New Atom owner
trixster
New Atom owner
Postby trixster » Mon Mar 27, 2017 1:23 pm
I've been reading the Atom forum with interests and no small amount of envy for quite some time. You all seem to be having a lot of fun. So for some reason I've decided to join in.
I picked her up this morning. Outwardly she's a little grubby but otherwise looks in decent enough nick. Here are some photos of the outer and the inners. I'm not going to power her up - I'm going to send her off for a full health check first.
Grubby
trixster
Re: New Atom owner
Postby trixster » Mon Mar 27, 2017 1:25 pm
More photos
trixster
Re: New Atom owner
Postby trixster » Mon Mar 27, 2017 1:26 pm
And then a final quick once over
So can someone tell me what I've got here. Some of the photos show some dodgy looking soldering. I can't see any voltage regulators.
Re: New Atom owner
Postby oss003 » Mon Mar 27, 2017 1:42 pm
Nice catch .... =D>
Looks like 2 crucial IC's are missing, IC49 (address decoder) and IC20 (MOS/Basic).
Without these chips, the Atom won't do anything.
Multiwizard
Re: New Atom owner
Postby Multiwizard » Mon Mar 27, 2017 1:49 pm
Oh, nice Atom... =D>
A check-up first will be indeed wise.
Missing voltage regulators are not a problem as long you give him a stable 5V input... 8)
They indeed have played about with a soldering iron :( , that's why a check-up is the best step... :D
Atom gurus enough on this forum, I can't wait to see him say on the screen, HELLO WORLD \:D/
Greetings, Wim... :-)
Re: New Atom owner
Postby hoglet » Mon Mar 27, 2017 1:49 pm
You have got a issue 5 Atom with the regulators bypassed (and removed) so it will run off 5V. This is the best issue to have, as it has a much better keyboard.
It's got 12K of RAM.
It looks like the bus buffers have been bypassed, which makes me think possibly someone was running this with an external ROM box of some sort.
Unfortunately, it seems to be missing the 8K Basic/OS ROM. This is hard to replace, because no pin-compatible EPROM exists. You might find one of our Dutch friends has a spare (from an old Atom that was sliced in half). Otherwise, you'll need to source a 28-pin to 24-pin ROM adaptor board.
trixster
Re: New Atom owner
Postby trixster » Mon Mar 27, 2017 1:59 pm
Thanks chaps!
No ROM! No decoder! Oh no, that's not good. Someone's cut a hole in the back as you can see, so I guess that's where an external rom box might have been connected.
So, anyone got a spare ROM and decoder!!?? [-o<
trixster
Re: New Atom owner
Postby trixster » Mon Mar 27, 2017 2:04 pm
Would this 24->28 pin adaptor work?
https://www.ebay.co.uk/itm/381290053308
Multiwizard
Re: New Atom owner
Postby Multiwizard » Mon Mar 27, 2017 2:05 pm
If I'm not wrong it's:
IC20 MM52164 (If no one else has, I have a spare one...)
IC49 74LS139
Greetings, Wim...;-)
trixster
Re: New Atom owner
Postby trixster » Mon Mar 27, 2017 2:07 pm
This area is messy. Does it look like the correct links have been modded to allow a 5v psu?
Actually, I think they've been soldered on the other side!
trixster
Re: New Atom owner
Postby trixster » Mon Mar 27, 2017 2:09 pm
Multiwizard wrote:If I'm not wrong it's:
IC49 74LS139
Blimey Wim, if you wouldn't mind then that would be amazing! Let me know what you would like in return if you're happy to send it across.
Andy
Re: New Atom owner
Postby roland » Mon Mar 27, 2017 2:11 pm
I will have a look for a spare rom, but it's quite easy to replace it with a 2764 eprom.
Edit: I just saw that Wim also has one available.
The main board has some damages but its condition is good enough to get this Atom working.
256K + 6502 Inside
Multiwizard
Re: New Atom owner
Postby Multiwizard » Mon Mar 27, 2017 2:18 pm
Andy
Just p&p
trixster
Re: New Atom owner
Postby trixster » Mon Mar 27, 2017 2:24 pm
roland wrote:I will have a look for a spare rom, but it's quite easy to replace it with a 2764 eprom.
