Writing to FE05 in Elkulator
Postby davidb » Mon Jun 19, 2017 5:48 pm
I'm just testing some of my code that does things with the Electron's ULA in Elkulator and I've encountered something strange.
I had previously noticed that some code would fail if it was running from bank 13 (ROM cartridge bank 2) but work fine in bank 12 (ROM bank 1). I was stepping through it using the -debug option and discovered that when I write to FE05, the machine triggers a BRK instruction. The code at this point looks like this:
    81B5 : LDA #10
    81B7 : STA FE05
    81BA : LDA #04
    81BC : BIT FE00
The debug session looks like this:
81B5 : LDA #10       >s
81B7 : STA FE05      >s
BRK 81BA! 81BA 0000
BRK at 81BA
81BA : BRK           >c
So it looks like something causes the write to page out the ROM after the STA instruction. Is this normal? I'm now trying to remember if using different banks is a problem on the actual hardware.
If someone wants to try it, I've attached a ROM image in an archive.
vscroll1-2017-06-19.zip
(16.14 KiB) Downloaded 7 times
dp11
Re: Writing to FE05 in Elkulator
Postby dp11 » Mon Jun 19, 2017 6:10 pm
If you are running code from one ROM bank . Then change the ROM bank to a bank which doesn't have code at the next instruction then I would expect this to occur and unless i've missed something.
Postby davidb » Mon Jun 19, 2017 6:16 pm
dp11 wrote:If you are running code from one ROM bank . Then change the ROM bank to a bank which doesn't have code at the next instruction then I would expect this to occur and unless i've missed something.
You're quite right. I keep forgetting that FE05 is used for paging as well. #-o :roll:
Thanks. :)
Return to “emulators”
