CMT 4 ROM Board
simoni
CMT 4 ROM Board
Postby simoni » Sat Jul 01, 2017 4:45 am
There was a CMT 4 ROM board mounted in the Acorn Atom that I recently restored:
As you can see in the picture, one of the ICs has been scratched to hide the markings. Since I like the 'originality' of the hardware I decided to restore it too and also reverse engineer the circuit. The 'mystery IC' is a SN54LS75. Attached are 600 DPI scans of the PCB (both sides), the single-sheet user manual and a KiCAD schematic of the board (untested - drawn mainly to help identify the unmarked IC).
I'm including it all here in case someone else finds one of these boards (I can't find any references to them via Google).
/Simon
CMT ROM Board Schematic - Acorn Atom.pdf
(60.01 KiB) Downloaded 12 times
CMT ROM Board Manual - Acorn Atom.pdf
(55.95 KiB) Downloaded 12 times
Multiwizard
Re: CMT 4 ROM Board
Postby Multiwizard » Sat Jul 01, 2017 6:50 am
Hi Simon,
nice board... :D
Several years ago one of the Atoms I received also had a (for me) unknown switchboard inside... :-k
Last year I build it in my Acorn ABM... 8)
Greetings, Wim... :-)
simoni
Re: CMT 4 ROM Board
Postby simoni » Sat Jul 01, 2017 7:03 am
Hi Wim
I did finish restoring the board; but I didn't think to post any pictures of it after the work was done :)
Here's the top-side:
And here's the underside:
It's designed to sit directly in the IC24 socket with a single wire to the R/!W line of the program RAM. I haven't put it back in the Atom yet as I'm still working on the machine (just some minor testing to go).
The design of the board you posted is certainly interesting; I like the big semi-circle of tracks between the IC rows, looks funky even if it breaks the golden-rule of keeping IC orientation constant ;)
/Simon
Multiwizard
Re: CMT 4 ROM Board
Postby Multiwizard » Sat Jul 01, 2017 7:10 am
Nice restoring... :D
Is it me or did you turn the four 24pin sockets 180 degrees?
simoni
Re: CMT 4 ROM Board
Postby simoni » Sat Jul 01, 2017 7:20 am
The original sockets had rough edges at the bottom (where the plastic was snapped from the mould) which looks a little like a orientation tab, but it's not. On the PCB you can see the little '1' markers showing the correct orientation. The new sockets are the right way round; and much easier to see the marker :)
Re: CMT 4 ROM Board
Postby daveejhitchins » Sat Jul 01, 2017 7:26 am
Multiwizard wrote:Is it me or did you turn the four 24pin sockets 180 degrees?
No, they're OK, pin 1 is marked - So it's you :lol:
Multiwizard
Re: CMT 4 ROM Board
Postby Multiwizard » Sat Jul 01, 2017 8:23 am
Thanks dave :mrgreen: I knew something was wrong... :lol:
Return to “acorn atom”
