Beebem teletext hold char (158) issue
spark001uk
Postby spark001uk » Fri Nov 24, 2017 2:44 pm
Been having a problem reproducing some teletext images from within beebem; I'm running into the issue with the "hold graphics" (158 / 0x9E) control code. When I change colour, it's repeating the correct character but in the new colour rather than the old one, it needs to apply the colour to the next byte, not the current one. I understand this is a known issue with beebem, but wanted to know has anyone released a "fixed" version yet?
I did find this github entry whilst looking around, it mentions a fix at the top of the page, and there's something about it in the code around the 720ish mark. But what do I do with this code? Is it a fix to the hold graphics problem? Would it have to be compiled back into a new beebem package or something? Not sure myself, all I know is it looks like C++.
guesser
Re: Beebem teletext hold char (158) issue
Postby guesser » Fri Nov 24, 2017 4:31 pm
Indeed colour codes should be Set-After. While someone's at it they should probably "fix" the bug that it doesn't correctly emulate the SAA5050's buggy hold mosaics, as noticed at the beginning of the year by kieranhj (though I've since discovered that it's been "known" for years just not widely)
guesser
Postby guesser » Fri Nov 24, 2017 4:45 pm
oh, looking at the code, the most recent commit is a fix for the set-after colour issue!
Postby chrisn » Fri Nov 24, 2017 4:53 pm
I believe this issue is fixed in the latest code in GitHub, but we haven't released a new binary with this fix included, so you'll still see the issue if you're using BeebEm 4.14 or earlier.
I should really get on releasing the new version soon... :-
guesser
Postby guesser » Fri Nov 24, 2017 5:02 pm
I'm going to have a go at building from source and playing around in the teletext code a bit IF VS BUILD TOOLS EVER FINISHES DOWNLOADING :evil:
Maybe I should start porting the project to mingw and see which is completed first :lol:
guesser
Postby guesser » Fri Nov 24, 2017 8:41 pm
hurrah! It took much gnashing of teeth and downloading the wrong things incredibly slowly off the Microsoft servers but I got there in the end.
In case anyone's mad enough to fancy doing the same here's the links to the tools I ended up installing for it to work:
http://landinghub.visualstudio.com/visu ... uild-tools and https://www.microsoft.com/en-gb/downloa ... px?id=6812
Now to start fiddling with the code to see if I can break it :)
Matt Godbolt
Postby Matt Godbolt » Fri Nov 24, 2017 8:52 pm
Glad to report this works OK in jsbeeb too (As best I can tell): https://bbc.godbolt.org/?autorun&loadBa ... tfile1.txt
Pernod
Postby Pernod » Fri Nov 24, 2017 9:04 pm
... and MAME is good too!
guesser
Postby guesser » Fri Nov 24, 2017 9:15 pm
It suffers the same issue as BeebEm though of not emulating the SAA5050's bug :)
I'll have to create a test page for someone who's got their beeb set up to properly nail down exactly what the SAA5050 does.
guesser
Postby guesser » Fri Nov 24, 2017 9:17 pm
MAME might get the bug part right as I seem to recall the guy I was talking to on twitter mentioning MAME.
Try 145 255 158 146 147 148
Pernod
Postby Pernod » Fri Nov 24, 2017 9:23 pm
guesser wrote:MAME might get the bug part right as I seem to recall the guy I was talking to on twitter mentioning MAME.
Who were you talking to on twitter?
Edit: Both match real Beeb.
guesser
Postby guesser » Fri Nov 24, 2017 9:46 pm
Oh, hrm, I must have got the sequence wrong then. Working from memory.
It was someone who's written a SAA5050 emulation who went deep on getting the character rounding and everything perfect, I asked him about the hold thing and he said he discovered it years ago.
I'm just digging up old posts so I can provide a proper test case.
guesser
Postby guesser » Fri Nov 24, 2017 9:49 pm
Try this one:
145 255 157 158 156 157 156 157
guesser
Postby guesser » Fri Nov 24, 2017 9:57 pm
Ah, found the twitter message again, it's not his code in MAME, he was just mentioning how long it took for font smoothing to be added.
Pernod
Postby Pernod » Fri Nov 24, 2017 10:17 pm
guesser wrote:Ah, found the twitter message again, it's not his code in MAME, he was just mentioning how long it took for font smoothing to be added.
Makes sense as it was me that added it a few years ago. It is heavily 'influenced' on b-em and jsbeeb so expect it to match those.
guesser wrote:Try this one:
I see a difference with this, emulation produces a solid block but real hardware has two gaps in it.
guesser
Postby guesser » Fri Nov 24, 2017 10:25 pm
Pernod wrote:I see a difference with this, emulation produces a solid block but real hardware has two gaps in it.
Yup, that's the bug. The question now is what exactly causes it to occur. I had obviously misremembered from Feb as I thought it was a case of the 5050 not committing a character until after the first hold code, but clearly it's not. Actually something to do with the black background code (at least in this case)
what if instead a new background (156) at the end you but a sequence of mosaic colour codes. Does it display the held char correctly or has it been reset?
