley » Wed Sep 28, 2016 12:49 pm
Thanks Dave,
'll have a read through that. It was the bootrom for the PIC in the zet core that I was looking at...I guess that must have come with the core.
I am now trying to work out how the *FX 151,230,X works...need to brush up on my Verilog! Should give me something to do on my holidays next week...
D
Postby hoglet » Wed Sep 28, 2016 12:59 pm
dominicbeesley wrote:I am now trying to work out how the *FX 151,230,X works...need to brush up on my Verilog! Should give me something to do on my holidays next week...
This component is attached to the tube interface in each Co Pro design, and is responsible to initiating the dynamic reconfiguration:
flynnjs
Postby flynnjs » Wed Sep 28, 2016 7:03 pm
The Verilog Dave pointed to won't make alot of sense unless you read the Xilinx docs about
the ICAP module. I cut the very first version of that and it was a bit of an experiment for
me so isn't the most elegant but it worked.
dominicbeesley
Postby dominicbeesley » Thu Sep 29, 2016 8:34 am
Thanks lads, it was the bit the reads the switches that I was interested in, I've had a quick look but now got side tracked as my beeb has decided to die on me so I can't test the matchbox at the moment.
Logic analyser is hooked up and hopefully be back in business soon...
D
Postby hoglet » Thu Nov 10, 2016 3:57 pm
Hi Guys,
It's been a while since we made any changes to the Matchbox firmware (about 9 months). So to remedy that, here's a update that includes a radically overhauled version of the 6502 Co Pro:
LX9CoProCombined_20161110_1455_dmb.zip
(1.89 MiB) Downloaded 40 times
The main changes are:
6502 Co Pro now uses the 65C02 version of Arlet's 6502 core.
Arlet's 6502 core is very well regarded over on 6502.org, and is specifically designed to get the most out of registered FPGA block RAM without needing to insert a wait state. The update to the 65C02 instruction set was done a few months ago by myself and BigEd.
6502 Co Pro speeds are now 4MHz/8MHz/16MHz and 64MHz.
i.e. Co Pro 3 is now twice as fast, due to the use of Arlet's core.
6502 Co Pro has access to 1MB of external RAM using bank switching.
This is the cool new feature that we've been thinking about for a while.
The 6502 memory map is spilt into 8K pages via a set of paging eight registers at &FEE0-&FEE7:
- the register at &FEE0 controls the mapping of 0x0000-0x1FFF
- the register at &FEE1 controls the mapping of 0x2000-0x3FFF, etc
- page values of 0x00-0x07 are directed to fast internal block RAM (and this is the default).
- page values of 0x80-0xFF are directed to slower external static RAM.
To test this, there is now a variant of the Co Pro Conway Life implementation that uses this bank switched memory support much larger patterns. More on this later in the Conway Life Thread
It's now possible for someone to port Alan Cox's Fuzix to run on the 6502 Co Pro in the Beeb.
32016 Co Pro is slightly faster.
ROM accesses now have one less wait state.
Other Co Processors.
None of the other Co Processors have changed.
Compatibility.
Please let me know if you have any issue with this release. I'm aware that the last release didn't seem to work on the latest batch of boards from Jason, for reasons we have yet to fathom. There is nothing in this release that I would expect to have fixed that.
regards
Postby tricky » Thu Nov 10, 2016 6:27 pm
That's great, just one little suggestion ;)
Is it worth having a 3MHz 6502 for Elite/ModelB mode?
fordp
Postby fordp » Mon Mar 13, 2017 11:38 am
Dave with the Matchbox board no longer going to be made any more how about this as an alternative:
http://www.cnx-software.com/2017/03/13/ ... h-sh2-soc/
I am happy to buy one for you if it is suitable.
FordP (Simon Ellwood)
Postby hoglet » Mon Mar 13, 2017 12:30 pm
fordp wrote:Dave with the Matchbox board no longer going to be made any more how about this as an alternative:
The problem with this board, and in fact most current FPGA boards, is they use SDRAM rather than SRAM, which is much slower for random accesses, and infinitely harder to work with.
Also, I don't think I have the motivation to target another FPGA board, unless it is architecturally very similar to the old one (i.e. uses SRAM).
Jason has (I think) offered to make the current PCB design public, so if the demand is there I'm sure someone will pick this up. I'm just not sure the demand is there.
fordp
Postby fordp » Mon Mar 13, 2017 4:33 pm
Worth a try Dave. It just seemed an option to allow new people to get on board.
I was thinking if there is at least 64K of block RAM then the 8 pit parts would be OK.
It looked like a pretty similar chip too, so the porting would not be too bad.
I liked the elegance of using the same level shifter board for both this project and Pi Direct.
Thanks for looking.
flynnjs
Postby flynnjs » Mon Mar 13, 2017 10:14 pm
To be fair, I've got something else in the pipeline which may allow people "to get on board".
It could also free some boards up as people might upgrade.
