who every played OXBRIGDE from tynsoft
duikkie
Postby duikkie » Mon Jun 23, 2014 5:56 am
because you can call it an adventure game
maybe someone here every played the game from tape ?
i fixed it for disc but can't play it
it give a lot of errors
help do not work
inv place you sometime somewhere else ?
somebody know if this game
was some project that gone bad ??
or
could you buy it in 1980-1990 in store ??
Re: who every played OXBRIGDE from tynsoft
Postby hoglet » Mon Jun 23, 2014 6:25 am
Is your version the same as the one here?
http://oldwww.nvg.ntnu.no/data/bbc/sw/T ... bridge.zip
There is a hint sheet here:
http://solutionarchive.com/file/force%2 ... de%2Cfile/
duikkie
Postby duikkie » Mon Jun 23, 2014 10:55 am
no access to hint side ? can you make a copy here ??
zip file i will look if it is the same
i got my from the eoo list somewhere ??
hoglet wrote:Is your version the same as the one here?
duikkie
Postby duikkie » Mon Jun 23, 2014 1:19 pm
oke this game is working on e00 as the programmers want to
i don't like bbcim :evil: , but at last i have it on ssd :)
now i can change the game to run on normal beeb b with dfs and pa.=1900
duikkie
Postby duikkie » Tue Aug 05, 2014 5:50 am
i fixed it , saving the game is gone. because downloading to 1100 and openup needs 1300.
but you can play it now from disc/mmc card
duikkie wrote:oke this game is working on e00 as the programmers want to
Postby richardtoohey » Tue Aug 05, 2014 5:59 am
Can't you "just" convert it to use SWRAM? :wink: :shock: :twisted:
duikkie
Postby duikkie » Tue Aug 05, 2014 6:27 am
what is SWRAM ?? sideway ram and how is basic there running ?? specs please :)
because i don't have SWRAM i don't know how it works.
but the basic i wrote for this game is normaly basic from &1100, the second part also runs on &1100 overriding the first. you may have a problem
because openup works from 1100--1300.
richardtoohey wrote:Can't you "just" convert it to use SWRAM? :wink: :shock: :twisted:
