Don't have a desolder station or hot air gun!
Postby daveejhitchins » Sun Dec 31, 2017 12:59 pm
Try this: Halogen
May get you out of a hole . . . Let us know how you get on 8)
Re: Don't have a desolder station or hot air gun!
Postby CMcDougall » Sun Dec 31, 2017 1:15 pm
:shock: goes and gets 12v car battery out..... :lol:
Postby 1024MAK » Sun Dec 31, 2017 2:09 pm
Ahh, someone else watching Kasyan TV videos :mrgreen:
Postby roland » Sun Dec 31, 2017 2:25 pm
It looks quite easy in this film - even for people who have a desolder station and hot air gun. Did anyone here try this at home? (My wife is out of town with the car otherwise I'd try it immediately :mrgreen: )
256K + 6502 Inside
duikkie
Postby duikkie » Mon Jan 01, 2018 1:33 pm
is it the heat from the lamp or the light (wavelength) ?
if heat what i think then a hot air gun is beter .
Postby daveejhitchins » Mon Jan 01, 2018 2:01 pm
duikkie wrote:is it the heat from the lamp or the light (wavelength) ?
UV heat - see the video . . . And, if you haven't a hot air gun to hand?
duikkie
Postby duikkie » Tue Jan 02, 2018 7:03 am
heat is heat !!! so it is not the uv wavelength that melts the solder , but the production of heat by the uv light.
i think any other bolt will do then 100 w ?
Postby BigEd » Tue Jan 02, 2018 7:52 am
I think the car headlight halogen has two advantages over any ordinary 100w bulb: it's halogen, so the filament is hotter, so there's more infra red than from an ordinary filament; it has a metal reflector so you get the heat from the back of the filament too.
An ordinary domestic halogen has a dichroic reflector which allows heat out the back while sending the light out the front.
duikkie
Postby duikkie » Tue Jan 02, 2018 10:16 am
the point is it is still the heat not the light that makes de solder weak.
so because the light/heat ratio is so poor , you can desolder.
Postby BigEd » Tue Jan 02, 2018 10:40 am
Yes, I'd agree that it's the IR, not the visible or the UV, which is most important here.
duikkie
Postby duikkie » Tue Jan 02, 2018 11:28 am
totally off subject but what is the melting point of solder ?
i am thinking about hot oil for desolder things ?
Postby daveejhitchins » Tue Jan 02, 2018 12:03 pm
duikkie wrote:totally off subject but what is the melting point of solder ?
Google says:
Alloys commonly used for electrical soldering are 60/40 Sn-Pb, which melts at 188 °C (370 °F)
The typical reflow temperature range for Pb-Free (Sn/Ag) solder is 240-250°C with 40-80 seconds over 220°C
duikkie wrote:i am thinking about hot oil for desolder things ?
Ooooow! Messy!
Postby 1024MAK » Tue Jan 02, 2018 12:50 pm
Although, you want the heat to be a bit higher that those values, so that the solder flows better. Also, the material that the solder is soldered to makes a little bit of a difference.
Postby CMcDougall » Tue Jan 02, 2018 1:42 pm
^true, my hot air solder leveler at old work was set at 250-260 (ran like water & through a pump) so could dip whole boards (1/2m 2) if went below 250 it would 'not be shinny' & holes not at correct size
Also gold melts at 1064oC but never used that much apart from making mobile phones, & fingers for better connection's on 'add ons'
Postby crj » Tue Jan 02, 2018 5:55 pm
I got my electric hot air gun on eBay for about twenty quid. I only use it for heat-shrink sleeving, but I imagine it might work for desoldering, too.
By the time you've messed around with a way to hold the bulb without getting fingerprint grease on it or burning your fingers, plus a way to power it, I'm not sure the halogen bulb trick is much cheaper?
Postby 1024MAK » Tue Jan 02, 2018 7:35 pm
An electric paint stripper hot air "gun" works well if an appropriate nozzle is used. At least for desoldering. Both SMD chips and through hole chips.
jonb
Postby jonb » Wed Jan 03, 2018 8:27 am
I found a hot air gun (paint stripper) could remove a bank of DRAM from a PET motherboard, but it nearly ruined the board, even with the narrow nozzle. That's when I bought a Duratool desoldering station.
duikkie
Postby duikkie » Wed Jan 03, 2018 12:05 pm
A narrow nozzle is to hot mostly i use the big one or gun futher away
jonb wrote:I found a hot air gun (paint stripper) could remove a bank of DRAM from a PET motherboard, but it nearly ruined the board, even with the narrow nozzle. That's when I bought a Duratool desoldering station.
