Atom to gonbes gbs8200
trixster
Postby trixster » Sun Mar 26, 2017 9:31 pm
I'm about to collect an Atom (hoorah!) and I'd like to connect it to my gbs8200. I'm assuming I'll have to make up a cable, so what would be the pinout to get it working?
Thanks!
Re: Atom to gonbes gbs8200
Postby danielj » Sun Mar 26, 2017 9:34 pm
It doesn't do composite unfortunately :( - but if you have an colour card in outputting RGB you can use it?
trixster
Postby trixster » Sun Mar 26, 2017 10:00 pm
I won't know what it has until I collect it tomorrow! Fingers crossed it'll be full of nice stuff (although I seriously doubt it).
But if it doesn't have a colour card I guess I'll have to get hold of one as in my loft where the Atom will live I will only be able to connect it through the gbs8200 or through composite.
Postby danielj » Sun Mar 26, 2017 10:08 pm
You can get cheapy composite / svideo to vga adaptors for very little iirc?
trixster
Postby trixster » Sun Mar 26, 2017 10:12 pm
danielj wrote:You can get cheapy composite / svideo to vga adaptors for very little iirc?
I have a couple of those cheaply composite / svideo to VGA adapters - they're terrible! I used them as a stop-gap until I got a monitor which has svideo and composite in (the dell 2001fp) and an svideo out mod for my cpc6128.
Postby danielj » Mon Mar 27, 2017 5:21 am
It'll be mono out of the atom, so won't look too bad (it looks pretty bad normally!), but if you have a monitor that takes composite then you'll be fine.
Postby hoglet » Mon Mar 27, 2017 7:21 am
Andy,
When I first joint stardot I got rather obsessed with Atom colour boards.
One of the designs is very simple: it uses a couple of transistors to create a YPrPb signal from PL4 than can be fed into a GB8200.
Details here:
viewtopic.php?p=59728#p59728
This is the simplest way I know of to get a colour output from an Atom.
trixster
Postby trixster » Mon Mar 27, 2017 8:08 am
Thanks for the link Dave, very interesting!
I'll take the Atom apart this afternoon and have a look inside. Who knows, it might have a colour board already fitted. If not i'll investigate getting hold of a new one as I guess this is the way to go.
Andy
