Matchbox sized 6502 / Z80 / 6809 Co Pro
Re: Matchbox sized 6502 / Z80 / 6809 Co Pro
Postby hoglet » Sun May 14, 2017 5:51 pm
flynnjs wrote:Thanks, that build seems 100% reliable on the rev E RAM.
Great.
Can I ask which Co Processors you were able to test?
flynnjs
Postby flynnjs » Sun May 14, 2017 6:10 pm
I checked each would boot and at minimum issued some star commands.
In the case of Z80 I also ran BASIC
In the case of x86 I also ran DOS
I didn't get time to exercise the paged RAM on 6502.
firthmj
Postby firthmj » Sun May 14, 2017 7:40 pm
Does that mean you would recommend this build if people are upgrading?
Had fun at the
Meeting 13th May 2017
flynnjs
Postby flynnjs » Sun May 14, 2017 8:39 pm
If you have RAM ending in EBLL, yes, you most definitely need to.
If you have RAM with DBLL then you may get away with slightly more aggressive speeds and use Dave's Nov '16 build.
Postby BigEd » Mon May 15, 2017 12:24 pm
Glad you got it working Jason! It seemed to be quite the puzzle when I dropped by.
firthmj
Postby firthmj » Mon May 15, 2017 9:20 pm
I've updated my CoPro this evening, and I'm seeing the dynamic mode switching lock up quite often
I've tried both the latest (LX9CoProCombined_20170514_1320_dmb) and previous stable (LX9CoProCombined_20161110_1455_dmb) designs, and both seem to behave similarly
It appears to only happen (so far) with the 6502 design.
The symptom is to switch between the various speeds of that and the NULL design (modes 0,1,2,3 and 14 in the firmware builds I'm using)
After a few such switches, the 6502 mode will "jam on", and it won't be possible to switch modes via the soft reconfiguration any more.
Reloading an old boot loader design .bit file with JTAG unlocks the switching for a while, but it will always lock up again quite quickly.
Switching between the ARM and NULL designs (12 and 14) doesn't seem to have the same problem.
Has anyone else seen this?
Is there anything different about the 6502 design that may make the dynamic switching less stable in it?
Had fun at the
flynnjs
Postby flynnjs » Mon May 15, 2017 10:14 pm
I've just soldered up a board for myself this evening (as I haven't had one for months!).
After programming it and testing it, I too noticed that and was mulling over why this
board was doing something that I hadn't seen this weekend.
Many of the boards I tested at Cambridge were defaulting to something other than
the 4MHz 6502 which may explain me not spotting it.
Postby hoglet » Thu Oct 05, 2017 12:27 pm
Hello all,
There is a new release of the Matchbox firmware available (20171003_0811):
https://github.com/hoglet67/CoPro6502/releases
I've also added all the significant past releases, so they are together in one place. For reference, most of Jason's boards shipped with the "20151215_1004" release.
Here's a quick summary of the changes:
- Co Pro 6502: updated speeds to 3, 4, 16, 64 MHz
- Co Pro 6809: Updated Client ROM to v1.05
- Co Pro PDP11: Updated Client ROM to v0.27a
- Be more conservative with timing within ICAP_core (might address some unreliability with *FX 151,230,N)
I'd be interested in feedback on the last item from anyone who has been having issues switching between different co processors.
Postby RobC » Fri Oct 06, 2017 3:50 pm
hoglet wrote:I'd be interested in feedback on the last item from anyone who has been having issues switching between different co processors.
Just upgraded my Matchbox boards. I have one of the red boards with decoupling mod and am using a 3-inch cable.
On my BBC B, switching between co-pros is okay apart from when switching from the ARM Co-pro (12) to something else. It seems to get stuck in the ARM copro and generally doesn't want to switch to anything else. This seems similar to what I was finding with the previous build.
On my Master 128, switching is better although it still gets stuck in the ARM Copro sometimes. However, it does seem better than the previous build as that seemed to get stuck most of the time.
Postby hoglet » Fri Oct 06, 2017 5:32 pm
Hi Rob,
RobC wrote:On my BBC B, switching between co-pros is okay apart from when switching from the ARM Co-pro (12) to something else. It seems to get stuck in the ARM copro and generally doesn't want to switch to anything else. This seems similar to what I was finding with the previous build.
Right, I've tracked down the reason the that the ARM2 Co Pro gets stuck, and I might be able to fix that. It's an issue that is specific to just that Co Pro.
Do you have any issues switching between any of the other Co Pros?
A good test is to program some of the function keys with *FX 151,230,N, and then that allows you to try lots of switching quite quickly.
Postby RobC » Fri Oct 06, 2017 8:37 pm
Hi Dave,
Not seen any problems switching between the other copros but I'll stress test it tomorrow.
Postby hoglet » Sat Oct 07, 2017 9:16 am
Hi Rob,
RobC wrote:Not seen any problems switching between the other copros but I'll stress test it tomorrow.
I've just pushed a new release (20171007_0719) that I hope will improve the configuration unreliability.
Please let me know if this resolves all the issues you are seeing.
Postby RobC » Sat Oct 07, 2017 3:48 pm
Hi Dave,
Just tested that release on my BBC 'B' and it all looks good =D> =D>
Changing from the ARM co-pro now works reliably - I spent 10 minutes flipping between processors and didn't see it fail once :D
Haven't tested it on a Master yet but, given the Beeb displayed the problem most often, I suspect all will be well.
Thanks,
Rob
Postby hoglet » Sat Oct 07, 2017 4:38 pm
RobC wrote:Just tested that release on my BBC 'B' and it all looks good =D> =D>
Excellent, thanks for testing it out.
trixster
Postby trixster » Sat Oct 07, 2017 9:25 pm
I'd like to update the firmware on my matchbox coprocessor but I'm not sure how. This might be a little cheeky but if I were to post it to one of you guys would you be able to flash it for me? I'd cover p&p both ways and pay for beer! :)
A3020 | A3000 | BBC B + 128K RAM/ROM + 20K Shadow + RPi2 CoPro + VideoNuLA
BBC Master Turbo + DC | Atom | A1200 060 | A500 | Jaguar | A420/1
A4000/040 060 | Atari Falcon 060 | Saturn | PS1 | SNES | CPC6128 | C64 | 3DO
Postby RobC » Sat Oct 07, 2017 9:35 pm
trixster wrote:This might be a little cheeky but if I were to post it to one of you guys would you be able to flash it for me?
Happy to do it for you. Send me a PM and we can arrange things.
Rob
trixster
Postby trixster » Sun Oct 08, 2017 8:20 am
Thanks rob, I'll PM you.
Return to “acorn atom”
Users browsing this forum: myelin and 2 guests