That's really good to hear, thanks Roland!
trixster
Re: New Atom owner
Postby trixster » Mon Mar 27, 2017 2:25 pm
Multiwizard wrote:
Andy
Just p&p
You, Sir, are an absolute gentleman of the highest order. I'll send you a PM.
Multiwizard
Re: New Atom owner
Postby Multiwizard » Mon Mar 27, 2017 2:38 pm
It's already packed... 8)
Would you like it with (€ 11,95) or without (€ 1,33) Track & Trace?
trixster
Re: New Atom owner
Postby trixster » Mon Mar 27, 2017 2:43 pm
I guess "With" is safest just to be sure the Royal Mail doesn't drop the ball! PM sent with my details.
Andy
trixster
Re: New Atom owner
Postby trixster » Mon Mar 27, 2017 6:07 pm
74LS139 ordered.
I've found a 5v 2a psu with a connector that fits nicely. Will 2a be enough with 12k of ram installed?
Re: New Atom owner
Postby oss003 » Mon Mar 27, 2017 6:13 pm
2A is ok, just check if the + and - are on the right postion.
Multiwizard
Re: New Atom owner
Postby Multiwizard » Mon Mar 27, 2017 6:14 pm
trixster wrote:74LS139 ordered.
Upsy, I don't know if it will work but I also did put a 74HC139 into the envelope... 8)
trixster
Re: New Atom owner
Postby trixster » Mon Mar 27, 2017 6:19 pm
You're a good man! :D
Re: New Atom owner
Postby roland » Mon Mar 27, 2017 6:44 pm
trixster wrote:You're a good man! :D
He's the best Multiwizard we have on this forum :lol:
256K + 6502 Inside
Re: New Atom owner
Postby oss003 » Mon Mar 27, 2017 6:48 pm
Trixster,
I think this Atom needs a good cleanup and the best way to do this is clean the areas around the bad soldering points and check if the tracks and connections are ok. The video circuit (around Q1 and Q2) and the printer connector (PL5) need a good inspection and cleanup.
I also noticed C11 and C12 are missing.
C11 is a 10 uF elco needed for a delay in the BREAK circuit and
C12 is a 22 uF elco mounted in the power circuit.
You can find information about the parts here:
http://www.acornatom.nl/atom_handleidin ... atm_07.htm
http://www.acornatom.nl/atom_handleidingen/atm/atm.htm
http://www.acornatom.nl/atom_handleidin ... .htm#PARTS
trixster
Re: New Atom owner
Postby trixster » Mon Mar 27, 2017 6:52 pm
Hi Kees, thanks for the details!
So, the good news is out very own TheCorfiot has agreed to take the Atom under his wing and breath life into her. I consider this to be a very good thing! :D He's going to recap my Falcon too so I hope no one else is after much from him for the next few weeks ;)
The plan is to obtain an AtoMMC, a Colour Board and a Ram/Rom upgrade, and in orde to facilitate this PM's have been sent to the resident forum hardware gurus! =D>
Re: New Atom owner
Postby oss003 » Mon Mar 27, 2017 6:56 pm
Yes, we can rebuild him, we have the technology!!
We can make it better than it was before, better...stronger...faster
:lol: :lol: :lol:
trixster
Re: New Atom owner
Postby trixster » Mon Mar 27, 2017 6:58 pm
Kees, a large part of my desire to get an Atom in the first place is to play your Atomic Elite! So to make that happen we have to deploy our best resources on the task! :)
Re: New Atom owner
Postby oss003 » Mon Mar 27, 2017 7:01 pm
Yep ... =D>
Here is some more information about Atomic hard- and software.
http://www.stardot.org.uk/forums/viewto ... ard#p86259
TheCorfiot
Re: New Atom owner
Postby TheCorfiot » Mon Mar 27, 2017 7:15 pm
Hi Wim
you wouldnt have a spare heatsink bracket you could pop in the envelope for trixter too please.
i dont plan on fitting voltage regulators but these brackers are a great place to mount a 6 pin RGB socket :)
Thanks in advance my friend.
Multiwizard
Re: New Atom owner
Postby Multiwizard » Mon Mar 27, 2017 7:44 pm
TheCorfiot wrote:Hi Wim
I just looked around/searched on my attic, sorry no... :(
Re: New Atom owner
Postby roland » Mon Mar 27, 2017 8:10 pm
I have one. I can send it to Wim if he hasn't posted the ic's already....
256K + 6502 Inside
Return to “acorn atom”
