Running ISE 14.7 on Windows 10
bprosman
Postby bprosman » Mon Sep 04, 2017 12:21 pm
As I am going to play with Roland's YARRB and Atom2015 (and some homebrew stuff) I was installing Xilinx 14.7 ISE on Windows 10 - 64 Bit.
Installing went smooth, unfortunately I only got the 32-Bit version to work.
Some Googling brought me to :
http://www.eevblog.com/forum/microcontr ... -8-64-bit/
Works like a charm, so now I have Xilinx AND Quartus working to play with the Altera EPM3064 as well.
Here I designed a memory mapper in schematic "language". Understood that preference goes to VHDL.
Kind regards, Bram
Re: Runnin ISE 14.7 on Windows 10
Postby hoglet » Mon Sep 04, 2017 1:14 pm
Well done! Xilinx do seem to go out of their way to make life difficult for their customers.
bprosman
Re: Running ISE 14.7 on Windows 10
Postby bprosman » Fri Sep 22, 2017 1:20 pm
To avoid hijacking Hoglets T65 topic I continue here.
As mentioned earlier, I am very new to programmable logic so apologies for the "Stupid questions" .
I got my Xilinx XC6SLX9 Mini Board from EEPIZZA.
When i connect it to USB I see its working. The leds nicely PWM 4 by 4.
When I start ISE 14.7, oad one of the example projects that came with the board , e.g. Barrel shifter and I hit : Re-run all I get the following error :
ERROR:Map:258 - A problem was encountered attempting to get the license for this
architecture.
I have acquired a : "Vivado design suite : HL Webpack 2015 and earlier license.
They show up as follows :
# ----- REMOVE LINES ABOVE HERE --------------------------
# This license is valid from Thu Sep 21 12:49:24 UTC 2017.
# This is license NODELOCKED to HOSTID=ANY;
# there is no need to run lmgrd for this license.
# This is a permanent license generated on Thu Sep 21 12:49:24 UTC 2017
INCREMENT SDK xilinxd 2018.09 permanent uncounted 69E25740F2B2 \
VENDOR_STRING=bprosman,SDK,software,permanent,_211029524_0_0_246 \
HOSTID=ANY ISSUER="Xilinx Inc" START=21-Sep-2017 TS_OK
INCREMENT Analyzer xilinxd 2018.09 permanent uncounted 4E2BED41DD8A \
VENDOR_STRING=bprosman,Analyzer,software,permanent,_211029524_0_0_048 \
INCREMENT HLS xilinxd 2018.09 permanent uncounted EA5A0DF35692 \
VENDOR_STRING=bprosman,HLS,software,permanent,_211029524_0_0_725 \
INCREMENT V_WebPACK xilinxd 2018.09 permanent uncounted 82C998995A1D \
VENDOR_STRING=bprosman,V_WebPACK,software,permanent,_211029524_0_0_422 \
# ----- REMOVE LINES BELOW HERE --------------------------
Postby hoglet » Fri Sep 22, 2017 2:27 pm
This looks like the wrong license to me (oh why do Xilinx make this so difficult????)
See these posts:
http://www.stardot.org.uk/forums/viewto ... 43#p176243
bprosman
Postby bprosman » Fri Sep 22, 2017 2:52 pm
Thanks dave, that did the trick :D
Just programmed my first "Barrel shift" program and it works :D
Now the next step, your ICE-T
Return to “acorn atom”