We could really do with a screen containing an exhaustive combination of control codes and hold mosaics.
guesser
Postby guesser » Fri Nov 24, 2017 10:26 pm
what if instead a new background (157) at the end you but a sequence of mosaic colour codes. Does it display the held char correctly or has it been reset?
We could really do with a screen containing an exhaustive combination of control codes and hold mosaics.[/quote]
Postby hoglet » Fri Nov 24, 2017 10:26 pm
Nigel,
Have you tried running the Ceefax Test card program, from this thread?
http://www.stardot.org.uk/forums/viewto ... f=4&t=4686
This was invaluable for improving the SAA5050 implementation in Beeb FPGA.
guesser
Postby guesser » Fri Nov 24, 2017 10:30 pm
hoglet wrote:Nigel,
This particular bug doesn't show up from that test card because there is no hold mosaics in force in the areas with background colour. It was only because Kieran's image conversion algorithm kept generating those crazy sequences of new background/black background that you'd never do on purpose that we noticed it :)
EDIT: the now fixed one from the original post would of course.
Pernod
Postby Pernod » Fri Nov 24, 2017 10:30 pm
hoglet wrote:Have you tried running the Ceefax Test card program, from this thread?
Yeah, that's emulated perfectly as far as I know. This bug is not apparent on the test card.
tom_seddon
Postby tom_seddon » Sun Nov 26, 2017 4:50 pm
After some experimentation it looks like control codes reset the held mosaic char when hold mosaics are off. Demo attached - load disc, CHAIN"HOLD2". It just shows VDU 145,97,n,158, where n is each control char in turn. (8 control chars per page. Press a key to get to the next page.) When n is 158, you get 3 copies of mosaic 'a'; in other cases, you get 1.
(You can see that 157 resets it too by doing something like VDU 147,97,157,158,156,97.)
I've sent a pull request for jsbeeb that I think fixes it: https://github.com/mattgodbolt/jsbeeb/pull/157 - with this minor change, running HOLD2 gives you the same thing on jsbeeb as you get on my Master 128. 145 255 157 158 156 157 156 157 looks correct too.
--Tom
mode7.zip
(444 Bytes) Downloaded 9 times
guesser
Postby guesser » Sun Nov 26, 2017 5:51 pm
Excellent. I'll have a crack at a BeebEm patch.
Incidentally I've found another bug in BeebEm which is that an alphanumerics code isn't clearing the held character.
guesser
Postby guesser » Sun Nov 26, 2017 6:34 pm
I've had a go at fixing BeebEm and fixed a couple of other issues while I was at it such as rendering the held character with the correct separated mosaics mode.
Here's the patch: <removed>
Edit: still no quite right, but getting closer
guesser
Postby guesser » Sun Nov 26, 2017 10:03 pm
The test card I'm using is here: http://temp.zxnet.co.uk/teletext.ssd
Could someone upload a photo of that displaying on a real beeb?
tom_seddon
Postby tom_seddon » Sun Nov 26, 2017 10:32 pm
Image attached, for whatever it's worth... my phone's camera is awful at taking CRT shots (and having me as the operator doesn't help). The four separated graphics bars at the top right are, from left to right, green, magenta, red and blue, but I think everything else looks roughly right.
The text "* Box" at the bottom is flashing.
--Tom
guesser
Postby guesser » Sun Nov 26, 2017 10:44 pm
tom_seddon wrote:Image attached, for whatever it's worth... my phone's camera is awful at taking CRT shots (and having me as the operator doesn't help). The four separated graphics bars at the top right are, from left to right, green, magenta, red and blue, but I think everything else looks roughly right.
Yup that's great thanks, I can see all the bits I need to clearly enough.
My current iteration of the code is closer to that but still not quite there. I'm almost tempted to just rip out the whole character row decoding loop and port my own teletext renderer code over from javascript cause I know my algorithm works :)
Just the cyan blocks at the top left to sort out now, and fix conceal which I seem to have broken
guesser
Postby guesser » Sun Nov 26, 2017 11:58 pm
Think I might be there unless anyone can come up with any other tests.
Here's the testcard:
A patch against the current github master: http://temp.zxnet.co.uk/0001-mode7-fixes.patch
Postby leenew » Mon Nov 27, 2017 12:52 am
That's great! When are we likely to see this incorporated into an official BeebEm release?
Lee.
Postby chrisn » Mon Nov 27, 2017 4:54 pm
leenew wrote:That's great! When are we likely to see this incorporated into an official BeebEm release?
Yes, great work indeed :D I'll do some tests and will be happy to merge the patch.
Over the weekend I merged the fixes that JGH submitted, while keeping the emulator filing system traps code (which needs more work to complete) on a branch.
This means that the next major BeebEm release is about ready to go. I'll prepare binaries and contact Mike about hosting them on his website.
spark001uk
Postby spark001uk » Tue Nov 28, 2017 1:35 am
Excellent work guys. Thanks very much for getting to the bottom of it, I know it's been a problem that's been around for a while now!
Return to “emulators”
