Adventure games to put to disc.
duikkie
Re: Adventure games to put to disc.
Postby duikkie » Fri Dec 19, 2014 9:07 am
i uploaded the : one file only gordon in game item ( maybe moved ?? )
billcarr2005
Postby billcarr2005 » Sun Dec 21, 2014 11:19 am
leenew wrote:**I believe BillC may have a disc version of "Not a Penny More"... Am I right Bill? :D
Sometimes you know (remember) more of my collection than me! :P
Yes, i've got this... it's protected with some tracks with deleted data, and curiously doesn't work properly with the latest cobbled together FSDBeebEM... but i've found an older version which it's happy with, so will try to look at it ASAP (unless it appears before that) :)
billcarr2005
Postby billcarr2005 » Fri Dec 26, 2014 12:33 pm
Not A Penny More Not A Penny Less
The protection overreads a sector and expects a certain value to be in the overread location.
I've not playtested it extensively.
Not A Penny More Not A Penny Less.zip
(45.54 KiB) Downloaded 70 times
Postby leenew » Sun Dec 28, 2014 6:56 pm
Brill. :D
Thanks BillC.
@cleverpeople.... don't forget the other uef 's at the beginning of this thread that need discifying
:D
Lee
Postby CMcDougall » Mon Dec 29, 2014 1:33 pm
here is Demon Knight, it seems to work, and in the proggy, if PAGE=&E00 then thinks its still on tape, so maybe was ready for an easy tape>disc 8)
Mystery of sheep already here:
http://www.stairwaytohell.com/filesearc ... rch=Search
DemonKnight-ASP.zip
ssd
(12.58 KiB) Downloaded 49 times
Postby CMcDougall » Mon Dec 29, 2014 1:52 pm
hobbit2, well last file is a bit to large for a normal beeb, and can't mind how to turn *Shadow on in a master :roll: plus would also need swram to get it >&8000 so can save it to disc, as the *CAT would end up all over the code at E00 or 1900.
here is it so far, but last file HOBGAME will have errors due to screen junk...
pic
may just be same as the other version 1.00 :?
TheHobbit2.zip
ssd with errs
(23.52 KiB) Downloaded 47 times
Postby leenew » Fri Oct 07, 2016 9:00 am
Can anyone confirm if this disc image from the STH archive of "Dr. Who And The Warlord" works on their install of BeebEm, BEm, or real beeb, or master...
In fact does it work for anyone at all?
http://www.stairwaytohell.com/bbc/archi ... arlord.zip
Lee.
Lardo Boffin
Postby Lardo Boffin » Fri Oct 07, 2016 10:14 am
leenew wrote:Hi,
Lee.
I tried it on BeebEm and it runs ok for the most part. It loads a part A or part B menu and then if you select part A it briefly shows you a nice loading screen which quickly turns garbled.
If you press enter you then start the game. I have wandered around a bit and it seems ok. I got as far as killing myself trying to climb a ravine.
Part B does the same with the menu. It then asks you if you want to load from part A. I said no and it launched ok.
Lardo
Postby lurkio » Fri Oct 07, 2016 10:37 am
Lardo Boffin wrote:
leenew wrote:Can anyone confirm if this disc image from the STH archive of "Dr. Who And The Warlord" works on their install of BeebEm, BEm, or real beeb, or master... In fact does it work for anyone at all http://www.stairwaytohell.com/bbc/archi ... arlord.zip
I tried it on BeebEm and it runs ok for the most part. It loads a part A or part B menu and then if you select part A it briefly shows you a nice loading screen which quickly turns garbled. If you press enter you then start the game. I have wandered around a bit and it seems ok. I got as far as killing myself trying to climb a ravine. Part B does the same with the menu. It then asks you if you want to load from part A. I said no and it launched ok.
What version of BeebEm are you using? What config?
I can't get the game to run in BeebEm at all. It hangs on the garbled screen after I choose Part A from the menu.
You have to press Return at the garbled screen, and then the game runs!
Postby leenew » Fri Oct 07, 2016 11:43 am
"You have to press Return at the garbled screen, and then the game runs!".....
Oh! :roll:
Lee.
Lardo Boffin
Postby Lardo Boffin » Fri Oct 07, 2016 6:22 pm
Sometimes random mashing of the keys does work.
Return to “adventures”