However, I've got LVROM drives to sort and a new computer to go into space before then
so I expect it won't be ready until xmas time.
trixster
Postby trixster » Tue Mar 21, 2017 7:12 pm
tricky wrote:That's great, just one little suggestion ;)
I'd like this too!
Postby hoglet » Sun May 14, 2017 6:31 am
Continued from:
viewtopic.php?p=169437#p169437
and
viewtopic.php?p=169449#p169449
dp11 wrote:Dave what ram speed it the copro expecting?
The x86 Co Processor is being clocked at 16MHz.
Which is somewhat overclocked I think for the RAM speed we have, but up until now there have been no reported issues.
It's very painful with Xilinx ISE to properly constrain a design that uses external asynchronous RAM, so I never attempted to do this with the Matchbox designs. So it is possible the path involving the asynchronous RAM includes considerable logic delays on the FPGA as well.
I did subsequently work out how to do this for BeebFPGA:
https://github.com/hoglet67/BeebFpga/bl ... uo.ucf#L57
but never went back and applied this to all the Matchbox designs.
dp11 wrote:With 70ns rev E chips tge x86 doesn't appear to work correctly some times you get ram faulty type 0/xxxx where xxxx appears to be random.
RevD ram at 70ns appear to work. Jason has tried all the usual tricks of adding extra decoupling etc.
I would suggest halving the clock rate to 8MHz, and see if that resolves this issue.
Here's a test build that does just that:
LX9CoProCombined_20170514_0720_dmb.zip
(1.89 MiB) Downloaded 10 times
The source for this is here:
https://github.com/hoglet67/CoPro6502/t ... _2017_test
(Only the x86 design has been changed here)
Note, it seems this 8MHz clock rate is slightly too slow as the language transfer on Ctrl-Break hangs. But it should still be useful for testing. Just do a normal break, then type DOS as the * prompt. If this resolves the issue, we can try 12MHz. The original Master 512 Co Processor is 10MHz I think.
Postby hoglet » Sun May 14, 2017 8:55 am
Here's a few more speeds to try:
10MHz:
LX9CoProCombined_20170514_0916_dmb.zip
(1.89 MiB) Downloaded 13 times
12MHz:
LX9CoProCombined_20170514_0941_dmb.zip
(1.89 MiB) Downloaded 15 times
14MHz:
LX9CoProCombined_20170514_0954_dmb.zip
(1.89 MiB) Downloaded 14 times
(10MHz is fast enough for the language transfer to work)
flynnjs
Postby flynnjs » Sun May 14, 2017 11:33 am
Dave,
thanks for that. I went straight for 12MHz build and x86 DOS is now 100% stable :D
The ARM is still very iffy. Does that push the RAM limits too?
Postby hoglet » Sun May 14, 2017 11:47 am
flynnjs wrote:Dave,
It runs at 32MHz with one wait state.
Adding a second wait state would be possible, but is more that a 5-minute job...
I could slow the whole thing down to 24MHz if you like.
Has the SRAM type changed on the most recent boards, or is it just a different batch that happens to be closer to spec (i.e. slower)?
I'm pretty sure I settled on 16MHz for all the external RAM based designs:
- Bank-switched RAM on the 6502
- 80x86
- 32016
- ARM2
- 68000
It does sound like all of these should be reduced to 12MHz.
Postby hoglet » Sun May 14, 2017 11:53 am
Edited above post.
flynnjs
Postby flynnjs » Sun May 14, 2017 12:01 pm
The latest are IS66WV51216EBLL-70
Previous had been IS66WV51216DBLL-70.
There could also be some with IS62 series too.
I have two identical PCBs one with the D revision RAM and another with the E revision.
The D is OK at 16 MHz and the is E isn't.
As an interim just running the whole ARM slower might be useful.
Postby hoglet » Sun May 14, 2017 12:03 pm
Actually, could you try the 6502, as it clocked at 64MHz but with 4 wait states added for external RAM accesses?
The only program I know that uses this is LIFE:
http://www.stardot.org.uk/forums/viewto ... 39#p154739
The program to run in MLIFE (Matchbox Life)
Test with the Turing Machine (it takes about a minute to load!)
I'll update the ARM now...
Postby hoglet » Sun May 14, 2017 12:08 pm
Actually, I can easily add an additional RAM wait state to the ARM, as I parametrized this:
https://github.com/hoglet67/CoPro6502/b ... ram32.v#L6
It will take about 30 mins to build this (and the x86 again at 12MHz).
Postby hoglet » Sun May 14, 2017 12:30 pm
Here's a build with:
- 80x86 running at 12MHz
- ARM2 running at 32MHz with two external RAM wait states
LX9CoProCombined_20170514_1320_dmb.zip
(1.89 MiB) Downloaded 18 times
flynnjs
Postby flynnjs » Sun May 14, 2017 5:37 pm
Thanks, that build seems 100% reliable on the rev E RAM.
The datasheet for the RAM gives the same timing figures but they've obviously changed something internally to make it less overclockable.
Return to “acorn atom”
