How to use the programme atm2wav
John Ferguson
Postby John Ferguson » Sat Oct 28, 2017 4:35 pm
Is there any advice or even a video on how to use in a Command shell the programme to convert atm format files to wav format.
I am referring to the programme atm2wav.exe.
A typical line of the programme plus file reference would help me.
Currently I drag the programme into the command window but do not know how to go further.
John
vanekp
Re: How to use the programme atm2wav
Postby vanekp » Sat Oct 28, 2017 4:49 pm
AcornAtom>atm2wav /?
ATM2WAV V1.1.0
Produces a WAV representing a cassette image of the supplied ATM.
WAV will be 44.1khz, 16 bit, mono.
Usage: atm2wav atmfile[.atm] [options]
Options:
out= Output filename. Optional, defaults to <infile>.wav
unnamed Save as unnamed file.
short Short headers - 3 sec. instead of 5, reduced inter-block gap.
you need to open a DOS window and run it from there with parameters.
Postby oss003 » Sat Oct 28, 2017 5:01 pm
Hi John,
here is a screendump of an ATM conversion.
John Ferguson
Postby John Ferguson » Sun Oct 29, 2017 7:09 am
Thank you Kees.
The help on this forum is fantastic.
John
John Ferguson
Postby John Ferguson » Thu Nov 02, 2017 7:48 pm
Now able to convert files to wav format from atm types.
Programmes converted and successfully loaded onto the Atom.
This has been possible due to the help I received.
John
Postby oss003 » Thu Nov 02, 2017 8:38 pm
Nice job John, enjoy your Atom ...
Return to “acorn atom”
