Need an AtoMMC board
John Ferguson
Postby John Ferguson » Sun Nov 05, 2017 8:13 am
I am very interested in obtaining an AtoMMC board.
John
Re: Need an AtoMMC board
Postby CMcDougall » Sun Nov 05, 2017 12:35 pm
http://www.stardot.org.uk/forums/viewto ... 89#p162891
well, if you searched the forum :roll: ,then SirMorris /Charlie is your man 8)
his email is in that linky, if you can't PM yet...
Postby oss003 » Sun Nov 05, 2017 1:52 pm
Yes, Charlie is your man ..
http://www.stardot.org.uk/forums/viewto ... cts#p86259
John Ferguson
Postby John Ferguson » Fri Nov 10, 2017 4:27 pm
AtoMMC now received from Sirmorris.
John
Postby hoglet » Fri Nov 10, 2017 6:51 pm
John Ferguson wrote:AtoMMC now received from Sirmorris.
You can find the latest Atom Software Archive here:
https://github.com/hoglet67/AtomSoftwar ... e/releases
(the first of the Zip files is the one you want to use on a normal AtoMMC)
John Ferguson
Postby John Ferguson » Sun Nov 12, 2017 7:36 am
David
Thank you for the link to the archive.
I am so glad I found this forum.
John
John Ferguson
Postby John Ferguson » Sun Nov 12, 2017 5:37 pm
The AtomMMC now installed and working. A brilliant solution. All credit to Sirmorris
John
sirmorris
Postby sirmorris » Sun Nov 12, 2017 6:31 pm
8)
waltermixxx
Postby waltermixxx » Mon Nov 27, 2017 8:59 pm
hi there, somewhat related to the original poster's request....
are there two versions of the ATOMMC? one that uses a pic and one that connects via the VIA?
http://www.acornatom.nl/atom_handleidin ... om-nl.html
Do they both work the same way? :)
I'm hoping to get some kind of sd card/mmc interface for an Acorn Atom built so when I get an Acorn Atom, I am ready to go. :)
Cheers. :)
Postby roland » Mon Nov 27, 2017 9:08 pm
I'd advise the one with a pic. It works great and quite fast.
256K + 6502 Inside
sirmorris
Postby sirmorris » Mon Nov 27, 2017 10:11 pm
waltermixxx wrote:are there two versions of the ATOMMC?
No.
The first prototypes attached to PL7, and were bit-banged using the VIA. There have been no boards made like this for many years. All AtoMMCs are pic-powered.
C
waltermixxx
Postby waltermixxx » Tue Nov 28, 2017 12:32 am
are they still available as a kit and or pre built?
also can one save to the disk images from the Acorn?
I'm hoping to re-create the software i made when i was a kid... :)
and save it to a disk image. :)
Cheers. :)
sirmorris
Postby sirmorris » Tue Nov 28, 2017 6:47 am
Yes, still available. Pre-built only though. Disk image support is possible and also the ability to use individual files on the card. There is an (old but still relevant) manual online here. I should really update it :oops:
waltermixxx
Postby waltermixxx » Tue Nov 28, 2017 11:34 pm
Thank you, Ordered and payed for. Looking forward to playing around with it. :)
